11 Replies Latest reply on Feb 27, 2011 3:33 PM by Stauffer Studios
    Video jerks
    Video Junky
      I have just upgraded to CS5 and 64bit Win7.  32MB RAM with 12 cores
      The video footage I have is from a Sony Z1U camera.
      The video bar in the timeline is yellow
      When i play back the footage in the timeline, the video continues to jerk every 10-15 seconds.  I am just wondering what could be causing this?  Surely Premiere is not taxing this system?
        • 1. Re: Video jerks
          rand42zhang
          I don't really think you should use 32MB RAM, use at least 2GB RAM.
          • 2. Re: Video jerks
            Harm Millaard Level 7
            It depends on your setup. If you take a look at the results page of the PPBM5 Benchmark you will notice that unbalanced systems perform badly, even with many cores.
            • 3. Re: Video jerks
              jeremy d. Level 3
              I'm going to guess that "32MB" is a typo. I think my phone has more than that.
              • 4. Re: Video jerks
                Stauffer Studios Level 1
                well, now that was silly.  Yes I meant to say 32GB but in reality I have 24GB instead.  It is an I7
                • 5. Re: Video jerks
                  the_wine_snob Level 9
                  Hey, don't feel badly, as when I saw the title of the post, I thought that you were talking about my acting debut...
                  • 6. Re: Video jerks
                    Yours is the first i7 I have heard of that contains duodeca cores. Maybe Intel would be surprised as well. Even the future releases after Q4 2011 do not go further than deca or octo cores.
                    Jerking is often caused by unbalanced systems, but unless we know the specifics of your system, it is only guessing.
                    • 7. Re: Video jerks
                      cvid01 Level 4
                      My guess it's an i7 with 6 cores with hyperthreading engaged. What might be helpful is how your hard drives are set up.
                      • 8. Re: Video jerks
                        OK Harm,
                        Here are all of the specifics
                        I have an I7 980 HexaCore Extreme
                        24GB DDR3-1333 RAM
                        Intel x58 Gigabit LAN (Sabertooth Motherboard)
                        1.5TB SATA 3Gbps Seagate 7200RPM C drive (Pagefile is on this drive)
                        nVidia Quadro 4000 2GB DDR5
                        4x 1.5GB SATA 3Gbps NCQ 32MB 7200 3TB Raid-10
                        Matrox MX02-MAX
                        Adobe CS5
                        Windows 7 64bit Pro
                        Using GPU for AME
                        Scratch Disks Same as Project
                        Project is DV NTSC
                        Source files are DV
                        Timeline is 32 minutes
                        No crazy effects, just straight up disolves
                        • 9. Re: Video jerks
                          Thanks for the details.
                          Is this a Matrox Project?
                          Have you updated CS5?
                          Do you have the latest Matrox drivers?
                          • 10. Re: Video jerks
                            Two possible suspects:
                            1. Matrox
                            2. Raid10 on the mobo.
                            Effectively you have two disks, C and the raid10 and the last one is not as fast as a two disk raid0. Two disks is the minimum requirement, so adding one would not be unwise.
                            • 11. Re: Video jerks
                              Harm,
                              Are you telling me that a Raid-10 is less performant that a Raid-0?  I thought a Raid-10 was a Raid 1 & 0.  I have 4 drives total.  2 for the Raid-0 and then 2 for the mirrors giving me a total of 3GB with a 3GB mirror.  I thought that was the best you could do.
                              Bill,
                              While I have Matrox, this particular project is not using it so no, it is not a Matrox project, however, yes the drivers are up to date.
                              This is a turnkey system I bought so everything came pre-configured.  There are times with it just hums and then there are times when just switching the export options takes up to 1 minute just to bring the dialog up.  It is very frustrating since I paid oodle gobs of money for this thing.
                              Harm,
                              I did the benchmark test and submitted my results.  I am not sure what will come of that.
                              My numbers were
                              "523","17","73","94" - Software
                              "523","17","73","10" - Hardware
                              Thank you both for responding.
                              My system has done an awful lot of crashing as well and I am not quite sure what to make of that but I have been working with Adobe on some of it.  I did manage to find a bug   I smile, because I found one, but at the same time I cry :'( because I found a bug and wanted to use the clock transition.  They have not yet given me a date as to when it will be fixed.
