6 Replies Latest reply on Feb 24, 2011 9:58 AM by Colin Brougham
    Export file size help...output seems way too big
    mccrorey_digital Level 1
      I have a 12 minute movie with audio, video and stills in it.
      Currently when I export it the file is 865MB...  I need it to be less than 100 with decent quality.  It is a tutorial video that will be downloaded from the web.
      Can you please give me some direction on how to do this?  On what variables to change etc.  I know if I exported this out of Camtasia Studio, it would be around that 100 or less bench mark .... problem is I don't know what the settings for the Camtasia preset are.
      I am using the following setup:
      Quicktime Format
      Summary:
      Output:
      1400x790, 15(fps), quality 100
      48000 Hz, Stero, 16 bit
      H.264
      Source:
      Sequece, 01-OverviewSWKit
      1920x1080 (1.0), 24fps, Progressive, 00:12:03:12
      48000 Hz, Stereo
      Settings:
      Video Codec:  H264
      Basica Settings:
      Quality 100
      Width/height (1400 x 790
      Aspect: Square pixels (1.0)
      Render at maximum depth - "UN"-checked
      Depth: 24 bit
      Advanced Settings
      Key Frame every 1 frame - "UN" checked
      Optimize stills - "UN" checked
      Frame Reordering "UN" checked
      Bitrate setting:
      Limit data rate to xxxx  "UN" checked
      Use Maximum Render Quality - "UN" Checked
      Use Previews "UN" Checked
      Use Frame Blending "CHECKED"
        • 1. Re: Export file size help...output seems way too big
          Harm Millaard Level 7
          For a 12 minute video less than 100 MB with decent quality is impossible. It is eitther BB or LL. Bigger size, Better quality or Less space, Lower quality.
          Your could try smaller resolution, like 320 x 240, 10 FPS, at low bitrates and with the lowest mono sound possible. 8 KHz or something. Or shorten the sequence to only a couple of minutes.
          • 2. Re: Export file size help...output seems way too big
            Colin Brougham Level 6
            Bitrate setting:
            Check this, and set a value. Bitrate is the single biggest determinant of output file size. If you lower the bitrate, you decrease the file size; of course, as you lower the bitrate, you lower the potential output quality. Welcome to the balancing act that is video encoding...
            • 3. Re: Export file size help...output seems way too big
              Nonsense. I could do a lot with 8MB a minute, particularly if it's something like a screen recording. Don't be such a naysayer...
              • 4. Re: Export file size help...output seems way too big
                No HD, only 5:30 minutes and already over 100 MB.
                Now go to 12 minutes for a movie, not a screen recording.
                Maybe you can show me a less than 100 MB file with a 12 minute HD movie with decent quality. I look forward to it. If you can't, please stop calling me a naysayer.
                • 5. Re: Export file size help...output seems way too big
                  Colin,
                  Thanks so much for your help....I appreciate you looking into this for me.
                  I am playing with the bit rate setting now to balance the quality vs. file size.
                  Are there anyother variables that you would recommend - besides output size.
                  Paul
                  • 6. Re: Export file size help...output seems way too big
                    Well, with the Apple H.264 encoder in a QuickTime container, you're a bit limited to the number of things you can tweak to decrease final file size. Using a more advanced H.264 encoder, like the free x264, will give access to many of the more "high-tech" bells and whistles that are part of the H.264 standard. One potential would be to tick the "Key frame every # frame" box and try a few values there, usually at multiples of your frame rate. Key frames are "whole" frames that take up much more space in the final file size, and decrease their frequency might help slightly decrease file size, though it will also affect quality.
                    Short of changing the dimensions of your destination video, decreasing the frame rate, or changing the bitrate of the video and audio streams, you will eventually reach a limit of how much you can push one parameter or another. You might try using H.264 in the Format (not codec) dropdown; this will give you a bit more control over encoding to an H.264 MP4 file. Unless you specifically need a QuickTime MOV, you might find you get better results with the H.264 MP4.
                    These are of course just the options in Premiere itself. Once you go outside the castle walls, you can find a whole bunch of other options, though they usually come at a steeper learning curve. The big thing to remember is that there is no free lunch when it comes to encoding; you have to give a bit here to gain there, and it's all about setting thresholds of what you're willing to accept.
