7 Replies Latest reply on Jun 27, 2007 5:05 AM by Clark_Kent101
    Repeater with empty dataprovider
    karel_s
      I have this repeater with a dataprovider:
      <mx:FormItem width="278">
      <mx:Repeater id="documentenRepeater" dataProvider="{documenten}">
      <mx:Label text="{documentenRepeater.currentItem.documentnaam}"/>
      </mx:Repeater>
      </mx:FormItem>
      If the dataprovider is empty, i get this error:
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
      What is the best way to solve this issue?
      Thanks a lot
      K
        • 1. Re: Repeater with empty dataprovider
          Clark_Kent101 Level 1
          insert a short-hand if statement within the dataProvider curly braces to check to see if the data provider variable is null. So you could do:
          dataProvider="{(documenten != null)?documenten:''}"
          Hope that helps,
          - Tony
          • 2. Re: Repeater with empty dataprovider
            karel_s Level 1
            Hi Tony,
            generates an error. (expects an > )
            When i remove the double quotes before the last curly brace, still got an error (rightparen is unexpected)
            Any ideas?
            K
            • 3. Re: Repeater with empty dataprovider
              The double quote you removed before the last curly brace isn't double quotes, its two single quotes. Try inserting the two single quotes instead of the double quote.
              • 4. Re: Repeater with empty dataprovider
                karel_s Level 1
                Yes!, no errors in this line anymore, but still the same old error:
                I guess the repeater needs an array anyway. I thought if the dataprovider is empty, the repeater should repeat himself zero times.
                Is it possible to do something like this:
                if array not empty then
                <mx:formitem>
                </mx:Formitem>
                end if
                K
                • 5. Re: Repeater with empty dataprovider
                  If the dataProvider is an array and the array is null, you shouldn't get that error - even if the dataprovider of the repeater is set to nothing, you still shouldn't get that error - here is an example:
                  <mx:Script>
                  <![CDATA[
                  [Bindable]
                  private var dp:Array = [1, 2, 3, 4, 5, 6, 7, 8, 9];
                  private function init():void
                  dp = null;
                  trace(dp);
                  </mx:Script>
                  <mx:Repeater dataProvider="{(dp != null)?dp:''}" id="rp">
                  <mx:Button height="49" width="50"
                  label="{String(rp.currentItem)}"
                  </mx:Repeater>
                  I dont get any errors. The error is probably coming up when you try access specific data from an array/array collection. The Label within the repeater tags is what might be causing the error, change it to:
                  <mx:Label text="{documentenRepeater.currentItem}"/>
                  To see what happens.
                  • 6. Re: Repeater with empty dataprovider
                    karel_s Level 1
                    Tony,
                    You are correct.
                    It is not he repeater going wrong, it's the event.result handler!
                    my hhtpservice result event handler is throwing the error.
                    documenten=event.result.Documenten.Document
                    When this returning xml is empty, the error is thrown
                    guess i have to look in that direction
                    Thanks!
                    • 7. Re: Repeater with empty dataprovider
                      Cool, no problem.
