2 Replies Latest reply on Jul 4, 2007 9:16 AM by Oliver Krylow
    Embed external .txt file
    Oliver Krylow Level 1
      Hello,
      trying to embed a external txt. file into my mxml file, which should be a rather easy task, I run into following problems:
      This is my AS Code :
      import flash.net.URLLoader;
      import flash.net.URLRequest;
      import flash.events.Event;
      var loader:URLLoader = new URLLoader();
      var request:URLRequest = new URLRequest("text.txt");
      loader.load(request);
      // "ggg" is EventHandler which loads external txt. file in TextArea with id = "textBox"
      loader.addEventListener(Event.COMPLETE, ggg);
      function ggg(event:Event):void
      textBox_txt.text = event.target.data;
      Now for "loader,request and ggg" it is giving me error #1120´which means "Access of undefined property _.".
      Since I distinctly remember declaring the variables loader and request and a function ggg, I do not understand why it is giving this error.
      I have tried this exact same code in the Flash CS3 environment and it worket just fine.
      So what is Flex trying to say to me ^^ ?
      Cheers, Oli
        • 1. Re: Embed external .txt file
          ntsiii Level 3
          You cannot do complex work outside of a function due to the way the mxml/as is compiled.
          Declare the variables at instance-level scope if you need that, but put all of the asignments in a function, say initApp(), that you call from the initialize or creationComplete event of the application.
          Tarcy
          • 2. Re: Embed external .txt file
            Hey Tarcy !
            Thank you a lot. I needed a while to understand what you were saying, but it is now making sense to me.
            Just in case somebody wants to know, this is how my code looks like now:
            <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="initApp()" >
            <mx:Script>
            <![CDATA[
            private function initApp():void
            private function ggg(event:Event):void
            </mx:Script>
            <mx:TextArea width="500" height="500" id="textBox_txt" editable="false" wordWrap="true"/>
            </mx:Application>
            It is working just fine!
            Bye, Oliver
