3 Replies Latest reply on Mar 1, 2011 12:29 PM by JimHess-ra2Osl
    .dng or .nef files preview
    gac1957 Level 1
      I just installed CS5 master collection trial version and also installed DNG convertion. Camera raw is also up to date.
      After dowloading files from D200 camera, I can not preview either .nef or converted .dng files using Bridge. I also tried purging camera raw and Bridge files with same results.
      Any suggestions? I'm following Scott Kelby's Adobe Photoshop CS5 book but my version seems to be corrupted or there is any missing parameter or option.
      I spent a lot of time searching in internet.
      Thanks in advance.
        • 1. Re: .dng or .nef files preview
          JimHess-ra2Osl Level 3
          What can you see? Are there gray squares, or what. If you are seeing just gray squares it could be a corrupted monitor profile. Try switching to an sRGB profile and see if that fixes the problem. Otherwise, I have no idea. Perhaps others will be of help.
          Just another thought. Are you sure Camera Raw installed? In Photoshop, go to Help/about Plug-Ins and click on Camera Raw. It should display a dialog indicating what version of Camera Raw is installed. If you just installed the master collection, then you probably have version 6.0, and you should upgrade to 6.3. However, the D200 should be supported, and you should be able to see your raw images if Camera Raw is properly installed.
          • 2. Re: .dng or .nef files preview
            gac1957 Level 1
            Hi Jim,
            1. I see, instead of thumbnail, a white square with NEF letters on blue background on left upper corner.
            2. Camera raw plug-in is 6.3.0.79
            • 3. Re: .dng or .nef files preview
              What is your operating system?
              What is the exact path to where Camera Raw is installed?
              Is there more than one version of Camera Raw on your system?
