2 Replies Latest reply on Feb 23, 2011 7:06 PM by Mayank Agrawal
    RH 9 Conditional Tags showing
    mindraytw
      Hi.
      I'm new to RH, so please be patient with me. :-)
      When I compile my RH HTML file I noticed that all my conditional text is showing even though it appears to be " turned off" in FM. How can I turn them off in RH?
      Thanks in advance.
        • 1. Re: RH 9 Conditional Tags showing
          Jeff_Coatsworth Adobe Community Professional & MVP
          You control that in the SSL layout when you create the chm.
          • 2. Re: RH 9 Conditional Tags showing
            Mayank Agrawal Level 2
            There are two possible solutions for your work flow.
            Solution One
            When FrameMaker content is imported in RoboHelp, RoboHelp imports all the Conditional tags and allows them to be turned On/Off independently. As suggested by Jeff they can be managed in Single Source Layout properties dialog. For HTML Help, you can click the "Define" button for Conditional Build Expression.
            Solution Two
            However, if you do not wish to manage the Conditional tags independently in RoboHelp, you can import FrameMaker content into RoboHelp with required conditions tuned On/Off as specified in FrameMaker. This can be done by turning "Apply FrameMaker Conditional Text Build Expression" setting on. Here is how this can be done.
            1. Go to File->Project Settings dialog
            2. Go to Import tab
            3. Click Edit button for FrameMaker document conversion settings dialog to open Conversion Settings dialog
            4. Select "Other Settings" on the left.
            5. Select the check box for "Apply FrameMaker Conditional Text Build Expression"
            6. Click OK on both the dialogs.
            7. Update/Import FrameMaker content.
            I hope this resolves the issue.
            Mayank
