21 Replies Latest reply on Mar 14, 2011 5:23 PM by C. Agruss (Adobe)
    Flash Builder 4 Burrito suddenly won't open
    Avi Kessner Level 1
      Hi, I got Flash Builder Buritto at Adobe Max  and havn't touched it in a while.  I wanted to play with it a bit today, and when I tried to open it, the Eclipse Helios logo popped up, instead of Flash Builder 4 Burrito, and then suddenly closed again without any notification or warning.  I have tried this multiple times and it just won't open.
      I currently have Flash Builder 4 Premium and Flex builder 3 professional installed on my computer in 2 different places from the burrito instilation.
      Thanks.
        • 1. Re: Flash Builder 4 Burrito suddenly won't open
          C. Agruss (Adobe) Level 3
          Hi Avi,
          Are you on Mac or Win? Also, when you tried launching were you double-clicking an application, or running it from the Start Menu or Taskbar?
          In any case, try looking in the amt3.log file for clues. More on that here:
          http://kb2.adobe.com/cps/834/cpsid_83481.html
          -Chris
          • 2. Re: Flash Builder 4 Burrito suddenly won't open
            Avi Kessner Level 1
            Thanks, I am on a windows 7 machine, and I tried to open the program from the start menu using the windows key and they typing in the application name.
            two things... Firstly, I could not find a amt3.log file.  However I did find a file named just .log and it had the following text in it.
            !SESSION 2011-02-24 09:18:49.821 -----------------------------------------------
            eclipse.buildId=I20100608-0911
            java.version=1.6.0_16
            java.vendor=Sun Microsystems Inc.
            BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
            Command-line arguments:  -os win32 -ws win32 -arch x86 -clean
            !ENTRY org.eclipse.osgi 4 0 2011-02-24 09:19:12.062
            !MESSAGE Application error
            !STACK 1
            org.eclipse.swt.SWTError: No more handles
            at org.eclipse.swt.SWT.error(SWT.java:4109)
            at org.eclipse.swt.SWT.error(SWT.java:3998)
            at org.eclipse.swt.SWT.error(SWT.java:3969)
            at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
            at org.eclipse.swt.widgets.Control.createHandle(Control.java:633)
            at org.eclipse.swt.widgets.Composite.createHandle(Composite.java:305)
            at org.eclipse.swt.widgets.Control.createWidget(Control.java:649)
            at org.eclipse.swt.widgets.Scrollable.createWidget(Scrollable.java:134)
            at org.eclipse.swt.widgets.Control.<init>(Control.java:110)
            at org.eclipse.swt.widgets.Scrollable.<init>(Scrollable.java:75)
            at org.eclipse.swt.widgets.Composite.<init>(Composite.java:95)
            at org.eclipse.ui.splash.BasicSplashHandler.getBundleProgressMonitor(BasicSplashHandler.java:159)
            at org.eclipse.ui.splash.BasicSplashHandler.getContent(BasicSplashHandler.java:265)
            at org.eclipse.ui.internal.splash.EclipseSplashHandler.init(EclipseSplashHandler.java:86)
            at org.eclipse.ui.internal.Workbench$8.run(Workbench.java:781)
            at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
            at org.eclipse.ui.internal.Workbench.createSplashWrapper(Workbench.java:797)
            at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2456)
            at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2427)
            at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
            at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
            at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:663)
            at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
            at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashBuilderApplication.java:102)
            at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
            at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
            at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
            at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
            at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
            at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
            at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
            at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
            at java.lang.reflect.Method.invoke(Unknown Source)
            at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
            at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
            at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
            !SESSION 2011-02-24 09:19:39.684 -----------------------------------------------
            !ENTRY org.eclipse.osgi 4 0 2011-02-24 09:19:54.015
            !STACK 1
            I will keep looking for other logs.
            • 3. Re: Flash Builder 4 Burrito suddenly won't open
              Avi Kessner Level 1
              I found the amt3.log file, and none of the errors on the page you listed showed up in the file.  Most of the log was references to my flash builder 4 and cs5 launches which are working fine.
              edit: Something worth noting. In the amt3.log file there is a break in dates/time..
              2011-02-24 09:18:38 [2192]  ALM: _info_: End ALM
              2011-02-24 09:18:38 [2192]  performance: AMTReleaseProductLicense took 46.908688 ms
              2011-02-24 09:18:38 [2192]  AMT: END SESSION.
              2011-02-24 09:23:28 [7292]  AMT: START SESSION, library version 3.0.0.64,3.0
              2011-02-24 09:23:28 [7292]  AMT: Initializing C:\Program Files (x86)\Adobe\Adobe Flash Builder 4\
              2011-02-24 09:23:28 [7292]  AMT: Adobe License Manager version 3.2 (build 64.0) RELEASE
              If you look above you will notice that the time when I couldn't luanch burrito fits right in that time slot.   So it seems to be crashing before AMT even begins.
              Message was edited by: Avi Kessner
              • 4. Re: Flash Builder 4 Burrito suddenly won't open
                Avi, from the latest log you posted it appears that you may be running into the handles error described in this eclipse bug:
                https://bugs.eclipse.org/bugs/show_bug.cgi?id=211124
                If you read down to the bottom of that bug report, there's a proposed workaround that involves increasing your desktop heap limit, described in this link:
                http://journals.jevon.org/users/jevon-phd/entry/19833
                Please let us know if that approach helps for your configuration.
                -Chris
                • 5. Re: Flash Builder 4 Burrito suddenly won't open
                  JabbyPandaUA Level 3
                  I am experiencing the same issue as Avi Kessner, my .log file has the same error information
                  !SESSION 2011-03-01 16:31:51.390 -----------------------------------------------
                  eclipse.buildId=M20100909-0800
                  java.version=1.6.0_24
                  Framework arguments:  -product org.eclipse.epp.package.java.product -vm c:\Program Files\Java\jre6\bin\javaw.exe
                  Command-line arguments:  -os win32 -ws win32 -arch x86 -clean -product org.eclipse.epp.package.java.product -vm c:\Program Files\Java\jre6\bin\javaw.exe
                  !ENTRY org.eclipse.osgi 4 0 2011-03-01 16:31:58.843
                  !STACK 1
                  I've increased the desktop heap value in Windows XP registry as suggested as MSDN article http://blogs.msdn.com/b/ntdebugging/archive/2007/01/04/desktop-heap-overview.aspx, but no luck.
                  Going to reinstall Flash Builder 4 Burrito from a scratch.
                  • 6. Re: Flash Builder 4 Burrito suddenly won't open
                    Reading down further in the longer stack trace posted earlier, the error appears related to the eclipse splash handler.
                    There was an old handles bug connected with the eclipse splash handler, that was fixed in Eclipse 3.3.1, so this might be a new manifestation of that problem:
                    https://bugs.eclipse.org/bugs/show_bug.cgi?id=188091
                    I'll alert our Dev team, to see if they can find the source of the current problem.
                    -Chris
                    • 7. Re: Flash Builder 4 Burrito suddenly won't open
                      Unni Gopinathan S Adobe Employee
                      Can you please tell me the bundled eclipse version of your installed FB. Have you installed an eclipse update using the "Search for update" option?
                      • 8. Re: Flash Builder 4 Burrito suddenly won't open
                        Avi Kessner Level 1
                        I tried extending my desktop heap but no luck.
                        I don't know which version of eclipse is being used for flash builder burrito 4.5 as it won't open.  However I get an eclipse splash screen, not a flash builder one, and it just says Eclipse: Helios
                        However, my flex builder 3 install is Version: 3.3.1.R33x_r20070802-8y8eE8sEV3Fz0z0GlHJrXvTAUS
                        Build id: I20070625-1500
                        And my flash builder 4 install is
                        Version: 3.5.1.R35x_v20090910-9gEeG1_FthkNDSP2odXdThaOu9GFDPn83DGB7
                        Build id: M20090917-0800
                        I will try a clean install when I have time as well.
                        I've installed a bunch of plugins like Author Oxygen, Flex PMD, Flex Formatter and a few others, so It's possible I've updated my eclipse but I'm never did it explicitly.  However none of the plugins were installed in Flash Builder Burrito 4.5
                        • 9. Re: Flash Builder 4 Burrito suddenly won't open
                          Can you try the following steps. (The files and folders mentioned below is releative to Flash Builder installed folder)
                          1)FlashBuilder.ini
                                    Update the launcher.library argument
                                                    From
                                                        --launcher.library eclipse/plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.0.v20100503
                                                     To
                                                       --launcher.library eclipse/plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.1.R36x_v20100810
                          2)configuration/config.ini
                                          Update osgi.framework argument
        From
        osgi.framework=file\:plugins/org.eclipse.osgi_3.6.0.v20100517.jar
        To
        osgi.framework=file\:plugins/org.eclipse.osgi_3.6.1.R36x_v20100806.jar
                          3)eclipse\configuration\config.ini
                                                          Remove osgi.splashPath=platform\:/base/plugins/org.eclipse.platform
                                                          Update eclipse.application argument
        From
        eclipse.application=org.eclipse.ui.ide.workbench
        To
        eclipse.application=com.adobe.flexbuilder.standalone.FlashBuilderApplication
                                                          Update eclipse.product argument
        From
        eclipse.product=org.eclipse.platform.ide
        To
        eclipse.product=com.adobe.flexbuilder.standalone.producte36
                          4)Replace eclipse\plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.1.1.R36x_v20100810/eclipse _1309.dll with the FB version (Present in the eclipse\plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.1.0.v20100503 folder before update).
                          • 10. Re: Flash Builder 4 Burrito suddenly won't open
                            Avi Kessner Level 1
                            Ok, a few small propblems.
                            I changed the .ini files as you suggested but then I hit some roadblocks.
                            1. Step 3 allready had the "new values" you suggested.
                            2. Step 3, I could not find any values for the "splashPath" argument
                            I ran the program and hit the same problem...
                            *new question... was I supposed to be doing this to my current flash builder 4 installed folders, or my flash builder 4 burrito installed folders?
                            • 11. Re: Flash Builder 4 Burrito suddenly won't open
                              juliannewa
                              @ avi: check up in C:\Program Files\Adobe\Adobe Flash Builder Burrito\eclipse\eclipse.ini the eclipse version has been installed e.g.
                              -startup
                              plugins/org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_1400.jar
                              --launcher.library
                              plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.2.R36x_v20101222
                              instead 3.6.1.R36x_v20100806.jar as in unnigs example, and follow unnigs described steps 1.) to 3.) I didn't have to replace the .dll file from step 4.)
                              Flash Buritto logo pop up and FB works again.
                              @unnigs: I have installed the eclipse update using the "Search for update" option in FB.
                              • 12. Re: Flash Builder 4 Burrito suddenly won't open
                                @juliannewa :Thanks for clarifying the steps. The path specified in the arguments should be a valid one (proper versions can be found in eclipse.ini). 4th step is optional.
                                @avi : I hope that you are able to use FB burrito now. The issue here is with the eclipse update, FB standalone version does not support the eclipse update installed using "Search for update"(You can install the updates for the other plugins which you have installed but not the base version of eclipse). If you want to use latest version of eclipse please use the plugin installer to plugin FB to desired version of eclipse.
                                Refer the Bug : http://bugs.adobe.com/jira/browse/FBG-2515
                                • 13. Re: Flash Builder 4 Burrito suddenly won't open
                                  Dan Zen Level 1
                                  I am in Windows 7 and just did the latest Java Update from the normal annoying little Java update reminder thingy.
                                  Now  Burrito will not load and gives me the Eclipse Helios splash screen.
                                  I took a look at your instructions, and went to edit the ini file but I can't save it.  The file is not read only but the directory is set to read only.  So I set that to not read only and the only choice I had was to do all the files in the folder.  So I did and waited patiently to do the 12000 files or whatever - wow - you guys are working.  And... I still can't edit it and the Burrito folder is still read only and I am an administrator so what gives?  My Program Folder (x86) is also read only and the only option to turn that off is setting all files inside to not read only.  Well... I really don't want to do that.
                                  So... can you give me a better way - I really want to get working.
                                  I looked into rolling back my Java - or my eclipse and all I get are Web pages of crap I have no idea about.
                                  Thanks.
                                  • 14. Re: Flash Builder 4 Burrito suddenly won't open
                                    Hi Dan,
                                    Are you using the copy of eclipse bundled with FB4 Burrito, or are you plugged into your own custom copy of eclipse?
                                    -Chris
                                    • 15. Re: Flash Builder 4 Burrito suddenly won't open
                                      Dan Zen Level 1
                                      Thanks for your speedy reply - and all the years of most excellent software!
                                      I was using the bundled version I guess.
                                      I managed to update those ini files by dragging them out of the directory, editing them and putting them back in so I tried out the instructions above.  I then started getting an immediate little white pop up saying it could not find some sort of resource - can't remember.
                                      So I did an uninstall and reinstall.  Last time I just did the reinstall and it did not help.  This time, with an uninstall, shutdown, restart and install I am in!
                                      To recap... I installed flashbuilder_burrito_287807.exe and ran it for a week.  Today, I said yes to an average Java update.  Then when I started Burrito, it gave me the generic eclipse Equinox screen and that's it.  I uninstalled with Windows uninstall, shut down, and reinstalled and it works.
                                      Love the tool by the way!  Just building a really nice a Playbook app called Rank - like a mini spreadsheet with totals.
                                      Dan
                                      • 16. Re: Flash Builder 4 Burrito suddenly won't open
                                        Dan Zen Level 1
                                        Crudly - it looks like I have spoken too soon.  I closed down Burrito and now when I go to start up again, it is the eclipse Helios Screen and nothing (that's what it was before - I mistakenly called it Equinox in my last message - it was Helios).  I tried from the start menu and from the program files exe.
                                        So... any suggestions?  One thing I could not quite figure out when I tried the instructions here was whether these paths will be different for people depending on their Java / eclipse install or whatever.  As mentioned, when I set them to what you suggested it could not find things.  I tried the various solutions listed.  Please let me know if you need anything from me to help solve the case.
                                        Dan
                                        • 17. Re: Flash Builder 4 Burrito suddenly won't open
                                          Dan Zen Level 1
                                          Here are my original unedited files that @unnings suggested to look at.  I tried modifying them again and it did not work.  I get the message:  The FlashBuilder executable launcher was unable to locate its companion library. I get this error after step 1).
                                          FlashBuilder.ini
                                          -clean
                                          -startup
                                          eclipse/plugins/org.eclipse.equinox.launcher_1.1.0.v20100507.jar
                                          --launcher.library
                                          --launcher.defaultAction
                                          openFile
                                          -nl
                                          en_US
                                          -vmargs
                                          -Xms256m
                                          -Xmx512m
                                          -XX:MaxPermSize=256m
                                          -XX:PermSize=64m
                                          -Djava.net.preferIPv4Stack=true
                                          -Dorg.eclipse.equinox.p2.reconciler.dropins.directory=eclipse/dropins
                                          -Declipse.application=com.adobe.flexbuilder.standalone.FlashBuilderApplication
                                          #This configuration file was written by: org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxFwConfigFileParser
                                          #Fri Jul 30 17:13:05 PDT 2010
                                          org.eclipse.update.reconcile=false
                                          eclipse.p2.profile=epp.package.java
                                          osgi.instance.area.default=@user.home/Adobe Flash Builder Burrito Preview
                                          equinox.use.ds=true
                                          osgi.bundles=reference\:file\:org.eclipse.equinox.simpleconfigurator_1.0.200.v20100503.jar@1\:start
                                          org.eclipse.equinox.simpleconfigurator.configUrl=file\:org.eclipse.equinox.simpleconfigurator/bundles.info
                                          osgi.framework.extensions=
                                          osgi.bundles.defaultStartLevel=4
                                          eclipse.p2.data.area=file\:p2/
                                          osgi.configuration.area=@user.home/Adobe Flash Builder Burrito Preview/cascaded/287807/configuration
                                          osgi.shared.configuration.area=file\:configuration
                                          osgi.configuration.cascaded=true
                                          eclipse/configuration/config.ini
                                          equinox.use.ds=true
                                          for reference: eclipse/eclipse.ini (seems to be the same as the FlashBuilder.ini)
                                          -clean
                                          -startup
                                          --launcher.library
                                          -nl
                                          en_US
                                          -vmargs
                                          -Xms256m
                                          -Xmx512m
                                          -XX:PermSize=64m
                                          -Dorg.eclipse.equinox.p2.reconciler.dropins.directory=dropins
                                          Thanks!
                                          • 18. Re: Flash Builder 4 Burrito suddenly won't open
                                            juliannewa Level 1
                                            it seems to me that there is something wrong in the eclipse.ini, I mean it shows the older version.
                                            in eclipse/.eclipseproduct you'll find the installed eclipse version
                                            for ref. my eclipse/.eclipseproduct :
                                            name=Eclipse Platform
                                            id=org.eclipse.platform
                                            version=3.6.1
                                            check the installed version in the "eclipse/plugins/" folder.
                                            a search for "org.eclipse.equinox.launcher." should show you the installed versions.
                                            for ref. my search:
                                            in the eclipse.ini you should than find the newest file and folder. for ref. my eclipse.ini:
                                            -clean
                                            -nl
                                            en_US
                                            -startup
                                            --launcher.library
                                            -product
                                            openFile
                                            --launcher.XXMaxPermSize
                                            256M
                                            -showsplash
                                            256m
                                            openFile
                                            -vmargs
                                            -XX:PermSize=64m
                                            -Dosgi.requiredJavaVersion=1.5
                                            -Xms256m
                                            -Xmx512m
                                            if you have to make changes, dont forget to  first backup your files.
                                            if the found version is the same as in your eclipse.ini than you have to  follow unnigs described steps 1.) to 3.) to make changes.
                                            otherwise replace in the eclipse.ini  the newest found version in the pluggins folder and follow unnigs described steps 1.) to 3.) - it should work.
                                            • 19. Re: Flash Builder 4 Burrito suddenly won't open
                                              Dan Zen Level 1
                                              In my eclipse/.eclipseproduct it says:
                                              version=3.5.0
                                              In my eclipse plugins I have only these two launcher files:
                                              I am not sure really what I am supposed to do - sorry and thanks for your help.
                                              Also - why would my files be any different? I just downloaded the files from Adobe two weeks ago and the Burrito page says the last update was October 2010.   I don't get it.  Would it make a difference to uninstall, download the files again and reinstall?  I did a previous uninstall and reinstall but I used the same download from two weeks ago.
                                              Dan
                                              • 20. Re: Flash Builder 4 Burrito suddenly won't open
                                                Dan Zen Level 1
                                                Just uninstalled and reinstalled the same zip from before.  Seems to be running fine now even with shutdowns and start ups.  Will let you know if it reverts but so far so good.
                                                • 21. Re: Flash Builder 4 Burrito suddenly won't open
                                                  Hi Dan,
                                                  Looks as if the original problem you were experiencing is not the one addressed by Unni's workaround. Unni was describing a fix to use if you've updated eclipse 3.6.0 (or eclipse 3.6.1) to eclipse 3.6.2.
                                                  However, from the version info you posted, I think you're running eclipse 3.6.0, that was bundled with Burrito's MAX Preview release last year. [Aside: there was a bug in the .eclipseproduct file that eclipse.org released with the eclipse 3.6.0 packages, where it read 3.5.0 as you described - they fixed that in eclipse 3.6.1.] Assuming that you're really using eclipse 3.6.0, then updating your ini files to use the eclipse 3.6.2 settings that Unni and Julianne described will make things worse for your installation, so you'll probably want to revert those back to the settings that were installed originally.
                                                  For your scenario, it might be easier to uninstall, and then re-install the MAX Preview. As a matter of habit, I routinely reboot before the uninstall, and then reboot again before re-installing.
                                                  Let me know how it goes,
                                                  -Chris
