5 Replies Latest reply on Feb 26, 2011 1:47 PM by kglad
    Making a zoomable comic
    undesignuk Level 1
      I am trying to make a comic by putting the comic in a movie clip called graphic_novel (also the instance name) but I want to have individual thumbnails in the comic zoomable so that if you hover over them then you get a further zoom into each thumbnail of the comic.
      So far I have the following actionscript on the main comic which also has a motion tween between frame 1 and 20 so that it zooms in or out over that amount of frames.
      The zoom works fine but I have tried numerous methods of creating invisible movie clip buttons over the individual thumbnails and tried to add similar actionscript to make a further zoom. Basically I want to navigate around the comic using zoom in zoom out.
      Any ideas?
      // whenever player enters frame, perform the actions between the curly brackets
      onClipEvent (load){
      _root.graphic_novel.onEnterFrame = function(){
      // if our zoom is "true", then previous frame (rewind)
      if(zoom == true){
      _root.graphic_novel.prevFrame();
      // when mouse is over this symbol, perform the actions between the curly brackets
      onClipEvent (load){
      _root.graphic_novel.onRollOver = function(){
      // sets zoom as false, contradicting our "if" statement above, so it plays our clip
      zoom = false;
      play();
      // when mouse is not over this symbol, perform the actions between the curly bracktes
      onClipEvent (load){
      _root.graphic_novel.onRollOut = function(){
      // sets zoom as true thus meeting the requirements of our "if" statement above
      // so it goes to the previous frame of our movie clip
      zoom = true;
        • 1. Re: Making a zoomable comic
          remove code from objects and delete those onClipEvent(load) lines.   then use the trace() function to see if you're detecting a rollover.
          • 2. Re: Making a zoomable comic
            undesignuk Level 1
            Thanks for your reply. The whole comic movie clip (called graphic_novel) with an instance name graphic_novel is working fine with that code above. It zooms in and out over 20 frames. The problem is when I add another movie clip on a separate layer of (as indicated by the slightly green button over the top of the policeman), I want it to zoom further to that clip and then I intend to set up all the individual thumbnails so that you can view them all in detail.
            I tried the following code on the green button (see below image) its doing something just not what I want it to do.
            onClipEvent (load){
            zoom = false;
            _root.graphic_novel.gotoAndPlay(21);
            onClipEvent (load){
            zoom = true;
            • 3. Re: Making a zoomable comic
              again, remove code from objects and delete those onClipEvent(load) lines.    then use the trace() function to see if you're detecting a rollover.
              • 4. Re: Making a zoomable comic
                undesignuk Level 1
                Hi
                Thanks for your reply,
                Just to be clear. Do you mean delete the code from the object (object action) and make it a frame action but also delete the onClipEvent (Load) lines then add a trace to see if anything is output when you roll over.
                thanks
                • 5. Re: Making a zoomable comic
                  yes
                  yes
                  yes
                  yes
