2 Replies Latest reply on Feb 24, 2011 10:37 PM by huangweiaaaaaaaaaasdf
    Cannot launch eclipse with burrito
      Hi All,
      I just install FB burrito and the plugin for eclipse.
      But I cannot lauch it correctly.
      When I double click the FB icon, it just show the splash screen and a input serial number window.
      And the IDE window pops up and disappeared very soon.
      I cannot find any error message in the Windows event log or amt3.log.
      Is there anybody can help with this?
      Thanks a lot.
        • 1. Re: Cannot launch eclipse with burrito
          Balaji Sridhar Level 2
          Can you provide us the following details:
          1) version of Flash Builder Burrito
          2) Version of eclipse
          3) Launch the eclipse (on which you installed FB) and attach the log file from Eclipse -> About Eclipse ->Installation Details ->Configuration ->Error Log. Also check if the 'Flash' perspective opens.
          Balaji
          • 2. Re: Cannot launch eclipse with burrito
            huangweiaaaaaaaaaasdf Level 1
            1) I am using flashbuilder_burrito_287807
            2) Eclipse SDK Version: 3.6.1 Build id: M20100909-0800
            3) It is strange that I can use the perspective to switch Java eclipse to flash eclipse! Thank you!
            here is the error log:
            !SESSION 2011-02-24 10:27:04.842 -----------------------------------------------
            eclipse.buildId=M20100909-0800
            java.version=1.6.0_24
            java.vendor=Sun Microsystems Inc.
            BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
            Command-line arguments:  -os win32 -ws win32 -arch x86
            !ENTRY org.eclipse.equinox.preferences 4 4 2011-02-24 10:29:02.506
            !MESSAGE Exception loading preferences from: .
            !STACK 0
            org.osgi.service.prefs.BackingStoreException: Unable to determine provisioning agent from location: file:\2fD:\2feclipse\2fconfiguration\2f..\2fp2\2f
                 at org.eclipse.equinox.internal.p2.engine.ProfilePreferences.getAgent(ProfilePreferences.java:159)
                 at org.eclipse.equinox.internal.p2.engine.ProfilePreferences.load(ProfilePreferences.java:240)
                 at org.eclipse.core.internal.preferences.EclipsePreferences.create(EclipsePreferences.java:307)
                 at org.eclipse.core.internal.preferences.EclipsePreferences.internalNode(EclipsePreferences.java:543)
                 at org.eclipse.core.internal.preferences.EclipsePreferences.node(EclipsePreferences.java:669)
                 at org.eclipse.core.internal.preferences.EclipsePreferences.internalNode(EclipsePreferences.java:549)
                 at org.eclipse.core.internal.preferences.RootPreferences.getNode(RootPreferences.java:106)
                 at org.eclipse.core.internal.preferences.RootPreferences.node(RootPreferences.java:85)
                 at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.getPreferences(AbstractRepositoryManager.java:499)
                 at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.remember(AbstractRepositoryManager.java:857)
                 at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.stop(AbstractRepositoryManager.java:1052)
                 at org.eclipse.equinox.internal.p2.core.ProvisioningAgent.unregisterService(ProvisioningAgent.java:121)
                 at org.eclipse.equinox.internal.p2.core.ProvisioningAgent.removedService(ProvisioningAgent.java:182)
                 at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:922)
                 at org.osgi.util.tracker.AbstractTracked.untrack(AbstractTracked.java:351)
                 at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:865)
                 at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:104)
                 at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:933)
                 at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:227)
                 at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:149)
                 at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:756)
                 at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:711)
                 at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.unregister(ServiceRegistrationImpl.java:225)
                 at org.eclipse.equinox.internal.ds.InstanceProcess.disposeInstances(InstanceProcess.java:355)
                 at org.eclipse.equinox.internal.ds.InstanceProcess.disposeInstances(InstanceProcess.java:305)
                 at org.eclipse.equinox.internal.ds.Resolver.disposeComponentConfigs(Resolver.java:685)
                 at org.eclipse.equinox.internal.ds.Resolver.disableComponents(Resolver.java:661)
                 at org.eclipse.equinox.internal.ds.SCRManager.stoppingBundle(SCRManager.java:553)
                 at org.eclipse.equinox.internal.ds.SCRManager.bundleChanged(SCRManager.java:232)
                 at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:919)
                 at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEventPrivileged(Framework.java:1349)
                 at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1300)
                 at org.eclipse.osgi.framework.internal.core.BundleHost.stopWorker(BundleHost.java:497)
                 at org.eclipse.osgi.framework.internal.core.AbstractBundle.suspend(AbstractBundle.java:550)
                 at org.eclipse.osgi.framework.internal.core.Framework.suspendBundle(Framework.java:1097)
                 at org.eclipse.osgi.framework.internal.core.StartLevelManager.decFWSL(StartLevelManager.java:597)
                 at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:257)
                 at org.eclipse.osgi.framework.internal.core.StartLevelManager.shutdown(StartLevelManager.java:215)
                 at org.eclipse.osgi.framework.internal.core.InternalSystemBundle.suspend(InternalSystemBundle.java:266)
                 at org.eclipse.osgi.framework.internal.core.Framework.shutdown(Framework.java:690)
                 at org.eclipse.osgi.framework.internal.core.Framework.close(Framework.java:588)
                 at org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(EclipseStarter.java:415)
                 at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:198)
                 at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                 at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
                 at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
                 at java.lang.reflect.Method.invoke(Unknown Source)
                 at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
                 at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
                 at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
            !SESSION 2011-02-24 10:38:08.356 -----------------------------------------------
            !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 10:40:58.066
            !MESSAGE Connection to http://download.eclipse.org/eclipse/updates/3.6/p2.index failed on No route to host: connect. Retry attempt 0 started
            !STACK 0
            java.net.NoRouteToHostException: No route to host: connect
                 at java.net.PlainSocketImpl.socketConnect(Native Method)
                 at java.net.PlainSocketImpl.doConnect(Unknown Source)
                 at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
                 at java.net.PlainSocketImpl.connect(Unknown Source)
                 at java.net.SocksSocketImpl.connect(Unknown Source)
                 at java.net.Socket.connect(Unknown Source)
                 at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43)
                 at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81)
                 at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73)
                 at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65)
                 at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707)
                 at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361)
                 at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387)
                 at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171)
                 at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
                 at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346)
                 at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1142)
                 at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:710)
                 at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:889)
                 at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576)
                 at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:98)
                 at org.eclipse.equinox.internal.p2.repository.FileReader.sendRetrieveRequest(FileReader.java:342)
                 at org.eclipse.equinox.internal.p2.repository.FileReader.readInto(FileReader.java:288)
                 at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:71)
                 at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:127)
                 at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:718)
                 at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:639)
                 at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
                 at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
                 at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:115)
                 at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:100)
                 at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$2.runModal(PreloadingRepositoryHandler.java:82)
                 at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:177)
                 at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
            !ENTRY org.eclipse.core.net 1 0 2011-02-24 10:41:11.270
            !MESSAGE System property http.proxyHost is not set but should be camaproxy.am.thmulti.com.
            !ENTRY org.eclipse.core.net 1 0 2011-02-24 10:41:11.286
            !MESSAGE System property http.proxyPort is not set but should be 80.
            !ENTRY org.eclipse.core.net 1 0 2011-02-24 10:41:11.317
            !MESSAGE System property https.proxyHost is not set but should be camaproxy.am.thmulti.com.
            !ENTRY org.eclipse.core.net 1 0 2011-02-24 10:41:11.332
            !MESSAGE System property https.proxyPort is not set but should be 80.
            !SESSION 2011-02-24 15:46:37.115 -----------------------------------------------
            !ENTRY org.eclipse.ui 4 4 2011-02-24 15:48:17.148
            !MESSAGE Unable to find view with id: com.adobe.flashbuilder.analytics.ui.SiteCatalystView, when creating perspective com.adobe.flexbuilder.editors.mxml.ui.perspectives.development
            !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 15:53:51.319
            !STACK 0
            !ENTRY org.eclipse.equinox.p2.core 4 0 2011-02-24 15:55:57.338
            !MESSAGE Provisioning exception
            !STACK 1
            org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at http://download.eclipse.org/eclipse/updates/3.6/content.xml.
                 at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:189)
                 at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleMetadataRepositoryFactory.java:66)
                 at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:88)
                 at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57)
                 at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:746)
                 at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:651)
            Caused by: java.net.NoRouteToHostException: No route to host: connect
                 at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:227)
                 at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69)
                 ... 1 more
            !SUBENTRY 1 org.eclipse.equinox.p2.repository 4 1002 2011-02-24 15:55:57.338
            !MESSAGE Unable to read repository at http://download.eclipse.org/eclipse/updates/3.6/content.xml.
            !STACK 0
            !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 15:56:18.221
            !STACK 0
                 at org.eclipse.equinox.p2.engine.ProvisioningContext.loadMetadataRepository(ProvisioningContext.java:211)
                 at org.eclipse.equinox.p2.engine.ProvisioningContext.getLoadedMetadataRepositories(ProvisioningContext.java:194)
                 at org.eclipse.equinox.p2.engine.ProvisioningContext.getMetadata(ProvisioningContext.java:275)
                 at org.eclipse.equinox.internal.p2.director.SimplePlanner.gatherAvailableInstallableUnits(SimplePlanner.java:322)
                 at org.eclipse.equinox.internal.p2.director.SimplePlanner.getSolutionFor(SimplePlanner.java:382)
                 at org.eclipse.equinox.internal.p2.director.SimplePlanner.getProvisioningPlan(SimplePlanner.java:440)
                 at org.eclipse.equinox.internal.p2.operations.PlannerResolutionJob.runModal(PlannerResolutionJob.java:76)
                 at org.eclipse.equinox.p2.operations.ProfileChangeOperation.resolveModal(ProfileChangeOperation.java:115)
                 at org.eclipse.equinox.internal.p2.ui.dialogs.ProvisioningOperationWizard$1.run(ProvisioningOperationWizard.java:207)
                 at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
            !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 15:57:00.190
            !MESSAGE Connection to http://download.eclipse.org/releases/helios/p2.index failed on No route to host: connect. Retry attempt 0 started
            !STACK 0
            !ENTRY org.eclipse.equinox.p2.core 4 0 2011-02-24 15:58:45.197
            !STACK 1
            org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at http://download.eclipse.org/releases/helios/content.xml.
                 ... 1 more
            !SUBENTRY 1 org.eclipse.equinox.p2.repository 4 1002 2011-02-24 15:58:45.197
            !MESSAGE Unable to read repository at http://download.eclipse.org/releases/helios/content.xml.
            !STACK 0
            !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 15:59:27.072
            !STACK 0
            !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 16:01:15.182
            !STACK 0
                 at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:99)
                 at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:95)
                 at org.eclipse.equinox.p2.engine.ProvisioningContext.getLoadedArtifactRepositories(ProvisioningContext.java:160)
                 at org.eclipse.equinox.p2.engine.ProvisioningContext.getArtifactRepositories(ProvisioningContext.java:143)
                 at org.eclipse.equinox.internal.p2.engine.phases.Sizing.completePhase(Sizing.java:91)
                 at org.eclipse.equinox.internal.p2.engine.Phase.postPerform(Phase.java:216)
                 at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:84)
                 at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:44)
                 at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:73)
                 at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44)
                 at org.eclipse.equinox.internal.p2.ui.ProvUI.getSize(ProvUI.java:253)
                 at org.eclipse.equinox.internal.p2.ui.dialogs.SizeComputingWizardPage$1.run(SizeComputingWizardPage.java:63)
            !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 16:03:21.990
            !STACK 0
            !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 16:14:27.966
            !STACK 0
                 at org.eclipse.equinox.internal.p2.engine.DownloadManager.start(DownloadManager.java:72)
                 at org.eclipse.equinox.internal.p2.engine.phases.Collect.completePhase(Collect.java:76)
                 at org.eclipse.equinox.p2.operations.ProvisioningSession.performProvisioningPlan(ProvisioningSession.java:174)
                 at org.eclipse.equinox.p2.operations.ProfileModificationJob.runModal(ProfileModificationJob.java:79)
            !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 16:15:52.026
            !STACK 0
            !SESSION 2011-02-24 16:17:35.268 -----------------------------------------------
            !ENTRY org.eclipse.jface 2 0 2011-02-24 16:17:58.115
            !MESSAGE Keybinding conflicts occurred.  They may interfere with normal accelerator operation.
            !SUBENTRY 1 org.eclipse.jface 2 0 2011-02-24 16:17:58.115
            !MESSAGE A conflict occurred for CTRL+G:
            Binding(CTRL+G,
                 ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.java.search.declarations.in.workspace,Declaration in Workspace,
                      Search for declarations of the selected element in the workspace,
                      Category(org.eclipse.search.ui.category.search,Search,Search command category,true),
                      ,,true),null),
                 org.eclipse.ui.defaultAcceleratorConfiguration,
                 org.eclipse.ui.contexts.window,,,system)
            Binding(CTRL+G,
                 ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.declarations.in.workspace,Find All Declarations In Workspace,
                      Category(com.adobe.flexbuilder.editorcore.navigation.category,Navigation,null,true),
                      LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllDeclarationsAction@b7dc78)),
                      ,,true),null),
                 com.adobe.flexide.editorcore.flexEditorScope,,,system)
            Binding(CTRL+G,
                      ,,true),null),
                 com.adobe.flexbuilder.as.editor.context.packageexplorer,,,system)
            !MESSAGE A conflict occurred for CTRL+SHIFT+G:
            Binding(CTRL+SHIFT+G,
                 ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.java.search.references.in.workspace,References in Workspace,
                      Search for references to the selected element in the workspace,
                      ,,true),null),
                 ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.references.in.workspace,Find All References In Workspace,
                      LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllReferencesAction@eb4dba)),
                      ,,true),null),
                      ,,true),null),
            !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 17:19:49.036
            !STACK 0
            !ENTRY org.eclipse.equinox.p2.core 4 0 2011-02-24 17:22:16.147
            !STACK 1
                 ... 1 more
            !SUBENTRY 1 org.eclipse.equinox.p2.repository 4 1002 2011-02-24 17:22:16.147
            !STACK 0
            !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 17:22:37.156
            !STACK 0
            !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 17:23:40.151
            !MESSAGE Connection to http://download.eclipse.org/releases/helios/p2.index failed on Connection timed out: connect. Retry attempt 0 started
            !STACK 0
            java.net.ConnectException: Connection timed out: connect
            !ENTRY org.eclipse.equinox.p2.core 4 0 2011-02-24 17:25:46.236
            !STACK 1
                 ... 1 more
            !SUBENTRY 1 org.eclipse.equinox.p2.repository 4 1002 2011-02-24 17:25:46.252
            !STACK 0
            !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 17:26:07.261
            !STACK 0
            !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 17:27:53.959
            !STACK 0
            !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 17:29:52.586
            !STACK 0
                 at org.eclipse.equinox.internal.p2.engine.EngineSession.rollBackPhase(EngineSession.java:239)
                 at org.eclipse.equinox.internal.p2.engine.EngineSession.rollback(EngineSession.java:178)
                 at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:82)
            !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 17:32:20.418
            !STACK 0
            !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 17:34:05.854
            !STACK 0
            !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 17:35:51.153
            !STACK 0
            !SESSION 2011-02-24 17:55:26.783 -----------------------------------------------
            !ENTRY org.eclipse.jface 2 0 2011-02-24 17:55:48.126
            !SUBENTRY 1 org.eclipse.jface 2 0 2011-02-24 17:55:48.126
            Binding(CTRL+G,
                      ,,true),null),
            Binding(CTRL+G,
                      LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllDeclarationsAction@1031d18)),
                      ,,true),null),
            Binding(CTRL+G,
                      ,,true),null),
                      ,,true),null),
                      LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllReferencesAction@16b1b61)),
                      ,,true),null),
                      ,,true),null),
            !SESSION 2011-02-24 22:28:43.609 -----------------------------------------------
            !ENTRY org.eclipse.jface 2 0 2011-02-24 22:30:06.562
            !SUBENTRY 1 org.eclipse.jface 2 0 2011-02-24 22:30:06.562
            Binding(CTRL+G,
                      ,,true),null),
            Binding(CTRL+G,
                      LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllDeclarationsAction@1731b2f)),
                      ,,true),null),
            Binding(CTRL+G,
                      ,,true),null),
                      ,,true),null),
                      LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllReferencesAction@1fdc405)),
                      ,,true),null),
                      ,,true),null),
