4 Replies Latest reply on Feb 28, 2011 7:28 PM by emerson_rm
    Problem to create dynamic DataGrid with ItemRenderer
    emerson_rm Level 1
      I´ve been working in a project whose the purpose is create dynamic DataGrids.
      So, in runtime the keyuser fill in a form how many rows and columns he wants. After that, a function create a DataGrid (like a two dimensional arrays).
      The problem is:
      I need to use a Componente inside a DataGridColumn.
      So I use ItemRenderer, but, how I send a ArrayCollection value to the ItemRenderer?????
      Follow the code:
           /* Define rowcount based of total row number informed */
           dataGrid.rowCount = row;
           cols = new Array();
           for(i = 0; i <= col; i++){
                dgc = new DataGridColumn(i.toString());
                dgc.dataField = ("col_" + i);
                dgc.itemRenderer = new ClassFactory(MyComponent);
                cols.push(dgc);
           dataGrid.columns = cols;
           /* Create the array with de values of the cells */
           arrayRubrica = new ArrayCollection();
           for(i = 0; i < row; i++){
                objeto = new Object();
                for(x = 0; x <= col; x++){
                     objeto["col_" + x] = "TEST-TEST-TEST";
                arrayRubrica.addItem(objeto);
      How I get the value of "col_x" inside Component of ItemRenderer????
      Let me know if you nedd any further info.
      Tks
        • 1. Re: Problem to create dynamic DataGrid with ItemRenderer
          Darrell Loverin Level 4
          Did you assign the ArrayCollection to the DataGrid's dataProvider property?
          -Darrell
          • 2. Re: Problem to create dynamic DataGrid with ItemRenderer
            emerson_rm Level 1
            Yes, the array is linked to the DataGrid.
            <mx:DataGrid id="dataGrid" dataProvider="{arrayRubrica}" width="100%" height="100%" />
            Any ideias?
            • 3. Re: Problem to create dynamic DataGrid with ItemRenderer
              Flex harUI Adobe Employee
              The entire object is the data property of the itemRenderer.
              • 4. Re: Problem to create dynamic DataGrid with ItemRenderer
                emerson_rm Level 1
                I got it!!!
                I used the ClassFactory class to solve the issue.
                First, I created a ClassFactory instance, later I used the propertie properties to send a value of Index Control to ItemRenderer.
                Inside the ItemRenderer, the value is manipulated with GET and SET and the main value was bindable in a Label component.
                Here´s the code:
                var i:int
                var dimensoesAvaliacaoCelulaItemRenderer:ClassFactory = new ClassFactory(dimensoesAvaliacaoCelula);
                dimensoesAvaliacaoCelulaItemRenderer.properties = { indiceCol:i };
                dgc.itemRenderer = dimensoesAvaliacaoCelulaItemRenderer;
                // The component <dimensoesAvaliacaoCelula>
                <mx:HBox xmlns:mx="http://www.adobe.com/2006/mxml" paddingLeft="5" paddingRight="5">
                     <mx:Script>
                          <![CDATA[
                               [Bindable] private var _indiceCol:int = 0;
                               public function get indiceCol():int {
                                    return this._indiceCol;
                               public function set indiceCol(_indiceCol:int):void {
                                    this._indiceCol = _indiceCol;
                     </mx:Script>
                     <mx:CheckBox id="dimensoesAvaliacaoCelulaCheckbox"/>
                     <mx:Label id="dimensoesAvaliacaoCelulaLabel" text="{data['col_' + _indiceCol]}"/>
                </mx:HBox>
                Tks.
                Emerson
