This content has been marked as final.
Show 3 replies
1. Re: Version Adobe CS, type tool won't work even tho worked before
Noel Carboni Feb 28, 2011 11:30 AM (in response to sheana2002)Does the cursor move as you type each character?
Just some possibilities...
- Very small type on a very zoomed-out image?
- Extreme or uncommon settings in the Character palette?
- Corrupted font?
- Recent video driver update via Windows Update that broke type handling?
Try a Reset of the Text tool by making the Character palette visible (Window - Character), then clicking the little menu button at the upper-right corner, then choosing Reset Character.
Try again with a different font.
Double check that your video driver is up to date with the web site of the maker of your video card.
-Noel
2. Re: Version Adobe CS, type tool won't work even tho worked before
Bill Hunt Feb 28, 2011 3:50 PM (in response to Noel Carboni)Noel,
Add white Type on a white background (match up the color of choice), and then get the MOD's to make this a sticky, as it comes up about once per week.
@OP, do these suggestions solve your issue, or is something else going on? [Do not forget Reset Tool.]
3. Re: Version Adobe CS, type tool won't work even tho worked before
sheana2002 Mar 1, 2011 3:43 AM (in response to Noel Carboni)A reset of the tool fixed the problem! Thanks so much.
