2 Replies Latest reply on Feb 25, 2011 7:47 AM by ArthurTheIgnorant
    Holding mouse down
      I currently have an issue where as I'd like to repeat an action when a user holds down their mouse button on one of the buttons within my application. At present, I'm using the following:
      button_left.onPress = function() {
           // action here
      This works but only executes the action once; it does not have the recurring effect I'm looking for. I've tried a few things in an attempt to get this working, one of which is below, but all have failed.
      var flag1 = false;
           flag1 = true;
           while(flag1==true) {
                // action
      button_left.onRelease = function() {
           flag1 = false;
      Thanks in advance for any help
        • 1. Re: Holding mouse down
          dtauer Level 2
          You want to use setInterval to do a repeated step. All you need to do is alter the rate at which it's called (i.e. a smaller number will run faster).  Here's the commented code:
          var id:Number;
               //Stop any existing intervals
               //Start a new interval.
               //The "doAction" function will be called at whatever rate you enter
               //Rate is in milliseconds (i.e. 1000 = 1 second)
               id = setInterval(doAction, 1000);
               //Stop the interval
          //When the interval is started, this function will be called
          //at whatever rate you've choosen
          function doAction():Void
          • 2. Re: Holding mouse down
            ArthurTheIgnorant Level 1
            Worked perfect and very well explained. Thanks very much!
