25 Replies Latest reply on Mar 1, 2011 9:18 AM by the_wine_snob
    juddering after burning
    cheesysmegs
      Guys, this has probably been covered, but bear with me
      using premiere elements 7
      copied vob files from dvd min discs into organizer
      made my video and looks great in sceneline/timeline
      burnt to dvd and the pan shots are all juddery
      is there a solution?
      do i have to convert files from vob, elements
      recognized them and had no trouble getting them
      into the organizer
        • 1. Re: juddering after burning
          Sometimes you do have to convert VOBs to DV-AVIs.
          But most of the time you don't, if you choose the proper project preset.
          When you start your new Premiere Elements project, make sure you click Settings and select the preset for a Hard Disk Camcorder, standard definition. This will automatically reverse the field dominance of your video so you don't get the "juddering".
          This is one of the many tips in my books, by the way -- just in case you want to nip some of the other potential problems in the bud.
          • 2. Re: juddering after burning
            the_wine_snob Level 9
            This could be a Field Reversal issue, as one can get some awful footage, if, for instance, the source material is LFF (Lower Field First), and then they output to an UFF (Upper Field First) format. What is the Field Order of the mini-DVD? A standard DVD is UFF.
            For some tips on working with DVD material, this ARTICLE might be useful.
            • 3. Re: juddering after burning
              cheesysmegs Level 1
              Thanks Bill, this was recorded and finalised in the camcorder, im a bit of
              a novice doing this, tried to look at the properties of the vob file but
              couldn't determine what the field order is, i'll try what the other guy
              suggested and change the settings before i get media from the disc and do the
              project again, it took me all day, but now im comfortable with the editing it
              shouldn't take me as long
              thanks for your help
              Dave
              In a message dated 26/02/2011 15:51:54 GMT Standard Time, forums@adobe.com
              writes:
              http://forums.adobe.com/message/2117743#2117743 might be  useful.
              Good  luck,
              • 4. Re: juddering after burning
                Are you saying your video was shot on a DVD camcorder?
                • 5. Re: juddering after burning
                  cheesysmegs Level 1
                  yes Steve, i had to borrow a sony handycam which records onto mini dvd
                  discs, i gave the handycam back
                  when my camcorder was fixed.
                  so i have 7 little discs that i put in my d drive and elements finds
                  them and puts them in the
                  organiser, as i said it looks great in the timeline and i can do all
                  the editing and it burns
                  abt 4.2 gb of a normal -r dvd disc, but the panned shots are all
                  juddery and sometimes have
                  two images, i only copy the major vob files (not the smaller scenes
                  type files)
                  one thing that did happen was a couple of discs got corrupted and i
                  managed to download a programme
                  that saved the majority of the data, those seem to be ok on the burned
                  disc (they were saved as mpg files)
                  i did try renaming the vobs to mpg when i tried to edit in movie maker,
                  but they came out wierd.
                  would it make sense (as elements seemed to work well with the repaired
                  mpgs, but i dont know
                  if the repair programme also recoded the files and i dont know if just
                  renamed the vobs
                  will have the same effect, shall i still try changing the settings
                  before i start this project again?
                  appreciate your help
                  Dave
                  • 6. Re: juddering after burning
                    Dave,
                    While this sounds like a possible Field Reversal issue, there is also the problem of having MPEG-2 material to start with, and then doing a second MPEG-2 compression. This can get to be like a FAX of a FAX, or a JPEG, Saved as another JPEG. Quality (especially off-axis motion, either camera, or subject) goes downhill quickly.
                    Also, what brand of blank media are you using? They are NOT created equal, and some just do a very poor job with playback. Memorex is about as bad as it gets, and Verbatim is about as good as it gets.
                    • 7. Re: juddering after burning
                      Bill and I are saying the same thing then.
                      If you use the project settings I described in the first post, all will be well.
                      • 8. Re: juddering after burning
                        cheesysmegs Level 1
                        Thanks guys, its 9am on Sunday morning and i'm starting the project  again!!
                        Wish me luck and i'll let you know how I get on
                        Dave
                        In a message dated 26/02/2011 23:38:14 GMT Standard Time, forums@adobe.com
                        writes:
                        well.
                        • 9. Re: juddering after burning
                          Dave,
                          My fingers are X'ed for you here in sunny, but cold AZ.
                          Let us know how well the Project goes.
                          • 10. Re: juddering after burning
                            cheesysmegs Level 1
                            Sorry guys, but if anything this finished dvd is worse then the previous
                            one!!
                            Anyhow, a couple of questions for you
                            1. As the damaged vob files that were recoded to mpg have come out ok, can
                            my edited vobs be recoded before burning?
                            2. If not and I have to recode all the vob files to mpg, can you recommend
                            a good programme that will not lose any of the original quality of the  vobs
                            thanks again
                            Dave
                            In a message dated 27/02/2011 15:00:55 GMT Standard Time, forums@adobe.com
                            writes:
                            Dave,
                            Good  luck,
                            • 11. Re: juddering after burning
                              cheesysmegs Level 1
                              One last thing, as vobs are being copied direct from a dvd drive,
                              would it help if i copied them to my desktop first?
                              One day i will get this project finished!!
                              Dave
                              writes:
                              Dave,
                              Good  luck,
                              • 12. Re: juddering after burning
                                It makes no difference.
                                But if you put the DVD in your computer's drive and then use Get Media/From DVD, you'll be sure that the program will import the files as they should be imported into your project.
                                • 13. Re: juddering after burning
                                  cheesysmegs Level 1
                                  Ok, it would seem that i need to convert the vobs to mpg as the damaged
                                  ones
                                  that i passed through the programme videoredo have come out fine
                                  I wouldnt normally bother by now, but this was recorded on my 50th
                                  birthday in Barbados.
                                  Thanks for all your help Steve
                                  • 14. Re: juddering after burning
                                    Dave,
                                    Copying to the HDD, into a folder just for them, is the best method. The Desktop is a special folder, with some differences between it, and other folders. PrE does not do something correctly, when working with the Desktop folder. Just use a regular folder, created just for the VOB's. That is as good as it gets.
                                    • 15. Re: juddering after burning
                                      cheesysmegs Level 1
                                      Thanks  Bill, like I said i had three damaged discs and used videorecode
                                      and it saved most of the data to a mpg file.
                                      Now when i finished the project and burnt it, only those files came out
                                      without any pan juddering, so I still have about a week left on my free
                                      trial and plan to do this.
                                      use videoredo using the quickstream fix to convert vobs to mpg
                                      and place in a folder named Barbados on my desktop
                                      Then build my dvd (should be able to do it blindfolded by now!!)
                                      then place it in my dvd and close my eyes!!
                                      When i start my project what settings should i use?
                                      thanks
                                      Dave
                                      • 16. Re: juddering after burning
                                        Dave,
                                        I would locate that Barbados folder somewhere else, perhaps in the Project's folder structure, and keep that special Desktop folder out of the mix. Many have had issues with both PrE and PrPro, when the Desktop folder is in use for Assets, or as a destination folder for Export.
                                        Good luck, and hope that things work fine.
                                        PS - Please note that if you are using the trial, the output will be watermarked with "Produced in PrE Trial," or simliar syntax. It will NOT be useful to deliver. Just want to make sure that you are aware of the watermark.
                                        • 17. Re: juddering after burning
                                          cheesysmegs Level 1
                                          Bill, i have a bought Premiere Elements
                                          i used videorecode to retrieve the damaged
                                          data from three of my discs and used
                                          them in my project (it converted them mpg)
                                          when i burnt it, those were the only clips that didnt judder
                                          on the pan shots.
                                          so theoretically if i run all my dvd discs through
                                          viedorecode ( i have about a week left of a fully
                                          functioning trial) then my project should beok
                                          but before istart my new project, what do i need
                                          to preset it at, as Steve suggested before
                                          Hard Disk Camcorder, standard definition,
                                          i guess that should be different now
                                          thanks
                                          Dave
                                          • 18. Re: juddering after burning
                                            Dave,
                                            With MPEG-2 footage, the Preset would still be just as Steve outlined.
                                            • 19. Re: juddering after burning
                                              cheesysmegs Level 1
                                              cool, let you guys know how i get on
                                              • 20. Re: juddering after burning
                                                cheesysmegs Level 1
                                                Yeehaa, all done, thanks to Bill and Steve for your imput, for anyone else
                                                that have
                                                these damned dvd mini discs and want to use the superb Premiere Elements to
                                                edit
                                                heres what i did
                                                downloaded videoredo plus
                                                ran each disc through quickstream fix (this will also retrieve as much good
                                                data as possible from any damaged discs) and copied only the vob vts files
                                                to a  separate folder on my desktop, for ease of compiling
                                                in date order, i renamed them 1,2,3 etc and when i got to 9 made them 9a,b
                                                etc as double figures gets
                                                put to the top of the edit list
                                                ran premiere elements and got media from this folder
                                                did the editing and burnt, job done
                                                thanks again guys
                                                Dave
                                                In a message dated 28/02/2011 16:31:13 GMT Standard Time, forums@adobe.com
                                                writes:
                                                Dave,
                                                Good  luck,
                                                • 21. Re: juddering after burning
                                                  Great news Dave, and glad that you got it working for you.
                                                  As for the file naming, use the computer convention of  01 thru 09, and then 10 thru XX, and the files will line up, as you wish.
                                                  • 22. Re: juddering after burning
                                                    cheesysmegs Level 1
                                                    Thanks Bill, one last thing, whats the best method of getting say 3
                                                    copies of my project?
                                                    copy the one I have burnt or burn more from the project in Elements?
                                                    regards
                                                    Dave
                                                    • 23. Re: juddering after burning
                                                      Dave,
                                                      Do mean "copies" of your completed DVD?
                                                      If so, here are some methods, and the one that you choose, might be related to what you have done already:
                                                      • Initially, Burn to Folder from PrE, and then use a burning utility, like the free ImgBurn, to do physical burns to disc. With ImgBurn, you can set the quantity that you need, and just fee blank discs into the burner.
                                                      • If you already have a perfect DVD, use ImgBurn, or similar, to Copy DVD. This works great, if you have two burners on your computer, as you just put your "source disc" into one, and the "destination disc," the blank media into the other burner. Again, you can set the quantity.
                                                      • If you only have one burner, you can still Copy DVD, but there will be a little more time involved, as first ImgBurn will Copy the VIDEO_TS folder and all the files to your HDD (you can set where this will happen, and it's best to choose a fast HDD w/ plenty of defragmented free space), and then it will just burn that VIDEO_TS folder to your blank media. This is pretty much the same as if you did the Burn to Folder above, and you can also set the quantity.
                                                      • You can Burn to Disc from PrE, but I believe that you will then be doing the Transcoding again, and again, thus taking quite a bit more time. I do not use PrE for authoring, or burning, so am not positive. In my authoring program, Encore, I set the quantity of disc, and the program Transcodes once, then quickly does the burns, per my settings.
                                                      Here are a couple of tips:
                                                      • Use only high-quality blank media, like Verbatim, or Taiyo-Yuden. Sony and Falcon Pro get high marks too.
                                                      • In PrE, one does not have the ability to adjust burn speed, like when using ImgBurn, or Encore, and the burn speed is derived from the fastest possible, given the blank media and the burner. For this reason, I would choose slower media. Note: with ImgBurn, you CAN set the burn speed, and I drop that down to about half of the max.
                                                      • Before doing any quantity, first burn to a Rewritable (RW) disc, and test in several different players. Look very closely for mis-spellings, or any glitches. Do NOT use RW for delivery. It is ONLY for testing purposes, and will save creating "coaster" from a Project, with the main character's name mis-spelled on the opening title...
                                                      Here is where you can download ImgBurn.
                                                      Good luck, and happy authoring,
                                                      • 24. Re: juddering after burning
                                                        cheesysmegs Level 1
                                                        Thanks Bill, didnt occur to me to burn outside the programme, thats why
                                                        these
                                                        forums are so helpful
                                                        thanks again, you and Steve have been a blessing!!
                                                        Dave
                                                        • 25. Re: juddering after burning
                                                          Dave,
                                                          You are most welcome. One of the beauties of this forum is that one can "think outside the program," where necessary.
                                                          I have learned many great tips, like using ClipMate (3rd party Clipboard Extender) to Copy/Paste from one Project to another - I had no idea that there was a way to do that, until I read about it here.
