11 Replies Latest reply: Mar 2, 2011 11:57 AM by Adam Cameron. RSS
    CF creating spurious variables
    Adam Cameron. Community Member
      G'day
      I hope the forums are in a good mood today, and will allow me to paste code in here.  Let's see...
      Could I ask y'all a favour?  Could you pls run this code on CF9, and let me know the results:
      <cfif structKeyExists(URL, "bung") AND URL.bung>
          <cfset st = {
              foo = "bar"
      <cfelse>
          <cfset st = structNew()>
          <cfset st.foo = "bar">
      </cfif>
      <cfloop item="sKey" collection="#variables#">
          VARIABLES.<cfoutput>#sKey#</cfoutput> found.  Value:<br />
          <cfdump var="#variables[sKey]#" label="#sKey#">
          <hr />
      </cfloop>
      <cfdump var="#variables#" label="variables">
      (contrast the results when passing ?bung=true and ?bung=false on the URL.
      We are seeing CF creating a spurious variable "___IMPLICITARRYSTRUCTVAR0" being created in the variables scope, when using {} notation for creating structs.
      This does not happen on CF8, but does happen on CF9 (9.0, 9.0.1, 9.0.1+CHF).
      It only happens when the code is in a CFM file; not a CFC file.
      It's "interesting" that Adobe are suppressing the output of this variable in CFDUMP.
      Adam
        • 1. Re: CF creating spurious variables
          BKBK Community Member
          This is the result without query-string or when the query-string is ?bung=false.
          My ColdFusion build: 9.0.1.274733.
          Message was edited by: BKBK
          • 2. Re: CF creating spurious variables
            Now with query-string ?bung=true
            • 3. Re: CF creating spurious variables
              Thanks.  That's what we're seeing too.  I know of one person who is not seeing this though.  Weird.
              Adam
              • 5. Re: CF creating spurious variables
                Peculair find, indeed. A Google search revealed just one instance of the term IMPLICITARRYSTRUCTVAR0 on the web.
                • 6. Re: CF creating spurious variables
                  What's even more interesting is that when I googled "___IMPLICITARRYSTRUCTVAR0" the other day... nothing came back.  Now Ben's article; and... very quick of google indeed: this thread; a mirror of this thread; and another coupla mentions of it too.
                  Adam
                  • 7. Re: CF creating spurious variables
                    Clearly a bug. I have been able to reproduce it -- always! (Note, however, my CF version above.)
                    I have learned something new from this exercise. I never realized until now that <cfloop item="myKey" collection="#myCollection#"> adds myKey to the variables scope!
                    The IMPLICITARRYSTRUCTVAR0 never occurs when you use this code:
                    <cfset st.foo1 = "foo1">
                    <cfset st.foo2 = "foo2">
                        Key:<cfoutput>#sKey#</cfoutput><br>
                      <cfdump var="#variables#">
                    <hr />
                    </cfloop>
                    <cfset st = {foo1 = "foo1", foo2 = "foo2"}>
                    <cfloop item="sKey" collection="#st#">
                    <hr />
                    </cfloop>
                    However, the IMPLICITARRYSTRUCTVAR0 always occurs when you use this code:
                    <hr />
                    </cfloop>
                    Apparently, when you use the new curly-bracket notation for structs and you loop through the variables structure, ColdFusion adds the extra key IMPLICITARRYSTRUCTVAR0 to the variables structure.
                    • 8. Re: CF creating spurious variables
                      Yeah - re the cfloop/item thing - it's not some sneaky iterator or anything: it's literally just a string holding the key name for each key in turn. It's like doing a list-loop over a structKeyList().
                      Adam
                      • 9. Re: CF creating spurious variables
                        Oh yeah, forgot to say. I don't think it's anything to do with the loop, per se.  I'm on a train to the pub to watch England v France (Six Nations), so cannae check, but you should just be able to do this:
                        st = {};
                        writeOutput(structKeyExists(variables, "___IMPLICITARRYSTRUCTVAR0");
                        Adam
                        • 10. Re: CF creating spurious variables
                          st = {};
                          Say what? Computer says yes! Nice counterexample!
                          Gets me thinking perhaps Javaman forgot to take out the placeholder for index 0 after the design phase. The code
                          <cfset st = {}>
                          <cfoutput>
                          structKeyList(variables): #structKeyList(variables)#<br>
                          isDefined("variables.___IMPLICITARRYSTRUCTVAR0"): #isDefined("variables.___IMPLICITARRYSTRUCTVAR0")#
                          </cfoutput>
                          gives the result
                          structKeyList(variables):  ___IMPLICITARRYSTRUCTVAR0,ST
                          isDefined("variables.___IMPLICITARRYSTRUCTVAR0"):  YES
                          But then again, the variable ___IMPLICITARRYSTRUCTVAR0 is nowhere to be found in <cfdump var="#variables#">
                          • 11. Re: CF creating spurious variables
                            Yeah. Sadly I think they have put specific code into dump.cfm to suppress output of that variable.
                            One would think that of they were going to those lengths, their time might be better spent simply fixing the issue instead.
                            Oh well: the bug is logged. Very little of our code needs refactoring to avoid this, so I'm not that fussed.
                            Adam
