14 Replies Latest reply on Mar 11, 2011 12:49 PM by vito c
    Help Flash Builder Debugger Broken
    vito c Level 1
      I updated my java on mac os x the other day and it has pretty much destroyed my installed version of Flash Builder. I had Eclipse installed using the Plugin. Since the debugger wasn't working correctly I uninstalled everything and installed the stand alone version of Flash Builder just to see if I could get things running smoothly again. Unfortunately I had no luck. I posted on the Flexcoders forumns and was told to post here. I'm thinking if I download an older version of the Java JDK and try make my system use it things might return to normal? The way it is now is the debugger is completely fried even after a fresh install.
      Thanks.
      I am using Flash Builder Plugin Version 4.0.1 build 277662
      Eclipse 3.5.2.M20100211-1343
      Here is the Eclipse Error:
      Message:
      Problems occurred when invoking code from plug-in:
      "com.adobe.flexbuilder.debug".
      Exception Stack Trace:
      java.lang.NullPointerException
      at
      com.adobe.flexbuilder.debug.breakpoints.FlexLineBreakpoint.findSourceFiles(FlexL\
      ineBreakpoint.java:412)
      at
      com.adobe.flexbuilder.debug.breakpoints.FlexLineBreakpoint.instantiate(FlexLineB\
      reakpoint.java:465)
      at
      com.adobe.flexbuilder.debug.model.FlexDebugTarget.instantiateBreakpoint(FlexDebu\
      gTarget.java:1012)
      at
      com.adobe.flexbuilder.debug.model.FlexDebugTarget.access$4(FlexDebugTarget.java:\
      1006)
      at
      com.adobe.flexbuilder.debug.model.FlexDebugTarget$FdbThread.installDeferredBreak\
      points(FlexDebugTarget.java:637)
      at
      com.adobe.flexbuilder.debug.model.FlexDebugTarget$FdbThread.advanceStateMachine(\
      FlexDebugTarget.java:668)
      at
      com.adobe.flexbuilder.debug.model.FlexDebugTarget$FdbThread.access$7(FlexDebugTa\
      rget.java:642)
      at
      com.adobe.flexbuilder.debug.model.FlexDebugTarget$FdbThread$1.run(FlexDebugTarge\
      t.java:752)
      at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
      at
      com.adobe.flexbuilder.debug.model.FlexDebugTarget$FdbThread.eventLoop(FlexDebugT\
      arget.java:732)
      at
      com.adobe.flexbuilder.debug.model.FlexDebugTarget$FdbThread.run(FlexDebugTarget.\
      java:793)
      at java.lang.Thread.run(Thread.java:680)
      Session Data:
      eclipse.buildId=unknown
      java.version=1.6.0_22
      java.vendor=Apple Inc.
      BootLoader constants: OS=macosx, ARCH=x86, WS=carbon, NL=en_US
      Framework arguments: -product org.eclipse.epp.package.jee.product -keyring
      /Users/phoenixage/.eclipse_keyring -showlocation
      Command-line arguments: -os macosx -ws carbon -arch x86 -product
      org.eclipse.epp.package.jee.product -keyring /Users/phoenixage/.eclipse_keyring
      -showlocation
        • 1. Re: Help Flash Builder Debugger Broken
          C. Agruss (Adobe) Level 3
          What version of Java were you using previous to Apple's update?
          In some cases, Apple's updater will preserve earlier Java versions on disk, when updating the default to a newer version. Have you already tried using Apple's Java Preferences utility, generally available under /Applications/Utilities?  Be sure you have your 32-bit Java version listed above the 64-bit versions in the priority list.
          Or, if you have a Time Machine backup, maybe you could revert to the earlier Java version that way.
          -Chris
          • 2. Re: Help Flash Builder Debugger Broken
            vito c Level 1
            Before I updated my java I was using java 1.6 released from apple with the second update I believe. This was the third update they released and it's java 1.6_022 I think?
            Yah I have the 32 bit version above the 64 bit version.
            • 3. Re: Help Flash Builder Debugger Broken
              There's an alternate approach described here for changing the default Java version on OS X:
              http://hints.macworld.com/article.php?story=20060121171126988
              Switching versions that way is controversial, so please be sure to read the discussion comments down below the script, before deciding if this approach is appropriate for your situation.
              -Chris
              • 4. Re: Help Flash Builder Debugger Broken
                vito c Level 1
                Couldn't I just change the version of the JDK that flash builder is using?? I am really surprised nobody from adobe has commented on this problem.
                • 5. Re: Help Flash Builder Debugger Broken
                  vito c Level 1
                  I just reinstalled the opertaing system. That seems to have been the only solution. I did not try the script you provided because it was a few years old and I remember reading some where that apple hard changed some of the symbolic links for java inside the OS (from leopard to snow leopard). I wish apple would not release a java update if it's going to break applications....
                  • 6. Re: Help Flash Builder Debugger Broken
                    vito c Level 1
                    I still get the error with connecting to debugger after a clean install... maybe it's something left over in my workspace??? here is the java stack
                    !SESSION 2011-03-02 13:23:53.151 -----------------------------------------------
                    java.version=1.6.0_17
                    Framework arguments:  -product org.eclipse.epp.package.jee.product -keyring /Users/phoenixage/.eclipse_keyring -showlocation
                    Command-line arguments:  -os macosx -ws carbon -arch x86 -product org.eclipse.epp.package.jee.product -keyring /Users/phoenixage/.eclipse_keyring -showlocation
                    This is a continuation of log file /workspace/phoenixage/.metadata/.bak_5.log
                    Created Time: 2011-03-02 13:28:08.991
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:08.991
                    !MESSAGE Problems occurred when invoking code from plug-in: "com.adobe.flexbuilder.debug".
                    !STACK 0
                    at com.adobe.flexbuilder.debug.breakpoints.FlexLineBreakpoint.findSourceFiles(FlexLineBreakp oint.java:412)
                    at com.adobe.flexbuilder.debug.breakpoints.FlexLineBreakpoint.instantiate(FlexLineBreakpoint .java:465)
                    at com.adobe.flexbuilder.debug.model.FlexDebugTarget.instantiateBreakpoint(FlexDebugTarget.j ava:1012)
                    at com.adobe.flexbuilder.debug.model.FlexDebugTarget.access$4(FlexDebugTarget.java:1006)
                    at com.adobe.flexbuilder.debug.model.FlexDebugTarget$FdbThread.installDeferredBreakpoints(Fl exDebugTarget.java:637)
                    at com.adobe.flexbuilder.debug.model.FlexDebugTarget$FdbThread.advanceStateMachine(FlexDebug Target.java:668)
                    at com.adobe.flexbuilder.debug.model.FlexDebugTarget$FdbThread.access$7(FlexDebugTarget.java :642)
                    at com.adobe.flexbuilder.debug.model.FlexDebugTarget$FdbThread$1.run(FlexDebugTarget.java:75 2)
                    at com.adobe.flexbuilder.debug.model.FlexDebugTarget$FdbThread.eventLoop(FlexDebugTarget.jav a:732)
                    at com.adobe.flexbuilder.debug.model.FlexDebugTarget$FdbThread.run(FlexDebugTarget.java:793)
                    at java.lang.Thread.run(Thread.java:637)
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:08.991
                    !MESSAGE Error processing debugger commands
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:08.992
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:08.992
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:08.993
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:08.993
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:08.994
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:08.994
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:08.995
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:08.995
                    !STACK 0
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:08.996
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:08.996
                    !STACK 0
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:08.997
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:08.997
                    !STACK 0
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:08.998
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:08.998
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:08.999
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:08.999
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:09.000
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:09.000
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:09.001
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:09.001
                    !STACK 0
                    !STACK 0
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:09.005
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:09.005
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:09.006
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:09.006
                    !STACK 0
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:09.007
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:09.007
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:09.008
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:09.008
                    !STACK 0
                    !STACK 0
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:09.009
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:09.009
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:09.010
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:09.010
                    !STACK 0
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:09.011
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:09.011
                    !STACK 0
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:09.012
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:09.012
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:09.013
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:09.013
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:09.014
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:09.014
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:09.015
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:09.015
                    !STACK 0
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:09.016
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:09.016
                    !STACK 0
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:09.017
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:09.018
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:09.018
                    !STACK 0
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:09.019
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:09.019
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:09.023
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:09.023
                    !STACK 0
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:09.024
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:09.024
                    !STACK 0
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:09.025
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:09.026
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:09.026
                    !STACK 0
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.debug 4 2 2011-03-02 13:28:09.027
                    !STACK 0
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-03-02 13:28:09.027
                    !STACK 0
                    !SESSION 2011-03-02 13:33:09.670 -----------------------------------------------
                    !ENTRY org.eclipse.equinox.p2.repository 4 0 2011-03-02 13:33:11.811
                    !MESSAGE ProvisioningEventBus could not be obtained. Metadata caches may not be cleaned up properly.
                    !ENTRY org.eclipse.core.net 1 0 2011-03-02 13:33:44.404
                    !MESSAGE System property http.nonProxyHosts has been set to local|*.local|169.254/16|*.169.254/16 by an external source. This value will be overwritten using the values from the preferences
                    !ENTRY org.eclipse.ui.workbench 2 0 2011-03-02 13:33:50.915
                    !MESSAGE A handler conflict occurred.  This may disable some commands.
                    !SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-03-02 13:33:50.915
                    !MESSAGE Conflict for 'AUTOGEN:::org.eclipse.eclipsemonkey.emFileContextMenu/org.eclipse.eclipsemonkey.action4' :
                    HandlerActivation(commandId=AUTOGEN:::org.eclipse.eclipsemonkey.emFileContextMenu/org.ecli pse.eclipsemonkey.action4,
                    handler=ActionDelegateHandlerProxy(null,org.eclipse.eclipsemonkey.actions.PublishScriptFor Wiki),
                    expression=WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@f08d0f),sourc ePriority=16384)
                    !MESSAGE Conflict for 'AUTOGEN:::org.eclipse.eclipsemonkey.emFileContextMenu/org.eclipse.eclipsemonkey.action5' :
                    HandlerActivation(commandId=AUTOGEN:::org.eclipse.eclipsemonkey.emFileContextMenu/org.ecli pse.eclipsemonkey.action5,
                    handler=ActionDelegateHandlerProxy(null,org.eclipse.eclipsemonkey.actions.PublishScript),
                    !MESSAGE Conflict for 'AUTOGEN:::org.eclipse.eclipsemonkey.emFileContextMenu/org.eclipse.eclipsemonkey.action2' :
                    HandlerActivation(commandId=AUTOGEN:::org.eclipse.eclipsemonkey.emFileContextMenu/org.ecli pse.eclipsemonkey.action2,
                    handler=ActionDelegateHandlerProxy(null,org.eclipse.eclipsemonkey.actions.PublishScriptFor Blogger),
                    !MESSAGE Conflict for 'AUTOGEN:::org.eclipse.eclipsemonkey.emFileContextMenu/org.eclipse.eclipsemonkey.action6' :
                    HandlerActivation(commandId=AUTOGEN:::org.eclipse.eclipsemonkey.emFileContextMenu/org.ecli pse.eclipsemonkey.action6,
                    handler=ActionDelegateHandlerProxy(null,org.eclipse.eclipsemonkey.actions.PublishScriptFor Email),
                    !ENTRY org.eclipse.jface 2 0 2011-03-02 13:33:50.974
                    !MESSAGE Keybinding conflicts occurred.  They may interfere with normal accelerator operation.
                    !SUBENTRY 1 org.eclipse.jface 2 0 2011-03-02 13:33:50.974
                    !MESSAGE A conflict occurred for COMMAND+SHIFT+F12:
                    Binding(COMMAND+SHIFT+F12,
                    ParameterizedCommand(Command(org.eclipse.mylyn.tasks.ui.command.searchForTask,Search Repository for Task,
                    Category(org.eclipse.ui.category.navigate,Navigate,null,true),
                    ,,true),null),
                    org.eclipse.ui.defaultAcceleratorConfiguration,
                    org.eclipse.ui.contexts.window,,,system)
                    ParameterizedCommand(Command(com.adobe.flexbuilder.flashbridge.export.publish.movie,&Publi sh Movie,
                    Publish in Flash Professional,
                    Category(com.adobe.flexbuilder.flashbridge.flashProCommands,Flash Professional,null,true),
                    ,,true),null),
                    org.eclipse.ui.contexts.window,,carbon,system)
                    • 7. Re: Help Flash Builder Debugger Broken
                      vito c Level 1
                      I just reinstalled my operating system and created a new work space. I still get some errors when I am debugging my flash application. If I create a new application and debug on my local it works just fine. When I try to connect to my application that is sitting on our webserver the debugger just hangs right after the SWF is decrompressed (I can see that line in the debugger). Any thoughts?
                      • 8. Re: Help Flash Builder Debugger Broken
                        vito c Level 1
                        I tried safari and got better results than I was getting in firefox... I just got SecurityError: Error #2000: No active security context.
                        • 9. Re: Help Flash Builder Debugger Broken
                          vito c Level 1
                          So if I don't have any breakpoints set then my debugger will connect to the flash application otherwise if I have a break point set (just one in a different project). The appliction will stop. If I try to add a breakpoint while the debugger is running then I will get the original null pointer java error.
                          • 11. Re: Help Flash Builder Debugger Broken
                            vito c Level 1
                            Hi Chris, thanks for the effort but that's more just a post about where the java src is located in the newer version compared to the older version. Let me explain the problem a bit further as I have done some more testing.
                            When I create a new workspace and create a new project in the work space then add a breakpoint  everything works as expected. Then when I import a project that I downloaded via subeclipse I can no longer add breakpoints without getting an Eclipse Java Error. When I try to run a project with breakpoints set in it the app will just freeze until I remove the break point. Is there anyway someone who works on the flash builder team could take a look at this?? I have tried reinstalling several times. Here is the eclipse stack trace.
                                at com.adobe.flexbuilder.debug.model.FlexDebugTarget$1.run(FlexDebugTarget.java:1054)
                                at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
                            and the session data:
                            Framework arguments:  -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -keyring /Users/phoenixage/.eclipse_keyring -showlocation
                            Command-line arguments:  -os macosx -ws carbon -arch x86 -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -data /Users/phoenixage/workspaces/phoenixage -product org.eclipse.epp.package.jee.product -keyring /Users/phoenixage/.eclipse_keyring -showlocation
                            • 12. Re: Help Flash Builder Debugger Broken
                              vito c Level 1
                              I've actually nailed it down to one project that is throwing these errors. When I created an empty project it works fine. Another Project that is conected to svn works fine. But when I download the project from SVN I still get these errors. Is there anything I can do to fix this issue?
                              • 13. Re: Help Flash Builder Debugger Broken
                                vito c Level 1
                                I also noticed that the code line numbers are no longer showing up correctly. So when it shows line numbers 1 at the top no matter how far down I scroll.
                                • 14. Re: Help Flash Builder Debugger Broken
                                  vito c Level 1
                                  I don't know if this will help my situation at all but I thought I'd add some more information. Flash Builder is throwing errors in an AS3 only project I created but not throwing the errors in a normal flex project.
