1 Reply Latest reply on Mar 1, 2011 9:06 PM by Shongrunden
    Loading controls in Datagroup
    Flex Rock Level 1
              I have a Datagroup  in which i have an ItemRenderer of  Label and HRule. The length of dataprovider is  4. So label and Hrule appears four times. But i need the Hrule to be  appeared only three times.
      example.
      I need the layout to be like this.
      Regards,
      Jayagopal.
        • 1. Re: Loading controls in Datagroup
          Shongrunden Adobe Employee
          You can use the itemIndex property of ItemRenderer and compare it against the length of the DataGroup's dataProvider.
          Here is a simple example:
                         xmlns:s="library://ns.adobe.com/flex/spark">
              <s:DataGroup width="100">
                  <s:layout>
                      <s:VerticalLayout gap="0" horizontalAlign="justify" />
                  </s:layout>
                  <s:dataProvider>
                      <s:ArrayList>
                          <fx:String>0</fx:String>
                          <fx:String>1</fx:String>
                          <fx:String>2</fx:String>
                          <fx:String>3</fx:String>
                      </s:ArrayList>
                  </s:dataProvider>
                  <s:itemRenderer>
                      <fx:Component>
                          <s:ItemRenderer>
                              <fx:Script>
                                  <![CDATA[
                                      import spark.components.DataGroup;
                                      override public function set data(value:Object):void {
                                          super.data = value;
                                          if (!data)
                                              return;
                                          // set the Label text
                                          lbl.text = data as String;
                                          // find the number of items in the dataProvider
                                          var d:DataGroup = owner as DataGroup;
                                          var numItems:int = d.dataProvider.length;
                                          // only show the separator if its not the last item
                                          if (itemIndex == numItems - 1){
                                              separator.visible = false;
                                          } else {
                                              separator.visible = true;
                              </fx:Script>
                              <s:Label id="lbl" />
                              <s:Rect id="separator" width="100%" height="1" bottom="0">
                                  <s:fill>
                                      <s:SolidColor color="black" />
                                  </s:fill>
                              </s:Rect>
                          </s:ItemRenderer>
                      </fx:Component>
                  </s:itemRenderer>
              </s:DataGroup>
          </s:Application>
