0 Replies Latest reply on Feb 25, 2011 6:54 PM by ben_reiv
    Invoking WCF service from Flex throws Error2032#
    ben_reiv
      I have  a WCF service which is working fine when I invoke it from .NET application.
      I can even test the service methods from WCFClientTest tool.
      But when I invoke this from Flex, it is throwing the error 2032
      Following are the issues I observed.
      1). The WSDL generated is having the local machinename [say webserver1] instead of the IP address.
      Here is what the issue is
      http://social.msdn.microsoft.com/forums/en-US/wcf/thread/7ed3f70e-1f65-49c1-b1e5-994f1691b e99
      Found couple of work arounds for this. One is to point it to a WSDL placed on the server as explained here
      http://www.codeproject.com/KB/webservices/WsdlDownloader.aspx?display=Print
      But even after fixing this, it is not working.
      2) When I compared the requests made from WCFClientTest tool and that from Flex[using wire shark], there is considerable difference in the way, the SOAP request is sent. WCFClientTest tool is making a SOAP xml file and sending it, but the Flex client is using a different format.
      Not sure whether Flex can call the WCF service the way .NET is doing.
      3) What is the best binding type I can use in the WCF config file?
      4) Is there any good articles I can refer to make this combination working?
      Any help is appreciated to make this combination working.
