3 Replies Latest reply on Apr 19, 2011 7:43 AM by Mr. Kirkwood
    Removing Silver Bar at Bottom
    Mr. Kirkwood Level 1
      I have a project i made in Flash Catalyst. When i export it to AIR and run the executable there is a silver bar at the bottom of the window.does anyone know how to remove the silver bar at the bottom of the window? It is covering up my player controls... here is a screen shot.
        • 1. Re: Removing Silver Bar at Bottom
          The bar does not appear when i run the .swf file created when exporting the FC poject. it only appears when
          the .exe file is run. Does anone know here i find the skin to modify the look of the .exe file?
          • 2. Re: Removing Silver Bar at Bottom
            I forgot to mention that i am taking the FC file in to Flash Builder. I convert to Flex Desktop Project (runs in Adobe AIR). Then i change the framRate and save the project. next, i export the release build and its creates an Adobe AIR package. when i install the AIR i get the typical files in a folder.
            assets
            META-INF
            Main.css
            Main.swf
            Main_1.css
            mimetype
            Main.exe
            The .swf file will not run.
            The .exe file is the one with the silver bar at the bottom.
            when i export from Flash Catalyst the .exe file does not do this. it is only when i export from Flash Builder to the AIR package...Any ideas?
            • 3. Re: Removing Silver Bar at Bottom
              oOMadMaxOo posted this response...
              hi !
              This silver bar at the bottom of your Air Animation is a default component Skin for windowed applications, to desactivate it just insert "showStatusBar="false"
              at the beginning of your MXML Main file.
              Exemple :
              <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
              xmlns:mx="library://ns.adobe.com/flex/mx"
              height="360" width="654"
              backgroundAlpha="0"
              showStatusBar="false">
              This line work fine for my desktop application.
              (This works!)
