1 Reply Latest reply on Feb 26, 2011 11:13 AM by Frustrated in AZ
    What is Explorer?
    @Terri Brodie@
      Hi All
      I wonder if you can help me? I recently bought an eReader, the website I bought the eBooks from suggested that I download ADE to read the eBooks. I have spent all day trying to make it work but have now heard that the eReader I have is not compatible with ADE but is with Explorer, does anyone know what this means? Also does this mean that the eBooks I bought are useless as they only work with ADE??? Any info you have would be a great help as I have no idea what I'm doing!! Thank you.
      Terri.
        • 1. Re: What is Explorer?
          Level 4
          Terry, there's a process you can follow that should work and it's not going
          to cause you grief.  It should take about 20 minutes.
          I can give you generic steps to follow because you haven't given enough
          information in this message to give you specific steps.
          I have to assume that you have a PC, not a Macintosh computer, and that it
          is running Windows.  There are several versions of Windows, and the latest
          version is Windows 7.  The earliest versions of Windows that you should have
          to make this process work is Windows Vista or Windows XP.
          I don't know what type of eReader you bought either.  So, for now, let's
          deal with getting ADE running and getting the eBooks you purchased into
          ADE.  That way you can read the eBooks on your computer until you get the
          eReader sorted out.
          You got here somehow, so I assume that you're familiar with how software
          works, and you've visited the Adobe.com site.  But, just to be sure, let me
          start as if you came to the blog from ADE itself.  I'm not talking down to
          you - I just want to put the sequence together so that you can pick it up
          where it's appropriate for you.
          First, you have to have an account established with Adobe Systems.  That's
          easy: just point your browser to www.adobe.com and register as a user.  You
          don't have to pay anything to do this, but it is key in getting ADE
          working.  Sign off of adobe.com.
          Next, either you or someone else needs to find out where your eBooks are
          located on your computer.  You need to copy them to a 'safe' area somewhere
          on it, because you'll be fiddling with the ADE software and don't want to
          delete them accidentally.
          Then, uninstall/delete the ADE application.  Send everything to the Trash -
          and then EMPTY THE TRASH.  If you don't do this, when you reinstall ADE (the
          next step), it can pick up files from the previous installation - and those
          files may be corrupted.
          Log in to Adobe.com with your User ID and password.  This is important,
          because ADE is going to record your User ID as part of its authentication
          when you go to install it again.  Then, go to the Home page, and type
          "digital" into the Search box in the upper left of the screen.  A drop-down
          box will contain Adobe Digital Editions, and you click on it.  When you do,
          the upper left side will have two embedded links: 'Download Now' and 'Get
          Support'.  Click on 'Download Now' and the download/installation process
          will take over.  I know you've done this before, but I am assuming that when
          you did, you were not logged into Adobe.com.
          When the process is complete, you can open ADE and, in Library mode, you can
          click on the down arrow next to the word 'Library'.  That will drop down a
          menu, and you pick 'Add Item To Library'.  That will open a window, asking
          you to give ADE the information on where to find the item and its name.  You
          can browse your drive and point at the location of your ebooks, then click
          on the name when it's on the screen, and it will appear in the line below.
          Click on OK, and ADE will do the rest.  Repeat as necessary to get the
          ebooks into your library.  You can open the books and read them using ADE,
          once they're in the Library, by clicking on the icon in Library view.
          Now, about that eReader: what kind is it,  and who makes it?
          Hope this helps!
          Tom (Frustrated in AZ)
