4 Replies Latest reply on Mar 8, 2011 9:45 AM by Chang_indd
    How to select and alert
    Chang_indd Level 1
      Hi All,
      I want to delete text frame which has not contents. I do it manually but it takes time. Some of the text frames are within group of textframe.
      Can I select and alert my first instance of empty text frame in my document through js.
      Thank you,
      Chang
        • 1. Re: How to select and alert
          csm_phil Level 4
          Hi Chang,
          Here is my scripting code, i think you expect this:
          var myPageItems = myDoc.allPageItems;
          for (var i =0; i<myPageItems.length; i++){
              app.select(myPageItems[i]);
              alert(app.selection[0].constructor.name);
              if(app.selection[0].constructor.name == "TextFrame"){
                  if(app.selection[0].contents == ""){
                      try{
                          app.selection[0].locked=false;
                          app.selection[0].remove();
                          }catch(e){};
                  app.selection = null;
          CSM_PHiL
          • 2. Re: How to select and alert
            Chang_indd Level 1
            Thanks for you reply.
            The provided code selects  and alert all the pageitems constructor name. And delete only ungrouped empty text frame.
            However, I want js code which only select and alert first instance of empty text frame within group or without group in my document.
            Anyone can help.
            Chang
            • 3. Re: How to select and alert
              csm_phil Level 4
              Hi Chang,
              i have modified the js code as per your request.
                  var mySel = app.selection[0];
                  try{
                      mySel.locked=false;
                      }catch(e){};
                      if(mySel.constructor.name == "TextFrame"){
                          if(mySel.contents == ""){
                              try{
                                   //if you want alert enable the below line
                                  //alert(mySel.constructor.name);
                                  mySel.remove();
                                  }catch(e){};
              Regards
              CSM_Phil
              • 4. Re: How to select and alert
                Chang_indd Level 1
                Dear CSM_Phil,
                Thanks for quick reply, you have solved my problem.
                I require this code.
                Thanks again,
                Chang
