1 Reply Latest reply on Feb 27, 2011 1:32 AM by Mylenium
    Using Adobe After Effects CS5- Trouble with Echo & 3D Camera
    j_hyrkas@hotmail.com
      Hi
      i'm using Effects CS5 to a create a set of superman esque titles implementing the method found in the link below
      www://vimeo.com/6562241
      Everything goes smootlhy until i try making additional changes to the animation.
      Here's my problem, since this process requires echo to achieve the effect. I try and set an independant camera motion from the text as it extrudes outward. But...once the text begins its animation and the camera starts to move the echo or the extrusion is ALWAYS...ALWAYS altered by the camera. (The path of the echo is follows the path of the camera.) Whether it's in a x, y, or z path it still occurs.
      Sure i can change the camera angle and view it from a different perspective stationary, but i can't get them to move independant paths from each other without thecho being altered as well.
      IF ANYONE OUT THERE IS A WIZ AT ADOBE AFTER EFFECTS PLEASE PLEASE RESPOND
