5 Replies Latest reply on Mar 9, 2011 9:25 AM by _durin_
    Crashes when in multitrack...
    biribibi Level 1
      Hi all!
      I am experiencing continuous crashes with AA4 when try to record in multitrack. I'm using RME Fireface 800, 8 mics., at 96*24. I also noticed the tracks are not syncronized and the recording is not precise (contains many jumps). Any suggestions?
        • 1. Re: Crashes when in multitrack...
          biribibi Level 1
          A very strange thing is that when I lauch Audition it changes the setup of the Fireface (from 96 to 192)... Recording stops and when listening to them they contain clicks. Very often the software crashes... any help?
          I have a MacBook Pro 2.3 GHz.
          • 2. Re: Crashes when in multitrack...
            _durin_ Adobe Employee
            I would first verify that the default Sample Rate in Audition matches your device.  Enter Preferences > Audio Hardware and adjust the "Sample Rate" dropdown at the bottom of this display.
            As a test, I would be curious if you experience these problems when recording at 44K or 48K.
            • 3. Re: Crashes when in multitrack...
              biribibi Level 1
              Autoresponder / Risposta automatica
              This email is not yet available. Please re-email at: / Questo email non è più disponibile. Per favore riscrivere a:
              studio (at) onclassical (dot) com
              Sorry for the inconvenience / Ci scusiamo per il disturbo.
              The staff of onclassical.com
              http://onclassical.com/texts/contacts.htm
              This message is encoded by ISO8859-1
              • 4. Re: Crashes when in multitrack...
                You may have read this in other discussions on this board, but we were able to isolate a few issues where Audition might drop off or suffer other issues while recording in multitrack, most noticeable at higher sample rates such as you were using.  These issues have been resolved and multitrack recording should be far more stable and reliable when Audition is officially released.  I hope you'll consider downloading the 30-day free trial when it becomes available and let us know if the problem you've experienced has been fixed.
                Durin
                • 5. Re: Crashes when in multitrack...
                  biribibi Level 1
