1 Reply Latest reply on Feb 25, 2011 8:04 AM by landar
    Update a single cell value in datagrid
    A.kameshwaran Level 1
           I want to update a single cell value in a datagrid, is this possible?
      here is the code from adobe for replaceItemAt example:
      my_dg.setSize(140, 100);
      my_dg.move(10, 40);
      replace_button.move(10, 10);
      // Set up sample data.
      var myDP_array:Array = new Array();
      myDP_array.push({name:"Clark", score:3135});
      myDP_array.push({name:"Bruce", score:403});
      myDP_array.push({name:"Peter", score:25});
      my_dg.dataProvider = myDP_array;
      // Create listener object.
      var buttonListener:Object = new Object();
      buttonListener.click = function(evt_obj:Object) {
      //Replace previous value
      var prevValue_obj:Object = my_dg.replaceItemAt(2, {name:"Frank", score:949});
      my_dg.selectedIndex = 2;
      // Add button listener.
      replace_button.addEventListener("click", buttonListener);
      what I want to do is just replace the score with out doing anything to the name
      Kameshwaran A.
        • 1. Re: Update a single cell value in datagrid
          I would think you could operate directly on the provider array and change only the score.
          Something like:
          myDP_array[index].score = newScore;
          You need to determine the "index" and supply the "newScore" number.
          You might have to refresh the dataGrid to show the new results by again setting the
