2 Replies Latest reply on Feb 23, 2011 3:21 PM by dokhebi
    Configure ADE for Aluratek transfer
    dokhebi
      According to the ADE site, my Aluratek ebook reader is compatible.  But there are no instructions for setting up transfers between ADE and a device.  I looked at ADE for a configuration menu.
      What good is this product?  Is there supposed to be some automagic way that ADE knows about the ebook readers plugged into a computer it's running on?
      Where are the instructions?  I am not happy and I feel I am wasting my time.
        • 1. Re: Configure ADE for Aluratek transfer
          Level 4
          Hold on there!  Don't go blaming the product - yet....  [I am NOT an Adobe
          employee!]
          The instructions can be found in a couple of places.  To start, your ereader
          should have come with some setup instructions so you can connect it to your
          PC (or MAC) as a device.  That must be done first.  Once your computer
          recognizes the ereader, you're halfway there.  Then, you have to activate
          ADE by registering with Adobe.  When that's done, you can download and
          install ADE on your computer.  Once this is completed, you're ready for the
          'automagic'.
          Plug in your ereader and make sure it's recognized by your computer (In
          Windows, pull up Windows Explorer, go to My Computer, and look at the drives
          attached.  You should see your ereader as a drive letter).  Then, start
          ADE.  It will scan your computer to see if there are any ereader devices
          attached, and if it finds one, it will show it on the right hand side of the
          ADE display.
          This process is described in the ADE Help files.  I also got a list of
          instructions from my local library.
          If this doesn't work for you, then come back and ask some more questions.  I
          grant you that something can go wrong, and your fellow ADE bloggers may be
          able to give you some simple answers.  Before you freak out if something
          doesn't work, check ADE Help for 'Known Issues'.
          Hope this helps!
          • 2. Re: Configure ADE for Aluratek transfer
            dokhebi Level 1
            I gues one of the "known issues" is that I am using Linux (Fedora 13) and not Windows or Mac OS X.  The device is recognized as two direrctories (internal memory and SD card, both under /media) and ADE is installed using Wine, the "not a Windows Emulator emulator."  I can copy in ebooks from Kobo by drag-and-drop of the URLLink.acsm file into ADE but it doesn't recognize the ebook reader.
            I tried copying the .epub file directly onto the SD card but the ebook reader cannot open it.  I get a "failed to open" error message.  So much for DRM installed on my ebook reader.  A recent update of the firmware shows an Adobe copyright notice and something about Digital Editions so I suspect it *should* be able to handle the DRM.  Is there a hidden file I need to manaully copy over to read these books?
            Thanks inadvance,
            Edward Hooper
