0 Replies Latest reply on Feb 28, 2011 7:10 AM by Skarbas
    Problem making 2 separate message sending in one app
    Skarbas
      I have made a simple application which should be a chat and some other text sending, but not to chat window.
      I have added netGroup.removeEventListener and added another EventListener with another handler, but still my messsage when submitting (not chatting) goes to chat window.
      Maybe somebody can tell why?
      What am I doing wrong?
      Already 2 weeks on the same spot!
      Tried the netStream.publish, but still with no luck.
      And I cannot find any examples on web.
      Any help would be appreciated.
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" width="100%" height="100%" applicationComplete="OnApplicationComplete()">
      <mx:Script>
      <![CDATA[
      private var netConnection:NetConnection = null;
      private var netStream:NetStream = null;
      private var netGroup:NetGroup = null;
      private var video:Video = null;
      private var sequenceNumber:uint = 0;
      private var resizeTimer:Timer = null;
      private var sendStream:NetStream;
      private var recvStream:NetStream;
      private const SERVER:String = "rtmfp://p2p.rtmfp.net/";
      [Bindable] private var connected:Boolean = false;
      [Bindable] private var joinedGroup:Boolean = false;
      private function OnApplicationComplete():void
      userName.text = "user " + int(Math.random() * 65536);
      groupName.text = "channel" + (int(Math.random() * 899) + 101);
      private function StatusMessage(msg:Object):void
      statusLog.text += msg;
      statusLog.verticalScrollPosition = statusLog.textHeight;
      statusLog.validateNow();
      public function NetStatusHandler2(event:NetStatusEvent):void{
      switch(event.info.code)
      case "NetGroup.Posting.Notify": // e.info.message, e.info.messageID
      postStream(event.info.score);
      break;
      private function NetStatusHandler(e:NetStatusEvent):void
      StatusMessage(e.info.code);
      switch(e.info.code)
      case "NetConnection.Connect.Success":
      OnConnect();
      break;
      case "NetConnection.Connect.Closed":
      case "NetConnection.Connect.Failed":
      case "NetConnection.Connect.Rejected":
      case "NetConnection.Connect.AppShutdown":
      case "NetConnection.Connect.InvalidApp":
      OnDisconnect();
      break;
      case "NetStream.Connect.Success": // e.info.stream
      OnNetStreamConnect();
      break;
      case "NetStream.Connect.Rejected": // e.info.stream
      case "NetStream.Connect.Failed": // e.info.stream
      DoDisconnect();
      break;
      case "NetGroup.Connect.Success": // e.info.group
      OnNetGroupConnect();
      break;
      case "NetGroup.Connect.Rejected": // e.info.group
      case "NetGroup.Connect.Failed": // e.info.group
      DoDisconnect();
      break;
      OnPosting(e.info.message);
      break;
      case "NetStream.MulticastStream.Reset":
      case "NetStream.Buffer.Full":
      case "NetGroup.SendTo.Notify": // e.info.message, e.info.from, e.info.fromLocal
      case "NetGroup.LocalCoverage.Notify": //
      case "NetGroup.Neighbor.Connect": // e.info.neighbor
      case "NetGroup.Neighbor.Disconnect": // e.info.neighbor
      case "NetGroup.MulticastStream.PublishNotify":// e.info.name
      case "NetGroup.MulticastStream.UnpublishNotify": // e.info.name
      case "NetGroup.Replication.Fetch.SendNotify": // e.info.index
      case "NetGroup.Replication.Fetch.Failed": // e.info.index
      case "NetGroup.Replication.Fetch.Result": // e.info.index, e.info.object
      case "NetGroup.Replication.Request": // e.info.index, e.info.requestID
      default:
      break;
      private function DoConnect():void
      StatusMessage("Connecting to \"" + SERVER + "\" ...\n");
      netConnection = new NetConnection();
      netConnection.addEventListener(NetStatusEvent.NET_STATUS, NetStatusHandler);
      netConnection.connect(SERVER);
      private function OnConnect():void
      var groupSpecifier:GroupSpecifier;
      StatusMessage("Connected\n");
      connected = true;
      groupSpecifier = new GroupSpecifier("max2009lab/" + groupName.text);
      groupSpecifier.multicastEnabled = true;
      groupSpecifier.postingEnabled = true;
      groupSpecifier.serverChannelEnabled = true;
      netStream = new NetStream(netConnection, groupSpecifier.groupspecWithAuthorizations());
      netStream.addEventListener(NetStatusEvent.NET_STATUS, NetStatusHandler);
      netGroup = new NetGroup(netConnection, groupSpecifier.groupspecWithAuthorizations());
      netGroup.addEventListener(NetStatusEvent.NET_STATUS, NetStatusHandler);
      StatusMessage("Join \"" + groupSpecifier.groupspecWithAuthorizations() + "\"\n");
      private function OnNetStreamConnect():void
      netStream.client = this;
      private function OnNetGroupConnect():void
      joinedGroup = true;
      private function DoDisconnect():void
      if(netConnection)
      netConnection.close();
      private function OnDisconnect():void
      StatusMessage("Disconnected\n");
      netConnection = null;
      netStream = null;
      netGroup = null;
      connected = false;
      joinedGroup = false;
      private function ClearChatText():void
      chatText.text = "";
      private function DoPost():void
      var message:Object = new Object;
      message.user = userName.text;
      message.text = chatText.text;
      message.sequence = sequenceNumber++;
      message.sender = netConnection.nearID;
      netGroup.post(message);
      StatusMessage("==> " + chatText.text + "\n");
      chatText.callLater(ClearChatText);
      private function OnPosting(message:Object):void
      StatusMessage("<" + message.user + "> " + message.text + "\n");
      public function doSubmit(): void {
      netGroup.removeEventListener(NetStatusEvent.NET_STATUS, NetStatusHandler);
      netGroup.addEventListener(NetStatusEvent.NET_STATUS, NetStatusHandler2);
      var message2:Object = new Object;
      message2.user = userName.text;
      message2.text = textInput.text;
      message2.sequence = sequenceNumber++;
      message2.sender = netConnection.nearID;
      netGroup.post(message2);
      public function postStream(message2:Object):void {
      remoteText.text += message2.text + "\n"
      netGroup.removeEventListener(NetStatusEvent.NET_STATUS, NetStatusHandler2);
      public function onPlayStatus(info:Object):void {}
      public function onMetaData(info:Object):void {}
      public function onCuePoint(info:Object):void {}
      public function onTextData(info:Object):void {}
      public function ValidateConnectAllowed(isConnected:Boolean, groupNameText:String):Boolean
      return (!isConnected) && (groupNameText.length > 0);
      </mx:Script>
      <mx:VBox top="10" right="10" left="10" bottom="10" verticalGap="6">
      <mx:HBox width="100%">
      <mx:Text text="Group:"/>
      <mx:TextInput id="groupName" width="100%" text="default" enabled="{!connected}"/>
      <mx:Button label="Connect" click="DoConnect()" enabled="{ValidateConnectAllowed(connected, groupName.text)}" />
      <mx:Button label="Disconnect" click="DoDisconnect()" enabled="{connected}" />
      </mx:HBox>
      <mx:HBox width="100%" horizontalAlign="center" height="100">
      <mx:TextArea id="ownText" height="92"/>
      <mx:TextArea id="remoteText" height="92"/>
      </mx:HBox>
      <mx:VBox height="54" width="651" horizontalAlign="center">
      <mx:TextArea id="textInput" height="22" enabled="{joinedGroup}" />
      <mx:Button label="Submit" click="doSubmit()" />
      </mx:VBox>
      <mx:TextInput id="userName" width="160" />
      <mx:TextInput id="chatText" width="405" enabled="{joinedGroup}" />
      <mx:Button label="Chat" click="DoPost()"/>
      </mx:HBox>
      <mx:TextArea id="statusLog" width="100%" height="93"/>
      </mx:VBox>
      </mx:Application>
