4 Replies Latest reply on Feb 24, 2011 8:59 AM by John T Smith
    error message - could not find any capable video play modules
    dgl4gw
      Premier Pro CS5 - will not start having installed 5.03 update. New machine with only Adobe Master collection installed, iCore 7 -980, 12 GB DDR3, 3 sata drives and Nvidia FX 3800. error message - could not find any capable video play modules
        • 1. Re: error message - could not find any capable video play modules
          You may have been hit by the "revert to trial" bug (do a forum search) where the solution is to uninstall, run the clean script 2-3 times, and reinstall
          • 2. Re: error message - could not find any capable video play modules
            Colin Brougham Level 6
            Are your GPU drivers up-to-date? If I recall correctly, the Premiere Pro CS5 updates have often required GPU driver updates to use hardware MPE; I'm assuming that since you specifically mentioned your FX3800, that you have been using hardware MPE.
            • 3. Re: error message - could not find any capable video play modules
              dgl4gw Level 1
              Cheers re-installation has been sucessful in solving the problem. Do you have any idea what causes it
              ? would prefer to avoid problem rather than having to re-install every time.
              • 4. Re: error message - could not find any capable video play modules
                None that I have seen posted
                Now that everything is working... buy/use software to make a full backup of your boot drive to an external USB drive... plus making step-by-step backups during a new install or major program addition makes it easy to go back a step if something doesn't work
                This backup and then restore is, of course, only to the same computer with a new drive (or the same drive as long as you don't mind writing over everything) since doing a restore to a new computer won't work due to Windows and many programs having activation information that is keyed to your hardware (which is why Windows will force you to RE-Activate if you change very much hardware)
                The product I use is at http://www.terabyteunlimited.com/image-for-linux.htm
                Image runs off of a bootable CD via Linux (the Zip you download includes a program to make the bootable CD) and it reads EVERYTHING on the drive, even the hidden registration information, so everything is restored when needed... and you may restore the image to a brand new drive in case of a crash, and not have to re-install anything
                Please note that I own no part of Image, and I don't get a referral fee (that is just a plain web link) but I use the program and it has saved me a LOT of trouble when I had a hard drive die... and I was able to restore everything and not have to re-install or re-activate a single program, from Windows on up
