5 Replies Latest reply on Mar 29, 2018 2:16 AM by HussainMe
    pdf form conditional checkboxes
    jacjohnston Level 1
      Hi.
      I'm building a pdf form in Acrobat 8 Professional. I want to add JavaScript to 3 checkboxes to achieve the following:
      if checkbox 1 or 2 is checked, uncheck checkbox 3; and if checkbox 3 is checked uncheck both 1 and 2.
      It seems straightforward, but I have not been able to find a solution either in the Acrobat guide nor online. I have no experience in Javascript other than copying and pasting, so I'm not sure I'm using the right language to search. If anyone can provide any guidance, I would greatly appreciate it.
      Thanks a lot!
        • 1. Re: pdf form conditional checkboxes
          George_Johnson MVP & Adobe Community Professional
          You could create a function in a document-level JavaScript and call it in the Mouse Up event of each check box, something like:
          // Document-level function
          function cbControl() {
              // Get a reference to each check box
              var f1 = getField("cb1");
              var f2 = getField("cb2");
              var f3 = getField("cb3");
              // Uncheck cb3 if cb1 or cb2 was selected/deselected
              if (event.target === f1 || event.target === f2) {
                  f3.value = "Off";
                  return;
              // Uncheck cb1 and cb2 if cb3 was selected/deselected
              if (event.target === f3) {
                  f1.value = "Off";
                  f2.value = "Off";
          Change "cb1", "cb2", "cb3" to the names of the check boxes you're using.
          Here's the code for each check box's Mouse Up event:
          cbControl();
          • 2. Re: pdf form conditional checkboxes
            jacjohnston Level 1
            OMG!!!!   Who are you?!   It works perfectly -- you are amazing.   Thank you so so so much!   I was expecting many more hours of agonizing over this -- I can't thank you enough!!!
            • 4. Re: pdf form conditional checkboxes
              fd6 Level 1
              Well, a little bit late but thanks for this anyway. Very helpful.
              I've another question related to this matter. How can I make polish this code and apply to various groups of checkboxes without creating an endless list of variables?
              function Caselles()
                  var f1 = getField("C1");
                  var f2 = getField("C2");
                  var f3 = getField("C3");
                  var f4 = getField("C4");
                  var f5 = getField("C5");
                  // Uncheck c2, c3 and c4 if c1 was selected/deselected
                  if (event.target === f1) {
                      f2.value = "Off";
                      f3.value = "Off";
                      f4.value = "Off";
                  // Uncheck c3 and c4 and check c1 when c2 was selected/deselected
                  if (event.target === f2) {
                      f1.checkThisBox(0,true);
                      f3.value = "Off";
                      f4.value = "Off";
                  // Uncheck c4 and check c1 and c2 when c3 was selected/deselected
                        f2.checkThisBox(0,true);
                        f4.value = "Off";
                  // Check all when c4 was selected/deselected
                   if (event.target === f4) {
                        f3.checkThisBox(0,true);
              Thanks in advance!
              • 5. Re: pdf form conditional checkboxes
                HussainMe Level 1
                This seems not working on acrobat dc?
