3 Replies Latest reply on Mar 1, 2011 1:18 PM by Kevin Cavallo
    Sum of Radio Button Values
    Josh_B_369 Level 1
      I'm looking to add the values of separate radio buttons together. (JavaScript knowledge = minimal)
      If I have one group of radio buttons with 5 different answers (each answer with a value 1-5). Then I have another group of radio buttons with 2 different answers (each answer with a value 1-2).
      From these two groups of radio buttons I want to have a numeric field that calculates the sum of the two groups of radio buttons. (this would range from a total value of 2-7)
      Take for instance the following example which would be shown in the Hierarchy Pallette where the numbers represent the value.
           -Page1
                -Subform1
                     -Question1
                          -Radio_Button_A = 1
                          -Radio_Button_B = 2
                          -Radio_Button_C = 3
                          -Radio_Button_D = 4
                          -Radio_Button_E = 5
                -Subform2
                     -Question2
                          -Radio_Button_A = 1
                          -Radio_Button_B = 2
        • 1. Re: Sum of Radio Button Values
          Josh_B_369 Level 1
          I found the following solution using FormCalc but would rather use the JavaScript equivilant.
          sum(Subform1.Question1, Subform2.Question2)
          Is there a Javascript script equal to the FormCalc script above?
          • 2. Re: Sum of Radio Button Values
            Kevin Cavallo Level 4
                 var result = parseInt(Subform1.Question1.rawValue) + parseInt(Subform2.Question2.rawValue);
            Since the values returned from the radio button groups are strings, you need to convert the values to an integer using parseInt() before you can add them.
            However: be careful where you are doing the calculation if you are not defaulting a value for the button groups.  If none of the buttons are selected in a group, it will return an empty string for the value, which parseInt will convert to "NaN" (meaning Not a Number) and you will end up with a meaningless result.  Either: have a default for all button groups, or check that a valid number exists for each group before doing the calculation, or put the calculation in an event that will occur after all selections have been made.
            • 3. Re: Sum of Radio Button Values
              Sorry, read your initial post again more closely.  If you're going to use a numeric field to display the sum, then just put the following in the calculate event of the numeric field:
              The numeric field will throw away any value that isn't a number, so it won't display anything until you actually have two valid selections.
              Kevin
