14 Replies Latest reply on Mar 4, 2011 6:53 AM by jfbilodeau
    Resources stored in SWC are stripped from the SWF
    jfbilodeau
      Greetings,
      Using Flash Builder Burrito with Hero SDK. I'm compiling a SWC with some [Embed()] resources, and using it with an Air application. When starting the application, the resources are not loadable.
      Turns out that the Flex compiler seems to strip the resources from the SWC. The code from the SWC is definitely merged and executes within the Air SWF.
      Size of the SWC: 586KB
      Size of the SWF: 53KB
      Google failed me. Any suggestions?
      J-F
        • 1. Re: Resources stored in SWC are stripped from the SWF
          Flex harUI Adobe Employee
          The compiler will not link classes from the SWC that aren't required due to
          a chain of dependencies from the SWF.
          • 2. Re: Resources stored in SWC are stripped from the SWF
            jfbilodeau Level 1
            Thanks for the reply.
            I should have clarified that I'm referring (using) the resource in the swc. For example:
            From the swc:
            [Embed(source="myresource.swf")]
            static const Resource:Class;
            var movie = new Resource();
            This swc is then merged with an Air application. The code executes, but the resource (myresource.swf) is nowhere to be found in the new Air swf.
            Could it be that the Flex compiler does not use metadata (Embed()) to determine the chain of dependency?
            If that's the case, would you have a suggestion on how I could get around this? I'm hoping to share the code and the resources between projects, and a swc seemed like the right answer.
            J-F
            • 3. Re: Resources stored in SWC are stripped from the SWF
              It doesn't matter that you are using the resource in the SWC, what matters
              is the SWF.  The code you quoted is in some .AS file representing a class.
              Is that class used by the SWF?  A -link-report will help you see the class
              dependencies.
              • 4. Re: Resources stored in SWC are stripped from the SWF
                jfbilodeau Level 1
                Thanks again harUI,
                Thanks for pointing out the -link-report. Based on the above example, the Resource:Class is clearly declared and it's dependencies (<pre id="mx.core:ByteArrayAsset" /><dep id="AS3" />) are listed. Unfortunately, I don't see any reference to the embedded asset that accompanies the Resource (Movie.swf). The same applies to catalog.xml in the swc. I can see the dependencies listed for the Resource variable, but nothing about the actual swf. Thus, the compiler does not recognizes that the embedded file is a dependency.
                Is there anyway to make the compiler recognize assets declared using the Embed() metadata in AS3?
                If not, how could I share code and resources between projects?
                Thank you very much!
                • 5. Re: Resources stored in SWC are stripped from the SWF
                  I would expect that you've written that embed as part of a class.  What is
                  the name of that class, and how is the main SWF using that class?
                  Show the code for the class and what is using it, and maybe snippets from
                  the link-report.
                  • 6. Re: Resources stored in SWC are stripped from the SWF
                    jfbilodeau Level 1
                    I appreciate your persistence, harUI. Thanks!
                    In the hopes of making it easier for you, here's the class code:
                    package com.chronogears.meteorminer
                        public class Assets
                            [Embed(source="/assets/star.png")]
                            public static const star:Class;
                            [Embed(source="/assets/Ship.png")]
                            public static const ship:Class;
                            [Embed(source="/assets/SmallOre.swf")]
                            public static const smallOre:Class;
                            [Embed(source="/assets/MediumOre.swf")]
                            public static const mediumOre:Class;
                            [Embed(source="/assets/LargeOre.swf")]
                            public static const largeOre:Class;
                            [Embed(source="/assets/Meteor_16.png")]
                            public static const meteor16:Class;
                            [Embed(source="/assets/Meteor_32.png")]
                            public static const meteor32:Class;
                            [Embed(source="/assets/Meteor_64.png")]
                            public static const meteor64:Class;
                            [Embed(source="/assets/Meteor_128.png")]
                            public static const meteor128:Class;
                    H
                    ere's where I use the asset:
                        public class Ship extends Sprite
                            protected override function init():void
                                var image:Bitmap = new Assets.ship;
                                addChild(image);
                    Here's Catalog.xml from the swc:
                    <?xml version="1.0" encoding ="utf-8"?>
                    <swc xmlns="http://www.adobe.com/flash/swccatalog/9">
                      <versions>
                        <swc version="1.2" />
                        <flex version="4.5.0" build="17689" minimumSupportedVersion="3.0.0" />
                      </versions>
                      <features>
                        <feature-script-deps />
                        <feature-files />
                      </features>
                      <libraries>
                        <library path="library.swf">
                          <script name="org/flintparticles/threeD/geom/Transformable3D" mod="1283190769000" signatureChecksum="2921223431" >
                            <def id="org.flintparticles.threeD.geom:Transformable3D" />
                            <dep id="AS3" type="n" />
                            <dep id="Object" type="i" />
                          </script>
                          <script name="org/flintparticles/common/counters/Counter" mod="1283190769000" signatureChecksum="1954177909" >
                            <def id="org.flintparticles.common.counters:Counter" />
                            <dep id="org.flintparticles.common.emitters:Emitter" type="s" />
                          </script>
                          <script name="org/flintparticles/common/counters/KeyDownCounter" mod="1283190769000" signatureChecksum="4170432124" >
                            <def id="org.flintparticles.common.counters:KeyDownCounter" />
                            <dep id="flash.events:KeyboardEvent" type="e" />
                            <dep id="flash.events:KeyboardEvent" type="s" />
                            <dep id="flash.display:Stage" type="s" />
                            <dep id="org.flintparticles.common.counters:Counter" type="i" />
                          </script>
                          <script name="org/flintparticles/common/behaviours/Behaviour" mod="1283190769000" signatureChecksum="839868160" >
                            <def id="org.flintparticles.common.behaviours:Behaviour" />
                          </script>
                          <script name="org/flintparticles/common/actions/Action" mod="1289466183000" signatureChecksum="1330537774" >
                            <def id="org.flintparticles.common.actions:Action" />
                            <dep id="org.flintparticles.common.particles:Particle" type="s" />
                            <dep id="org.flintparticles.common.behaviours:Behaviour" type="i" />
                          </script>
                          <script name="org/flintparticles/common/actions/ActionBase" mod="1289466180000" signatureChecksum="1095339969" >
                            <def id="org.flintparticles.common.actions:ActionBase" />
                            <dep id="org.flintparticles.common.actions:Action" type="i" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/TweenPosition" mod="1289464578000" signatureChecksum="2429733331" >
                            <def id="org.flintparticles.threeD.actions:TweenPosition" />
                            <dep id="org.flintparticles.threeD.geom:Vector3D" type="e" />
                            <dep id="org.flintparticles.threeD.particles:Particle3D" type="e" />
                            <dep id="org.flintparticles.threeD.geom:Point3D" type="e" />
                            <dep id="org.flintparticles.threeD.geom:Vector3D" type="s" />
                            <dep id="org.flintparticles.threeD.geom:Point3D" type="s" />
                            <dep id="org.flintparticles.common.actions:ActionBase" type="i" />
                          </script>
                          <script name="org/flintparticles/common/renderers/Renderer" mod="1283190769000" signatureChecksum="225396532" >
                            <def id="org.flintparticles.common.renderers:Renderer" />
                          </script>
                          <script name="org/flintparticles/common/renderers/FlexRendererBase" mod="1289464578000" signatureChecksum="159785682" >
                            <def id="org.flintparticles.common.renderers:FlexRendererBase" />
                            <dep id="org.flintparticles.common.events:ParticleEvent" type="e" />
                            <dep id="flash.events:Event" type="e" />
                            <dep id="org.flintparticles.common.events:EmitterEvent" type="e" />
                            <dep id="org.flintparticles.common.emitters:Emitter" type="e" />
                            <dep id="org.flintparticles.common.events:ParticleEvent" type="s" />
                            <dep id="flash.events:Event" type="s" />
                            <dep id="org.flintparticles.common.events:EmitterEvent" type="s" />
                            <dep id="mx.core:UIComponent" type="i" />
                            <dep id="org.flintparticles.common.renderers:Renderer" type="i" />
                          </script>
                          <script name="org/flintparticles/twoD/renderers/mxml/BitmapRenderer" mod="1289464578000" signatureChecksum="1955477476" >
                            <def id="org.flintparticles.twoD.renderers.mxml:BitmapRenderer" />
                            <dep id="flash.display:BitmapData" type="e" />
                            <dep id="flash.geom:Rectangle" type="e" />
                            <dep id="flash.display:DisplayObject" type="e" />
                            <dep id="Math" type="e" />
                            <dep id="flash.display:Bitmap" type="e" />
                            <dep id="flash.geom:Point" type="e" />
                            <dep id="flash.filters:BitmapFilter" type="s" />
                            <dep id="flash.display:BitmapData" type="s" />
                            <dep id="flash.geom:Rectangle" type="s" />
                            <dep id="flash.geom:Matrix" type="s" />
                            <dep id="flash.display:Bitmap" type="s" />
                            <dep id="org.flintparticles.twoD.particles:Particle2D" type="s" />
                            <dep id="flash.geom:Point" type="s" />
                            <dep id="org.flintparticles.common.renderers:FlexRendererBase" type="i" />
                          </script>
                          <script name="org/flintparticles/twoD/renderers/mxml/BitmapLineRenderer" mod="1289466550000" signatureChecksum="2194521158" >
                            <def id="org.flintparticles.twoD.renderers.mxml:BitmapLineRenderer" />
                            <dep id="flash.display:Shape" type="e" />
                            <dep id="flash.display:Shape" type="s" />
                            <dep id="org.flintparticles.twoD.renderers.mxml:BitmapRenderer" type="i" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/Move" mod="1289464578000" signatureChecksum="2842069929" >
                            <def id="org.flintparticles.threeD.actions:Move" />
                            <dep id="org.flintparticles.threeD.particles:Particle3D" type="s" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/MutualGravity" mod="1289464578000" signatureChecksum="3538413463" >
                            <def id="org.flintparticles.twoD.actions:MutualGravity" />
                            <dep id="org.flintparticles.twoD.emitters:Emitter2D" type="e" />
                            <dep id="org.flintparticles.twoD.particles:Particle2D" type="e" />
                            <dep id="org.flintparticles.twoD.emitters:Emitter2D" type="s" />
                          </script>
                          <script name="org/flintparticles/common/initializers/Initializer" mod="1289466258000" signatureChecksum="118843508" >
                            <def id="org.flintparticles.common.initializers:Initializer" />
                          </script>
                          <script name="org/flintparticles/common/initializers/InitializerBase" mod="1289466285000" signatureChecksum="415274835" >
                            <def id="org.flintparticles.common.initializers:InitializerBase" />
                            <dep id="org.flintparticles.common.initializers:Initializer" type="i" />
                          </script>
                          <script name="org/flintparticles/common/initializers/ChooseInitializer" mod="1283190769000" signatureChecksum="3873428252" >
                            <def id="org.flintparticles.common.initializers:ChooseInitializer" />
                            <dep id="org.flintparticles.common.utils:WeightedArray" type="e" />
                            <dep id="org.flintparticles.common.initializers:Initializer" type="s" />
                            <dep id="org.flintparticles.common.utils:WeightedArray" type="s" />
                            <dep id="org.flintparticles.common.initializers:InitializerBase" type="i" />
                          </script>
                          <script name="org/flintparticles/common/actions/KeyDownAction" mod="1283190769000" signatureChecksum="805693850" >
                            <def id="org.flintparticles.common.actions:KeyDownAction" />
                            <dep id="org.flintparticles.common.actions:Action" type="s" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/TweenPosition" mod="1283190769000" signatureChecksum="1599788047" >
                            <def id="org.flintparticles.twoD.actions:TweenPosition" />
                          </script>
                          <script name="org/flintparticles/common/actions/Age" mod="1283190769000" signatureChecksum="1022394747" >
                            <def id="org.flintparticles.common.actions:Age" />
                            <dep id="org.flintparticles.common.energyEasing:Linear" type="e" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/GravityWell" mod="1289464578000" signatureChecksum="103222334" >
                            <def id="org.flintparticles.threeD.actions:GravityWell" />
                          </script>
                          <script name="org/flintparticles/common/utils/WeightedArray" mod="1289464578000" signatureChecksum="2365310234" >
                            <def id="org.flintparticles.common.utils:WeightedArray" />
                            <dep id="flash.utils:Proxy" type="i" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/Accelerate" mod="1283190769000" signatureChecksum="2391974387" >
                            <def id="org.flintparticles.twoD.actions:Accelerate" />
                          </script>
                          <script name="org/flintparticles/common/actions/TargetColor" mod="1283190769000" signatureChecksum="3099364021" >
                            <def id="org.flintparticles.common.actions:TargetColor" />
                          </script>
                          <script name="org/flintparticles/twoD/zones/Zone2D" mod="1289466928000" signatureChecksum="442328552" >
                            <def id="org.flintparticles.twoD.zones:Zone2D" />
                          </script>
                          <script name="org/flintparticles/twoD/zones/GreyscaleZone" mod="1283190769000" signatureChecksum="1423313146" >
                            <def id="org.flintparticles.twoD.zones:GreyscaleZone" />
                            <dep id="org.flintparticles.common.utils:FastWeightedArray" type="e" />
                            <dep id="org.flintparticles.common.utils:FastWeightedArray" type="s" />
                            <dep id="org.flintparticles.twoD.zones:Zone2D" type="i" />
                          </script>
                          <script name="org/flintparticles/common/displayObjects/Line" mod="1283190769000" signatureChecksum="2873251385" >
                            <def id="org.flintparticles.common.displayObjects:Line" />
                            <dep id="flash.display:Shape" type="i" />
                          </script>
                          <script name="org/flintparticles/common/behaviours/BehaviourArrayUtils" mod="1289464578000" signatureChecksum="2287242106" >
                            <def id="org.flintparticles.common.behaviours:BehaviourArrayUtils" />
                            <dep id="org.flintparticles.common.behaviours:Behaviour" type="e" />
                            <dep id="org.flintparticles.common.behaviours:Behaviour" type="s" />
                          </script>
                          <script name="org/flintparticles/common/energyEasing/Linear" mod="1283190769000" signatureChecksum="2990890041" >
                            <def id="org.flintparticles.common.energyEasing:Linear" />
                          </script>
                          <script name="org/flintparticles/common/actions/ColorChange" mod="1283190769000" signatureChecksum="4022181288" >
                            <def id="org.flintparticles.common.actions:ColorChange" />
                            <dep id="org.flintparticles.common.utils:interpolateColors" type="e" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/ZonedAction" mod="1283190769000" signatureChecksum="1913134011" >
                            <def id="org.flintparticles.twoD.actions:ZonedAction" />
                            <dep id="org.flintparticles.twoD.zones:Zone2D" type="s" />
                          </script>
                          <script name="org/flintparticles/common/renderers/SpriteRendererBase" mod="1289464578000" signatureChecksum="2246580016" >
                            <def id="org.flintparticles.common.renderers:SpriteRendererBase" />
                            <dep id="flash.display:Sprite" type="i" />
                          </script>
                          <script name="org/flintparticles/threeD/renderers/BitmapRenderer" mod="1289464578000" signatureChecksum="3821560078" >
                            <def id="org.flintparticles.threeD.renderers:BitmapRenderer" />
                            <dep id="org.flintparticles.threeD.geom:Quaternion" type="e" />
                            <dep id="org.flintparticles.threeD.renderers:Camera" type="e" />
                            <dep id="flash.geom:Matrix" type="e" />
                            <dep id="org.flintparticles.threeD.geom:Matrix3D" type="s" />
                            <dep id="org.flintparticles.threeD.renderers:Camera" type="s" />
                            <dep id="org.flintparticles.common.renderers:SpriteRendererBase" type="i" />
                          </script>
                          <script name="org/flintparticles/threeD/renderers/PixelRenderer" mod="1289464578000" signatureChecksum="1045065288" >
                            <def id="org.flintparticles.threeD.renderers:PixelRenderer" />
                            <dep id="org.flintparticles.threeD.renderers:BitmapRenderer" type="i" />
                          </script>
                          <script name="org/flintparticles/twoD/zones/DiscZone" mod="1283190769000" signatureChecksum="3740522503" >
                            <def id="org.flintparticles.twoD.zones:DiscZone" />
                            <dep id="Error" type="e" />
                          </script>
                          <script name="org/flintparticles/threeD/renderers/mxml/BitmapRenderer" mod="1289464578000" signatureChecksum="791005027" >
                            <def id="org.flintparticles.threeD.renderers.mxml:BitmapRenderer" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/QuadraticDrag" mod="1283190769000" signatureChecksum="49517903" >
                            <def id="org.flintparticles.twoD.actions:QuadraticDrag" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/RotateToDirection" mod="1289464578000" signatureChecksum="2243409892" >
                            <def id="org.flintparticles.threeD.actions:RotateToDirection" />
                            <dep id="org.flintparticles.threeD.geom:Vector3DUtils" type="e" />
                          </script>
                          <script name="org/flintparticles/common/initializers/CollisionRadiusInit" mod="1283190769000" signatureChecksum="3094707568" >
                            <def id="org.flintparticles.common.initializers:CollisionRadiusInit" />
                          </script>
                          <script name="org/flintparticles/common/emitters/Emitter" mod="1289466687000" signatureChecksum="3989135063" >
                            <def id="org.flintparticles.common.emitters:Emitter" />
                            <dep id="org.flintparticles.common.events:UpdateEvent" type="e" />
                            <dep id="org.flintparticles.common.behaviours:BehaviourArrayUtils" type="e" />
                            <dep id="org.flintparticles.common.activities:Activity" type="e" />
                            <dep id="org.flintparticles.common.initializers:Initializer" type="e" />
                            <dep id="org.flintparticles.common.utils:FrameUpdater" type="e" />
                            <dep id="org.flintparticles.common.counters:ZeroCounter" type="e" />
                            <dep id="org.flintparticles.common.events:UpdateEvent" type="s" />
                            <dep id="org.flintparticles.common.activities:Activity" type="s" />
                            <dep id="org.flintparticles.common.particles:ParticleFactory" type="s" />
                            <dep id="org.flintparticles.common.counters:Counter" type="s" />
                            <dep id="flash.events:EventDispatcher" type="i" />
                          </script>
                          <script name="org/flintparticles/threeD/emitters/Emitter3D" mod="1289464578000" signatureChecksum="525822458" >
                            <def id="org.flintparticles.threeD.emitters:Emitter3D" />
                            <dep id="org.flintparticles.threeD.geom:Matrix3D" type="e" />
                            <dep id="org.flintparticles.threeD.particles:ParticleCreator3D" type="e" />
                            <dep id="org.flintparticles.threeD.geom:Quaternion" type="s" />
                            <dep id="org.flintparticles.threeD.particles:ParticleCreator3D" type="s" />
                            <dep id="org.flintparticles.common.emitters:Emitter" type="i" />
                          </script>
                          <script name="org/flintparticles/common/activities/FrameUpdatable" mod="1277967615000" signatureChecksum="2175156078" >
                            <def id="org.flintparticles.common.activities:FrameUpdatable" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/RandomDrift" mod="1283190769000" signatureChecksum="878684857" >
                            <def id="org.flintparticles.twoD.actions:RandomDrift" />
                          </script>
                          <script name="org/flintparticles/threeD/zones/Zone3D" mod="1289466832000" signatureChecksum="4221454552" >
                            <def id="org.flintparticles.threeD.zones:Zone3D" />
                          </script>
                          <script name="org/flintparticles/threeD/zones/ParallelogramZone" mod="1289464578000" signatureChecksum="996718134" >
                            <def id="org.flintparticles.threeD.zones:ParallelogramZone" />
                            <dep id="org.flintparticles.threeD.zones:Zone3D" type="i" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/TurnTowardsMouse" mod="1283190769000" signatureChecksum="2079179701" >
                            <def id="org.flintparticles.twoD.actions:TurnTowardsMouse" />
                            <dep id="flash.display:DisplayObject" type="s" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/TurnAwayFromMouse" mod="1283190769000" signatureChecksum="2920635237" >
                            <def id="org.flintparticles.twoD.actions:TurnAwayFromMouse" />
                            <dep id="org.flintparticles.twoD.actions:TurnTowardsMouse" type="i" />
                          </script>
                          <script name="org/flintparticles/common/events/ParticleEvent" mod="1283190769000" signatureChecksum="1930083253" >
                            <def id="org.flintparticles.common.events:ParticleEvent" />
                            <dep id="flash.events:Event" type="i" />
                          </script>
                          <script name="org/flintparticles/common/easing/Exponential" mod="1283190769000" signatureChecksum="3801832471" >
                            <def id="org.flintparticles.common.easing:Exponential" />
                          </script>
                          <script name="org/flintparticles/common/initializers/ScaleImagesInit" mod="1283190769000" signatureChecksum="3630938390" >
                            <def id="org.flintparticles.common.initializers:ScaleImagesInit" />
                          </script>
                          <script name="org/flintparticles/common/counters/Blast" mod="1283190769000" signatureChecksum="2570812944" >
                            <def id="org.flintparticles.common.counters:Blast" />
                          </script>
                          <script name="org/flintparticles/common/activities/Activity" mod="1289466328000" signatureChecksum="2517065329" >
                            <def id="org.flintparticles.common.activities:Activity" />
                          </script>
                          <script name="org/flintparticles/common/activities/ActivityBase" mod="1289466345000" signatureChecksum="3088353796" >
                            <def id="org.flintparticles.common.activities:ActivityBase" />
                            <dep id="org.flintparticles.common.activities:Activity" type="i" />
                          </script>
                          <script name="org/flintparticles/threeD/activities/RotateEmitter" mod="1289464578000" signatureChecksum="2446180430" >
                            <def id="org.flintparticles.threeD.activities:RotateEmitter" />
                            <dep id="org.flintparticles.threeD.emitters:Emitter3D" type="e" />
                            <dep id="org.flintparticles.threeD.emitters:Emitter3D" type="s" />
                            <dep id="org.flintparticles.common.activities:ActivityBase" type="i" />
                          </script>
                          <script name="org/flintparticles/twoD/renderers/mxml/VectorLineRenderer" mod="1289464578000" signatureChecksum="4200642977" >
                            <def id="org.flintparticles.twoD.renderers.mxml:VectorLineRenderer" />
                          </script>
                          <script name="org/flintparticles/threeD/initializers/ScaleAllInit" mod="1283190769000" signatureChecksum="896644617" >
                            <def id="org.flintparticles.threeD.initializers:ScaleAllInit" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/TargetVelocity" mod="1283190769000" signatureChecksum="3680882721" >
                            <def id="org.flintparticles.twoD.actions:TargetVelocity" />
                          </script>
                          <script name="com/chronogears/meteorminer/CgSprite" mod="1298993390000" signatureChecksum="2554546437" >
                            <def id="com.chronogears.meteorminer:CgSprite" />
                          </script>
                          <script name="org/flintparticles/common/particles/ParticleFactory" mod="1283190769000" signatureChecksum="1830241903" >
                            <def id="org.flintparticles.common.particles:ParticleFactory" />
                          </script>
                          <script name="org/flintparticles/threeD/particles/ParticleCreator3D" mod="1289464578000" signatureChecksum="2078898752" >
                            <def id="org.flintparticles.threeD.particles:ParticleCreator3D" />
                            <dep id="org.flintparticles.common.particles:ParticleFactory" type="i" />
                          </script>
                          <script name="org/flintparticles/common/counters/Steady" mod="1283190769000" signatureChecksum="3155327627" >
                            <def id="org.flintparticles.common.counters:Steady" />
                          </script>
                          <script name="org/flintparticles/twoD/initializers/Rotation" mod="1283190769000" signatureChecksum="2164900887" >
                            <def id="org.flintparticles.twoD.initializers:Rotation" />
                          </script>
                          <script name="org/flintparticles/twoD/zones/MultiZone" mod="1283190769000" signatureChecksum="2842067175" >
                            <def id="org.flintparticles.twoD.zones:MultiZone" />
                          </script>
                          <script name="org/flintparticles/common/energyEasing/Elastic" mod="1283190769000" signatureChecksum="727141505" >
                            <def id="org.flintparticles.common.energyEasing:Elastic" />
                          </script>
                          <script name="org/flintparticles/threeD/geom/Vector3D" mod="1283190769000" signatureChecksum="3475274007" >
                            <def id="org.flintparticles.threeD.geom:Vector3D" />
                            <dep id="org.flintparticles.threeD.geom:Transformable3D" type="i" />
                          </script>
                          <script name="com/chronogears/meteorminer/TitleMode_titleMovie" mod="1291248118000" signatureChecksum="3825311160" >
                            <def id="com.chronogears.meteorminer:TitleMode_titleMovie" />
                            <dep id="flash.utils:ByteArray" type="e" />
                            <dep id="com.chronogears.meteorminer:TitleMode_titleMovie_dataClass" type="e" />
                            <dep id="flash.utils:ByteArray" type="s" />
                            <dep id="mx.core:MovieClipLoaderAsset" type="i" />
                          </script>
                          <script name="org/flintparticles/threeD/initializers/FaceAxis" mod="1283190769000" signatureChecksum="2391517978" >
                            <def id="org.flintparticles.threeD.initializers:FaceAxis" />
                          </script>
                          <script name="org/flintparticles/common/initializers/MassInit" mod="1283190769000" signatureChecksum="1339519688" >
                            <def id="org.flintparticles.common.initializers:MassInit" />
                          </script>
                          <script name="org/flintparticles/common/counters/TimePeriod" mod="1283190769000" signatureChecksum="3512778999" >
                            <def id="org.flintparticles.common.counters:TimePeriod" />
                            <dep id="org.flintparticles.common.easing:Linear" type="e" />
                          </script>
                          <script name="com/chronogears/meteorminer/MeteorMinerMain" mod="1299011489000" signatureChecksum="333081725" >
                            <def id="com.chronogears.meteorminer:MeteorMinerMain" />
                            <dep id="com.chronogears.meteorminer:StarField" type="e" />
                            <dep id="com.chronogears.meteorminer:GameMode" type="e" />
                            <dep id="com.chronogears.meteorminer:StarField" type="s" />
                            <dep id="flash.display:Sprite" type="s" />
                            <dep id="com.chronogears.meteorminer:CgSprite" type="i" />
                          </script>
                          <script name="org/flintparticles/threeD/activities/MoveEmitter" mod="1289464578000" signatureChecksum="1872347589" >
                            <def id="org.flintparticles.threeD.activities:MoveEmitter" />
                          </script>
                          <script name="org/flintparticles/threeD/renderers/controllers/CameraController" mod="1283190769000" signatureChecksum="3496495150" >
                            <def id="org.flintparticles.threeD.renderers.controllers:CameraController" />
                          </script>
                          <script name="org/flintparticles/threeD/renderers/controllers/KeyboardControllerBase" mod="1283190769000" signatureChecksum="983425361" >
                            <def id="org.flintparticles.threeD.renderers.controllers:KeyboardControllerBase" />
                            <dep id="flash.ui:Keyboard" type="e" />
                            <dep id="org.flintparticles.threeD.renderers.controllers:CameraController" type="i" />
                          </script>
                          <script name="org/flintparticles/threeD/renderers/controllers/FirstPersonCamera" mod="1283190769000" signatureChecksum="4078346913" >
                            <def id="org.flintparticles.threeD.renderers.controllers:FirstPersonCamera" />
                            <dep id="org.flintparticles.threeD.renderers.controllers:KeyboardControllerBase" type="i" />
                          </script>
                          <script name="org/flintparticles/common/particles/Particle" mod="1283190769000" signatureChecksum="1764937487" >
                            <def id="org.flintparticles.common.particles:Particle" />
                            <dep id="flash.geom:ColorTransform" type="e" />
                            <dep id="flash.utils:Dictionary" type="e" />
                            <dep id="flash.geom:ColorTransform" type="s" />
                            <dep id="flash.utils:Dictionary" type="s" />
                          </script>
                          <script name="org/flintparticles/common/counters/Pulse" mod="1283190769000" signatureChecksum="2086047966" >
                            <def id="org.flintparticles.common.counters:Pulse" />
                          </script>
                          <script name="org/flintparticles/twoD/activities/FollowDisplayObject" mod="1277967615000" signatureChecksum="4222273851" >
                            <def id="org.flintparticles.twoD.activities:FollowDisplayObject" />
                          </script>
                          <script name="org/flintparticles/common/initializers/SharedImage" mod="1283190769000" signatureChecksum="2852032910" >
                            <def id="org.flintparticles.common.initializers:SharedImage" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/ScaleAll" mod="1283190769000" signatureChecksum="4281048077" >
                            <def id="org.flintparticles.threeD.actions:ScaleAll" />
                          </script>
                          <script name="org/flintparticles/threeD/zones/ConeZone" mod="1289464578000" signatureChecksum="578936750" >
                            <def id="org.flintparticles.threeD.zones:ConeZone" />
                          </script>
                          <script name="org/flintparticles/common/renderers/RendererBase" mod="1289464578000" signatureChecksum="2458837344" >
                            <def id="org.flintparticles.common.renderers:RendererBase" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/RotateToDirection" mod="1283190769000" signatureChecksum="3543762281" >
                            <def id="org.flintparticles.twoD.actions:RotateToDirection" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/MatchVelocity" mod="1289464578000" signatureChecksum="599582700" >
                            <def id="org.flintparticles.threeD.actions:MatchVelocity" />
                          </script>
                          <script name="com/chronogears/meteorminer/Assets_largeOre" mod="1291412969000" signatureChecksum="3401225814" >
                            <def id="com.chronogears.meteorminer:Assets_largeOre" />
                            <dep id="com.chronogears.meteorminer:Assets_largeOre_dataClass" type="e" />
                          </script>
                          <script name="org/flintparticles/common/counters/Random" mod="1283190769000" signatureChecksum="1113428681" >
                            <def id="org.flintparticles.common.counters:Random" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/Accelerate" mod="1289464578000" signatureChecksum="659543370" >
                            <def id="org.flintparticles.threeD.actions:Accelerate" />
                          </script>
                          <script name="org/flintparticles/common/utils/FrameUpdater" mod="1283190769000" signatureChecksum="2444666076" >
                            <def id="org.flintparticles.common.utils:FrameUpdater" />
                            <dep id="flash.utils:getTimer" type="e" />
                          </script>
                          <script name="org/flintparticles/common/counters/ZeroCounter" mod="1283190769000" signatureChecksum="2656463687" >
                            <def id="org.flintparticles.common.counters:ZeroCounter" />
                          </script>
                          <script name="org/flintparticles/threeD/zones/SphereZone" mod="1289464578000" signatureChecksum="1989126407" >
                            <def id="org.flintparticles.threeD.zones:SphereZone" />
                          </script>
                          <script name="org/flintparticles/common/easing/Bounce" mod="1283190769000" signatureChecksum="3826604524" >
                            <def id="org.flintparticles.common.easing:Bounce" />
                          </script>
                          <script name="org/flintparticles/common/initializers/ImageClasses" mod="1283190769000" signatureChecksum="4637491" >
                            <def id="org.flintparticles.common.initializers:ImageClasses" />
                            <dep id="org.flintparticles.common.utils:construct" type="e" />
                          </script>
                          <script name="org/flintparticles/common/displayObjects/Star" mod="1283190769000" signatureChecksum="603085863" >
                            <def id="org.flintparticles.common.displayObjects:Star" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/TweenToZone" mod="1289464578000" signatureChecksum="2068564485" >
                            <def id="org.flintparticles.threeD.actions:TweenToZone" />
                            <dep id="org.flintparticles.threeD.zones:Zone3D" type="s" />
                          </script>
                          <script name="org/flintparticles/threeD/geom/Point3D" mod="1283190769000" signatureChecksum="2577478090" >
                            <def id="org.flintparticles.threeD.geom:Point3D" />
                          </script>
                          <script name="org/flintparticles/common/actions/TargetScale" mod="1283190769000" signatureChecksum="2008784034" >
                            <def id="org.flintparticles.common.actions:TargetScale" />
                          </script>
                          <script name="org/flintparticles/threeD/renderers/controllers/mxml/KeyboardControllerMxml" mod="1283190769000" signatureChecksum="1927707140" >
                            <def id="org.flintparticles.threeD.renderers.controllers.mxml:KeyboardControllerMxml" />
                            <dep id="mx.core:IMXMLObject" type="i" />
                          </script>
                          <script name="org/flintparticles/threeD/renderers/controllers/mxml/FirstPersonCamera" mod="1283190769000" signatureChecksum="1628939440" >
                            <def id="org.flintparticles.threeD.renderers.controllers.mxml:FirstPersonCamera" />
                            <dep id="org.flintparticles.threeD.renderers.controllers.mxml:KeyboardControllerMxml" type="i" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/DeathSpeed" mod="1283190769000" signatureChecksum="3608522241" >
                            <def id="org.flintparticles.threeD.actions:DeathSpeed" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/RotationalQuadraticDrag" mod="1283190769000" signatureChecksum="1146330505" >
                            <def id="org.flintparticles.twoD.actions:RotationalQuadraticDrag" />
                          </script>
                          <script name="com/chronogears/meteorminer/Assets_star" mod="1291136354000" signatureChecksum="1701428167" >
                            <def id="com.chronogears.meteorminer:Assets_star" />
                            <dep id="mx.core:BitmapAsset" type="i" />
                          </script>
                          <script name="org/flintparticles/common/easing/Linear" mod="1283190769000" signatureChecksum="3309465463" >
                            <def id="org.flintparticles.common.easing:Linear" />
                          </script>
                          <script name="org/flintparticles/threeD/zones/CylinderZone" mod="1289464578000" signatureChecksum="1425008306" >
                            <def id="org.flintparticles.threeD.zones:CylinderZone" />
                          </script>
                          <script name="org/flintparticles/twoD/activities/RotateEmitter" mod="1283190769000" signatureChecksum="113282368" >
                            <def id="org.flintparticles.twoD.activities:RotateEmitter" />
                          </script>
                          <script name="com/chronogears/meteorminer/Assets_mediumOre" mod="1291412994000" signatureChecksum="2959579064" >
                            <def id="com.chronogears.meteorminer:Assets_mediumOre" />
                            <dep id="com.chronogears.meteorminer:Assets_mediumOre_dataClass" type="e" />
                          </script>
                          <script name="org/flintparticles/common/initializers/SharedImages" mod="1283190769000" signatureChecksum="4230134644" >
                            <def id="org.flintparticles.common.initializers:SharedImages" />
                          </script>
                          <script name="org/flintparticles/threeD/zones/MultiZone" mod="1289464578000" signatureChecksum="1061315767" >
                            <def id="org.flintparticles.threeD.zones:MultiZone" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/MinimumDistance" mod="1289464578000" signatureChecksum="2620450456" >
                            <def id="org.flintparticles.threeD.actions:MinimumDistance" />
                          </script>
                          <script name="org/flintparticles/twoD/activities/MoveEmitter" mod="1283190769000" signatureChecksum="2537722212" >
                            <def id="org.flintparticles.twoD.activities:MoveEmitter" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/RotationalLinearDrag" mod="1289464578000" signatureChecksum="4064586683" >
                            <def id="org.flintparticles.threeD.actions:RotationalLinearDrag" />
                          </script>
                          <script name="org/flintparticles/common/behaviours/Resetable" mod="1283190769000" signatureChecksum="3752797332" >
                            <def id="org.flintparticles.common.behaviours:Resetable" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/Explosion" mod="1283190769000" signatureChecksum="4034558203" >
                            <def id="org.flintparticles.twoD.actions:Explosion" />
                            <dep id="org.flintparticles.common.activities:UpdateOnFrame" type="e" />
                            <dep id="org.flintparticles.common.activities:UpdateOnFrame" type="s" />
                            <dep id="org.flintparticles.common.behaviours:Resetable" type="i" />
                            <dep id="org.flintparticles.common.activities:FrameUpdatable" type="i" />
                          </script>
                          <script name="org/flintparticles/twoD/emitters/Emitter2D" mod="1289466888000" signatureChecksum="3468970638" >
                            <def id="org.flintparticles.twoD.emitters:Emitter2D" />
                            <dep id="org.flintparticles.twoD.particles:ParticleCreator2D" type="e" />
                            <dep id="org.flintparticles.common.utils:Maths" type="e" />
                            <dep id="org.flintparticles.twoD.particles:ParticleCreator2D" type="s" />
                          </script>
                          <script name="org/flintparticles/twoD/emitters/mxml/Emitter2D" mod="1283190769000" signatureChecksum="3440545133" >
                            <def id="org.flintparticles.twoD.emitters.mxml:Emitter2D" />
                            <dep id="org.flintparticles.twoD.emitters:Emitter2D" type="i" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/Explosion" mod="1289464578000" signatureChecksum="1796257047" >
                            <def id="org.flintparticles.threeD.actions:Explosion" />
                          </script>
                          <script name="org/flintparticles/threeD/zones/BoxZone" mod="1289464578000" signatureChecksum="3541365096" >
                            <def id="org.flintparticles.threeD.zones:BoxZone" />
                          </script>
                          <script name="org/flintparticles/common/utils/DisplayObjectUtils" mod="1283190769000" signatureChecksum="232937978" >
                            <def id="org.flintparticles.common.utils:DisplayObjectUtils" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/TweenToZone" mod="1283190769000" signatureChecksum="1799532407" >
                            <def id="org.flintparticles.twoD.actions:TweenToZone" />
                          </script>
                          <script name="org/flintparticles/common/energyEasing/Bounce" mod="1283190769000" signatureChecksum="3684125720" >
                            <def id="org.flintparticles.common.energyEasing:Bounce" />
                          </script>
                          <script name="org/flintparticles/common/activities/UpdateOnFrame" mod="1283190769000" signatureChecksum="1572491815" >
                            <def id="org.flintparticles.common.activities:UpdateOnFrame" />
                            <dep id="org.flintparticles.common.activities:FrameUpdatable" type="s" />
                          </script>
                          <script name="org/flintparticles/twoD/activities/FollowMouse" mod="1283190769000" signatureChecksum="156735780" >
                            <def id="org.flintparticles.twoD.activities:FollowMouse" />
                          </script>
                          <script name="com/chronogears/meteorminer/Assets_smallOre_dataClass" mod="1291412944000" signatureChecksum="3077617639" >
                            <def id="com.chronogears.meteorminer:Assets_smallOre_dataClass" />
                            <dep id="mx.core:ByteArrayAsset" type="i" />
                          </script>
                          <script name="org/flintparticles/common/actions/ChangeMass" mod="1283190769000" signatureChecksum="3851324156" >
                            <def id="org.flintparticles.common.actions:ChangeMass" />
                          </script>
                          <script name="org/flintparticles/threeD/renderers/DisplayObjectRenderer" mod="1289464578000" signatureChecksum="4019270710" >
                            <def id="org.flintparticles.threeD.renderers:DisplayObjectRenderer" />
                            <dep id="org.flintparticles.common.particles:Particle" type="e" />
                          </script>
                          <script name="org/flintparticles/twoD/particles/ParticleCreator2D" mod="1289464578000" signatureChecksum="2409331072" >
                            <def id="org.flintparticles.twoD.particles:ParticleCreator2D" />
                          </script>
                          <script name="org/flintparticles/threeD/renderers/controllers/mxml/OrbitCamera" mod="1283190769000" signatureChecksum="1396744114" >
                            <def id="org.flintparticles.threeD.renderers.controllers.mxml:OrbitCamera" />
                          </script>
                          <script name="org/flintparticles/common/actions/Fade" mod="1283190769000" signatureChecksum="1417578352" >
                            <def id="org.flintparticles.common.actions:Fade" />
                          </script>
                          <script name="org/flintparticles/twoD/zones/BitmapDataZone" mod="1283190769000" signatureChecksum="3042445674" >
                            <def id="org.flintparticles.twoD.zones:BitmapDataZone" />
                          </script>
                          <script name="org/flintparticles/threeD/particles/Particle3DUtils" mod="1289464578000" signatureChecksum="340964686" >
                            <def id="org.flintparticles.threeD.particles:Particle3DUtils" />
                            <dep id="flash.display:Sprite" type="e" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/Friction" mod="1283190769000" signatureChecksum="3729691923" >
                            <def id="org.flintparticles.twoD.actions:Friction" />
                          </script>
                          <script name="org/flintparticles/common/energyEasing/Circular" mod="1283190769000" signatureChecksum="2129677553" >
                            <def id="org.flintparticles.common.energyEasing:Circular" />
                          </script>
                          <script name="org/flintparticles/common/initializers/AlphaInit" mod="1283190769000" signatureChecksum="2377686536" >
                            <def id="org.flintparticles.common.initializers:AlphaInit" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/MouseGravity" mod="1283190769000" signatureChecksum="1686296255" >
                            <def id="org.flintparticles.twoD.actions:MouseGravity" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/MouseAntiGravity" mod="1283190769000" signatureChecksum="3256310912" >
                            <def id="org.flintparticles.twoD.actions:MouseAntiGravity" />
                            <dep id="org.flintparticles.twoD.actions:MouseGravity" type="i" />
                          </script>
                          <script name="org/flintparticles/threeD/zones/LineZone" mod="1289464578000" signatureChecksum="365266623" >
                            <def id="org.flintparticles.threeD.zones:LineZone" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/GravityWell" mod="1283190769000" signatureChecksum="3608792619" >
                            <def id="org.flintparticles.twoD.actions:GravityWell" />
                          </script>
                          <script name="org/flintparticles/common/energyEasing/Cubic" mod="1283190769000" signatureChecksum="2244299682" >
                            <def id="org.flintparticles.common.energyEasing:Cubic" />
                          </script>
                          <script name="org/flintparticles/common/counters/PerformanceAdjusted" mod="1289464578000" signatureChecksum="2279265225" >
                            <def id="org.flintparticles.common.counters:PerformanceAdjusted" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/Collide" mod="1289464578000" signatureChecksum="2952074540" >
                            <def id="org.flintparticles.twoD.actions:Collide" />
                          </script>
                          <script name="org/flintparticles/threeD/initializers/RotateVelocity" mod="1283190769000" signatureChecksum="2904817136" >
                            <def id="org.flintparticles.threeD.initializers:RotateVelocity" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/TargetVelocity" mod="1289464578000" signatureChecksum="3067539064" >
                            <def id="org.flintparticles.threeD.actions:TargetVelocity" />
                          </script>
                          <script name="org/flintparticles/common/easing/Cubic" mod="1283190769000" signatureChecksum="2056083830" >
                            <def id="org.flintparticles.common.easing:Cubic" />
                          </script>
                          <script name="org/flintparticles/common/energyEasing/Sine" mod="1283190769000" signatureChecksum="1069763403" >
                            <def id="org.flintparticles.common.energyEasing:Sine" />
                          </script>
                          <script name="org/flintparticles/common/displayObjects/Ellipse" mod="1280213530000" signatureChecksum="948533391" >
                            <def id="org.flintparticles.common.displayObjects:Ellipse" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/Move" mod="1283190769000" signatureChecksum="3026287345" >
                            <def id="org.flintparticles.twoD.actions:Move" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/Rotate" mod="1283190769000" signatureChecksum="1103335061" >
                            <def id="org.flintparticles.threeD.actions:Rotate" />
                          </script>
                          <script name="org/flintparticles/common/displayObjects/Rect" mod="1283190769000" signatureChecksum="395278551" >
                            <def id="org.flintparticles.common.displayObjects:Rect" />
                          </script>
                          <script name="_9cb1b303d5399b75893c10c52b3a8b735c08763f990c897efa3f85ea6aa4667e_flash_display_Sprite" mod="1299011793891" signatureChecksum="367688199" >
                            <def id="_9cb1b303d5399b75893c10c52b3a8b735c08763f990c897efa3f85ea6aa4667e_flash_display_Sprite" />
                            <dep id="flash.system:Security" type="e" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/RotationalFriction" mod="1289464578000" signatureChecksum="3538988549" >
                            <def id="org.flintparticles.threeD.actions:RotationalFriction" />
                          </script>
                          <script name="org/flintparticles/common/energyEasing/Back" mod="1283190769000" signatureChecksum="818891565" >
                            <def id="org.flintparticles.common.energyEasing:Back" />
                          </script>
                          <script name="org/flintparticles/twoD/zones/DiscSectorZone" mod="1283190769000" signatureChecksum="1591609966" >
                            <def id="org.flintparticles.twoD.zones:DiscSectorZone" />
                          </script>
                          <script name="org/flintparticles/common/utils/Maths" mod="1283190769000" signatureChecksum="1391473948" >
                            <def id="org.flintparticles.common.utils:Maths" />
                          </script>
                          <script name="org/flintparticles/common/actions/ChangeCollisionRadius" mod="1283190769000" signatureChecksum="1835439948" >
                            <def id="org.flintparticles.common.actions:ChangeCollisionRadius" />
                          </script>
                          <script name="org/flintparticles/common/easing/Quintic" mod="1283190769000" signatureChecksum="1440307821" >
                            <def id="org.flintparticles.common.easing:Quintic" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/Jet" mod="1283190769000" signatureChecksum="3295205179" >
                            <def id="org.flintparticles.twoD.actions:Jet" />
                          </script>
                          <script name="org/flintparticles/common/easing/Circular" mod="1283190769000" signatureChecksum="2873776837" >
                            <def id="org.flintparticles.common.easing:Circular" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/AntiGravity" mod="1289464578000" signatureChecksum="4012202471" >
                            <def id="org.flintparticles.threeD.actions:AntiGravity" />
                            <dep id="org.flintparticles.threeD.actions:GravityWell" type="i" />
                          </script>
                          <script name="org/flintparticles/twoD/renderers/mxml/DisplayObjectRenderer" mod="1289464578000" signatureChecksum="2503519164" >
                            <def id="org.flintparticles.twoD.renderers.mxml:DisplayObjectRenderer" />
                          </script>
                          <script name="org/flintparticles/twoD/zones/LineZone" mod="1283190769000" signatureChecksum="3771520228" >
                            <def id="org.flintparticles.twoD.zones:LineZone" />
                          </script>
                          <script name="org/flintparticles/threeD/geom/Vector3DUtils" mod="1289464578000" signatureChecksum="1147031070" >
                            <def id="org.flintparticles.threeD.geom:Vector3DUtils" />
                          </script>
                          <script name="com/chronogears/meteorminer/Assets_meteor64" mod="1291514211000" signatureChecksum="3713254052" >
                            <def id="com.chronogears.meteorminer:Assets_meteor64" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/MutualGravity" mod="1289464578000" signatureChecksum="1601829134" >
                            <def id="org.flintparticles.threeD.actions:MutualGravity" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/RotationalLinearDrag" mod="1283190769000" signatureChecksum="2157222659" >
                            <def id="org.flintparticles.twoD.actions:RotationalLinearDrag" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/SpeedLimit" mod="1283190769000" signatureChecksum="2982194767" >
                            <def id="org.flintparticles.threeD.actions:SpeedLimit" />
                          </script>
                          <script name="com/chronogears/meteorminer/Assets_meteor128" mod="1291514211000" signatureChecksum="1715717020" >
                            <def id="com.chronogears.meteorminer:Assets_meteor128" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/Jet" mod="1289464578000" signatureChecksum="4060416867" >
                            <def id="org.flintparticles.threeD.actions:Jet" />
                          </script>
                          <script name="com/chronogears/meteorminer/TitleMode" mod="1298993390000" signatureChecksum="2730044116" >
                            <def id="com.chronogears.meteorminer:TitleMode" />
                            <dep id="com.chronogears.meteorminer:TitleMode_titleMovie" type="e" />
                          </script>
                          <script name="org/flintparticles/common/utils/FastWeightedArray" mod="1289464578000" signatureChecksum="824004842" >
                            <def id="org.flintparticles.common.utils:FastWeightedArray" />
                          </script>
                          <script name="org/flintparticles/threeD/renderers/mxml/DisplayObjectRenderer" mod="1289464578000" signatureChecksum="629622004" >
                            <def id="org.flintparticles.threeD.renderers.mxml:DisplayObjectRenderer" />
                          </script>
                          <script name="org/flintparticles/threeD/zones/PointZone" mod="1289464578000" signatureChecksum="3922486630" >
                            <def id="org.flintparticles.threeD.zones:PointZone" />
                          </script>
                          <script name="org/flintparticles/threeD/initializers/Position" mod="1283190769000" signatureChecksum="2077745696" >
                            <def id="org.flintparticles.threeD.initializers:Position" />
                          </script>
                          <script name="org/flintparticles/common/initializers/ColorInit" mod="1283190769000" signatureChecksum="2141826472" >
                            <def id="org.flintparticles.common.initializers:ColorInit" />
                          </script>
                          <script name="com/chronogears/meteorminer/Assets_smallOre" mod="1291412944000" signatureChecksum="3780613760" >
                            <def id="com.chronogears.meteorminer:Assets_smallOre" />
                            <dep id="com.chronogears.meteorminer:Assets_smallOre_dataClass" type="e" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/LinearDrag" mod="1283190769000" signatureChecksum="1893176009" >
                            <def id="org.flintparticles.twoD.actions:LinearDrag" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/TargetRotateVelocity" mod="1289464578000" signatureChecksum="1720113898" >
                            <def id="org.flintparticles.threeD.actions:TargetRotateVelocity" />
                          </script>
                          <script name="org/flintparticles/common/easing/Sine" mod="1283190769000" signatureChecksum="648370463" >
                            <def id="org.flintparticles.common.easing:Sine" />
                          </script>
                          <script name="com/chronogears/meteorminer/Meteor" mod="1298993390000" signatureChecksum="3961473032" >
                            <def id="com.chronogears.meteorminer:Meteor" />
                          </script>
                          <script name="org/flintparticles/threeD/geom/Quaternion" mod="1289464578000" signatureChecksum="419950968" >
                            <def id="org.flintparticles.threeD.geom:Quaternion" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/ZonedAction" mod="1283190769000" signatureChecksum="93068794" >
                            <def id="org.flintparticles.threeD.actions:ZonedAction" />
                          </script>
                          <script name="org/flintparticles/common/utils/construct" mod="1283190769000" signatureChecksum="1599807403" >
                            <def id="org.flintparticles.common.utils:construct" />
                            <dep id="Class" type="s" />
                            <dep id="Array" type="s" />
                          </script>
                          <script name="org/flintparticles/common/energyEasing/Quartic" mod="1283190769000" signatureChecksum="898452629" >
                            <def id="org.flintparticles.common.energyEasing:Quartic" />
                          </script>
                          <script name="org/flintparticles/common/initializers/Lifetime" mod="1283190769000" signatureChecksum="2178983208" >
                            <def id="org.flintparticles.common.initializers:Lifetime" />
                          </script>
                          <script name="org/flintparticles/twoD/renderers/BitmapRenderer" mod="1289464578000" signatureChecksum="1754391100" >
                            <def id="org.flintparticles.twoD.renderers:BitmapRenderer" />
                          </script>
                          <script name="org/flintparticles/twoD/renderers/BitmapLineRenderer" mod="1289466563000" signatureChecksum="3997612435" >
                            <def id="org.flintparticles.twoD.renderers:BitmapLineRenderer" />
                            <dep id="org.flintparticles.twoD.renderers:BitmapRenderer" type="i" />
                          </script>
                          <script name="org/flintparticles/threeD/initializers/Velocity" mod="1289466775000" signatureChecksum="2227692157" >
                            <def id="org.flintparticles.threeD.initializers:Velocity" />
                          </script>
                          <script name="com/chronogears/meteorminer/Assets_meteor32" mod="1291514211000" signatureChecksum="3516318344" >
                            <def id="com.chronogears.meteorminer:Assets_meteor32" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/Friction" mod="1289464578000" signatureChecksum="1149150667" >
                            <def id="org.flintparticles.threeD.actions:Friction" />
                          </script>
                          <script name="com/chronogears/meteorminer/Assets_largeOre_dataClass" mod="1291412969000" signatureChecksum="2327558049" >
                            <def id="com.chronogears.meteorminer:Assets_largeOre_dataClass" />
                          </script>
                          <script name="org/flintparticles/common/easing/Elastic" mod="1283190769000" signatureChecksum="727347005" >
                            <def id="org.flintparticles.common.easing:Elastic" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/ScaleAll" mod="1283190769000" signatureChecksum="3406076751" >
                            <def id="org.flintparticles.twoD.actions:ScaleAll" />
                          </script>
                          <script name="org/flintparticles/twoD/renderers/PixelRenderer" mod="1283190769000" signatureChecksum="981686821" >
                            <def id="org.flintparticles.twoD.renderers:PixelRenderer" />
                          </script>
                          <script name="org/flintparticles/threeD/renderers/controllers/OrbitCamera" mod="1283190769000" signatureChecksum="4246838691" >
                            <def id="org.flintparticles.threeD.renderers.controllers:OrbitCamera" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/BoundingBox" mod="1283190769000" signatureChecksum="1070800766" >
                            <def id="org.flintparticles.threeD.actions:BoundingBox" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/DeathSpeed" mod="1283190769000" signatureChecksum="711371936" >
                            <def id="org.flintparticles.twoD.actions:DeathSpeed" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/BoundingBox" mod="1283190769000" signatureChecksum="249887012" >
                            <def id="org.flintparticles.twoD.actions:BoundingBox" />
                          </script>
                          <script name="org/flintparticles/threeD/zones/FrustrumZone" mod="1289464578000" signatureChecksum="2032966462" >
                            <def id="org.flintparticles.threeD.zones:FrustrumZone" />
                          </script>
                          <script name="org/flintparticles/threeD/zones/BitmapDataZone" mod="1289464578000" signatureChecksum="2501180190" >
                            <def id="org.flintparticles.threeD.zones:BitmapDataZone" />
                          </script>
                          <script name="org/flintparticles/common/initializers/ColorsInit" mod="1283190769000" signatureChecksum="2952967281" >
                            <def id="org.flintparticles.common.initializers:ColorsInit" />
                          </script>
                          <script name="org/flintparticles/threeD/particles/Particle3D" mod="1289464578000" signatureChecksum="2463493696" >
                            <def id="org.flintparticles.threeD.particles:Particle3D" />
                            <dep id="org.flintparticles.common.particles:Particle" type="i" />
                          </script>
                          <script name="org/flintparticles/common/energyEasing/Exponential" mod="1283190769000" signatureChecksum="2115980867" >
                            <def id="org.flintparticles.common.energyEasing:Exponential" />
                          </script>
                          <script name="com/chronogears/meteorminer/GameMode" mod="1298993390000" signatureChecksum="3990048841" >
                            <def id="com.chronogears.meteorminer:GameMode" />
                            <dep id="flash.ui:Mouse" type="e" />
                            <dep id="com.chronogears.meteorminer:Ship" type="e" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/RandomDrift" mod="1283190769000" signatureChecksum="715243904" >
                            <def id="org.flintparticles.threeD.actions:RandomDrift" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/Collide" mod="1289464578000" signatureChecksum="1577592483" >
                            <def id="org.flintparticles.threeD.actions:Collide" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/RotationalQuadraticDrag" mod="1289464578000" signatureChecksum="442674753" >
                            <def id="org.flintparticles.threeD.actions:RotationalQuadraticDrag" />
                          </script>
                          <script name="org/flintparticles/twoD/initializers/RotationAbsolute" mod="1283190769000" signatureChecksum="1206504085" >
                            <def id="org.flintparticles.twoD.initializers:RotationAbsolute" />
                          </script>
                          <script name="com/chronogears/meteorminer/TitleMode_titleMovie_dataClass" mod="1291248118000" signatureChecksum="3314139917" >
                            <def id="com.chronogears.meteorminer:TitleMode_titleMovie_dataClass" />
                          </script>
                          <script name="org/flintparticles/twoD/initializers/PositionAbsolute" mod="1283190769000" signatureChecksum="1418378292" >
                            <def id="org.flintparticles.twoD.initializers:PositionAbsolute" />
                          </script>
                          <script name="org/flintparticles/threeD/renderers/mxml/PixelRenderer" mod="1289464578000" signatureChecksum="942567675" >
                            <def id="org.flintparticles.threeD.renderers.mxml:PixelRenderer" />
                            <dep id="org.flintparticles.threeD.renderers.mxml:BitmapRenderer" type="i" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/MatchRotateVelocity" mod="1289464578000" signatureChecksum="1485106378" >
                            <def id="org.flintparticles.threeD.actions:MatchRotateVelocity" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/AntiGravity" mod="1283190769000" signatureChecksum="2628996539" >
                            <def id="org.flintparticles.twoD.actions:AntiGravity" />
                            <dep id="org.flintparticles.twoD.actions:GravityWell" type="i" />
                          </script>
                          <script name="org/flintparticles/twoD/initializers/ScaleAllsInit" mod="1283190769000" signatureChecksum="1033751683" >
                            <def id="org.flintparticles.twoD.initializers:ScaleAllsInit" />
                          </script>
                          <script name="org/flintparticles/common/initializers/InitializerGroup" mod="1289464578000" signatureChecksum="4186890437" >
                            <def id="org.flintparticles.common.initializers:InitializerGroup" />
                          </script>
                          <script name="org/flintparticles/twoD/particles/Particle2D" mod="1286384355000" signatureChecksum="4178825580" >
                            <def id="org.flintparticles.twoD.particles:Particle2D" />
                          </script>
                          <script name="org/flintparticles/common/initializers/DictionaryInitializer" mod="1277968222000" signatureChecksum="2102295304" >
                            <def id="org.flintparticles.common.initializers:DictionaryInitializer" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/TurnTowardsPoint" mod="1283190769000" signatureChecksum="2010037261" >
                            <def id="org.flintparticles.twoD.actions:TurnTowardsPoint" />
                          </script>
                          <script name="org/flintparticles/twoD/initializers/Velocity" mod="1289466907000" signatureChecksum="2673849770" >
                            <def id="org.flintparticles.twoD.initializers:Velocity" />
                          </script>
                          <script name="org/flintparticles/common/displayObjects/RadialDot" mod="1283190769000" signatureChecksum="2309450662" >
                            <def id="org.flintparticles.common.displayObjects:RadialDot" />
                            <dep id="flash.display:GradientType" type="e" />
                          </script>
                          <script name="org/flintparticles/twoD/initializers/Position" mod="1283190769000" signatureChecksum="2536289718" >
                            <def id="org.flintparticles.twoD.initializers:Position" />
                          </script>
                          <script name="org/flintparticles/threeD/initializers/PositionAbsolute" mod="1283190769000" signatureChecksum="674084846" >
                            <def id="org.flintparticles.threeD.initializers:PositionAbsolute" />
                          </script>
                          <script name="org/flintparticles/twoD/initializers/ScaleAllInit" mod="1283190769000" signatureChecksum="3518739787" >
                            <def id="org.flintparticles.twoD.initializers:ScaleAllInit" />
                          </script>
                          <script name="org/flintparticles/twoD/zones/RectangleZone" mod="1283190769000" signatureChecksum="1173602464" >
                            <def id="org.flintparticles.twoD.zones:RectangleZone" />
                          </script>
                          <script name="org/flintparticles/threeD/emitters/mxml/Emitter3D" mod="1283190769000" signatureChecksum="2452197194" >
                            <def id="org.flintparticles.threeD.emitters.mxml:Emitter3D" />
                            <dep id="org.flintparticles.threeD.emitters:Emitter3D" type="i" />
                          </script>
                          <script name="org/flintparticles/common/initializers/ApplyFilter" mod="1289466703000" signatureChecksum="2057540487" >
                            <def id="org.flintparticles.common.initializers:ApplyFilter" />
                          </script>
                          <script name="org/flintparticles/twoD/zones/DisplayObjectZone" mod="1283190769000" signatureChecksum="2282604684" >
                            <def id="org.flintparticles.twoD.zones:DisplayObjectZone" />
                          </script>
                          <script name="org/flintparticles/threeD/renderers/Camera" mod="1289464578000" signatureChecksum="328626812" >
                            <def id="org.flintparticles.threeD.renderers:Camera" />
                            <dep id="org.flintparticles.threeD.renderers.controllers:CameraController" type="s" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/ApproachNeighbours" mod="1289464578000" signatureChecksum="290314885" >
                            <def id="org.flintparticles.twoD.actions:ApproachNeighbours" />
                          </script>
                          <script name="org/flintparticles/common/energyEasing/TwoWay" mod="1283190769000" signatureChecksum="1467452024" >
                            <def id="org.flintparticles.common.energyEasing:TwoWay" />
                          </script>
                          <script name="com/chronogears/meteorminer/Assets_meteor16" mod="1291514211000" signatureChecksum="3512844943" >
                            <def id="com.chronogears.meteorminer:Assets_meteor16" />
                          </script>
                          <script name="org/flintparticles/threeD/initializers/ScaleAllsInit" mod="1283190769000" signatureChecksum="3427847489" >
                            <def id="org.flintparticles.threeD.initializers:ScaleAllsInit" />
                          </script>
                          <script name="org/flintparticles/threeD/initializers/Rotation" mod="1283190769000" signatureChecksum="450230935" >
                            <def id="org.flintparticles.threeD.initializers:Rotation" />
                          </script>
                          <script name="org/flintparticles/twoD/initializers/RotateVelocity" mod="1283190769000" signatureChecksum="3526023143" >
                            <def id="org.flintparticles.twoD.initializers:RotateVelocity" />
                          </script>
                          <script name="org/flintparticles/common/initializers/ScaleImageInit" mod="1283190769000" signatureChecksum="3519455710" >
                            <def id="org.flintparticles.common.initializers:ScaleImageInit" />
                          </script>
                          <script name="org/flintparticles/twoD/renderers/VectorLineRenderer" mod="1289464578000" signatureChecksum="2046146949" >
                            <def id="org.flintparticles.twoD.renderers:VectorLineRenderer" />
                          </script>
                          <script name="org/flintparticles/twoD/renderers/mxml/PixelRenderer" mod="1283190769000" signatureChecksum="2073255128" >
                            <def id="org.flintparticles.twoD.renderers.mxml:PixelRenderer" />
                          </script>
                          <script name="org/flintparticles/common/energyEasing/Quadratic" mod="1283190769000" signatureChecksum="3487911258" >
                            <def id="org.flintparticles.common.energyEasing:Quadratic" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/MinimumDistance" mod="1289464578000" signatureChecksum="2031670561" >
                            <def id="org.flintparticles.twoD.actions:MinimumDistance" />
                          </script>
                          <script name="org/flintparticles/common/easing/Quartic" mod="1283190769000" signatureChecksum="1393646185" >
                            <def id="org.flintparticles.common.easing:Quartic" />
                          </script>
                          <script name="org/flintparticles/common/initializers/ImageClass" mod="1283190769000" signatureChecksum="2861669785" >
                            <def id="org.flintparticles.common.initializers:ImageClass" />
                          </script>
                          <script name="org/flintparticles/common/initializers/MouseEventHandlers" mod="1283190769000" signatureChecksum="2771658210" >
                            <def id="org.flintparticles.common.initializers:MouseEventHandlers" />
                            <dep id="flash.events:IEventDispatcher" type="e" />
                            <dep id="flash.events:MouseEvent" type="e" />
                            <dep id="flash.events:IEventDispatcher" type="s" />
                          </script>
                          <script name="org/flintparticles/common/displayObjects/Dot" mod="1283190769000" signatureChecksum="2399491459" >
                            <def id="org.flintparticles.common.displayObjects:Dot" />
                          </script>
                          <script name="org/flintparticles/twoD/renderers/DisplayObjectRenderer" mod="1289464578000" signatureChecksum="561097632" >
                            <def id="org.flintparticles.twoD.renderers:DisplayObjectRenderer" />
                          </script>
                          <script name="org/flintparticles/common/debug/FrameTimer" mod="1289464578000" signatureChecksum="3980476464" >
                            <def id="org.flintparticles.common.debug:FrameTimer" />
                            <dep id="flash.text:TextField" type="i" />
                          </script>
                          <script name="org/flintparticles/common/easing/Quadratic" mod="1283190769000" signatureChecksum="227826478" >
                            <def id="org.flintparticles.common.easing:Quadratic" />
                          </script>
                          <script name="com/chronogears/meteorminer/Ship" mod="1299000696000" signatureChecksum="1733000029" >
                            <def id="com.chronogears.meteorminer:Ship" />
                            <dep id="org.flintparticles.common.initializers:ColorInit" type="e" />
                            <dep id="org.flintparticles.twoD.renderers:DisplayObjectRenderer" type="e" />
                            <dep id="com.chronogears.meteorminer:Assets" type="e" />
                            <dep id="org.flintparticles.twoD.actions:Move" type="e" />
                            <dep id="org.flintparticles.common.counters:Random" type="e" />
                            <dep id="org.flintparticles.twoD.initializers:Velocity" type="e" />
                            <dep id="org.flintparticles.common.initializers:Lifetime" type="e" />
                            <dep id="org.flintparticles.common.actions:Fade" type="e" />
                            <dep id="org.flintparticles.twoD.zones:PointZone" type="e" />
                            <dep id="org.flintparticles.twoD.actions:RandomDrift" type="e" />
                            <dep id="org.flintparticles.twoD.initializers:Position" type="e" />
                            <dep id="org.flintparticles.common.actions:Age" type="e" />
                            <dep id="org.flintparticles.common.displayObjects:RadialDot" type="e" />
                            <dep id="org.flintparticles.common.initializers:ImageClass" type="e" />
                            <dep id="org.flintparticles.twoD.renderers:DisplayObjectRenderer" type="s" />
                          </script>
                          <script name="com/chronogears/meteorminer/Assets_ship" mod="1291484278000" signatureChecksum="1091222380" >
                            <def id="com.chronogears.meteorminer:Assets_ship" />
                          </script>
                          <script name="org/flintparticles/threeD/zones/GreyscaleZone" mod="1289464578000" signatureChecksum="1914108590" >
                            <def id="org.flintparticles.threeD.zones:GreyscaleZone" />
                          </script>
                          <script name="org/flintparticles/twoD/particles/Particle2DUtils" mod="1289464578000" signatureChecksum="2028414948" >
                            <def id="org.flintparticles.twoD.particles:Particle2DUtils" />
                            <dep id="org.flintparticles.common.utils:DisplayObjectUtils" type="e" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/MatchVelocity" mod="1289464578000" signatureChecksum="3132741237" >
                            <def id="org.flintparticles.twoD.actions:MatchVelocity" />
                          </script>
                          <script name="org/flintparticles/threeD/initializers/RotationAbsolute" mod="1283190769000" signatureChecksum="835121310" >
                            <def id="org.flintparticles.threeD.initializers:RotationAbsolute" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/RotationalFriction" mod="1283190769000" signatureChecksum="509648205" >
                            <def id="org.flintparticles.twoD.actions:RotationalFriction" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/LinearDrag" mod="1289464578000" signatureChecksum="2484642689" >
                            <def id="org.flintparticles.threeD.actions:LinearDrag" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/ApproachNeighbours" mod="1289464578000" signatureChecksum="687270908" >
                            <def id="org.flintparticles.threeD.actions:ApproachNeighbours" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/QuadraticDrag" mod="1289464578000" signatureChecksum="2323949063" >
                            <def id="org.flintparticles.threeD.actions:QuadraticDrag" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/TurnTowardsPoint" mod="1289464578000" signatureChecksum="3610638203" >
                            <def id="org.flintparticles.threeD.actions:TurnTowardsPoint" />
                          </script>
                          <script name="org/flintparticles/common/energyEasing/Quintic" mod="1283190769000" signatureChecksum="932531353" >
                            <def id="org.flintparticles.common.energyEasing:Quintic" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/MatchRotateVelocity" mod="1289464578000" signatureChecksum="502127443" >
                            <def id="org.flintparticles.twoD.actions:MatchRotateVelocity" />
                          </script>
                          <script name="org/flintparticles/common/actions/ScaleImage" mod="1283190769000" signatureChecksum="3040185390" >
                            <def id="org.flintparticles.common.actions:ScaleImage" />
                          </script>
                          <script name="org/flintparticles/common/events/UpdateEvent" mod="1289345647000" signatureChecksum="1147229848" >
                            <def id="org.flintparticles.common.events:UpdateEvent" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/Rotate" mod="1283190769000" signatureChecksum="2865462433" >
                            <def id="org.flintparticles.twoD.actions:Rotate" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/TargetRotateVelocity" mod="1283190769000" signatureChecksum="9811853" >
                            <def id="org.flintparticles.twoD.actions:TargetRotateVelocity" />
                          </script>
                          <script name="com/chronogears/meteorminer/StarField" mod="1298993390000" signatureChecksum="4262663443" >
                            <def id="com.chronogears.meteorminer:StarField" />
                            <dep id="org.flintparticles.twoD.zones:RectangleZone" type="e" />
                            <dep id="org.flintparticles.twoD.actions:DeathZone" type="e" />
                            <dep id="org.flintparticles.twoD.zones:LineZone" type="e" />
                            <dep id="org.flintparticles.common.initializers:AlphaInit" type="e" />
                            <dep id="org.flintparticles.common.counters:Steady" type="e" />
                            <dep id="org.flintparticles.twoD.renderers:DisplayObjectRenderer" type="i" />
                          </script>
                          <script name="org/flintparticles/common/easing/Back" mod="1283190769000" signatureChecksum="2569167733" >
                            <def id="org.flintparticles.common.easing:Back" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/SpeedLimit" mod="1283190769000" signatureChecksum="23702738" >
                            <def id="org.flintparticles.twoD.actions:SpeedLimit" />
                          </script>
                          <script name="com/chronogears/meteorminer/Assets_mediumOre_dataClass" mod="1291412994000" signatureChecksum="1744812527" >
                            <def id="com.chronogears.meteorminer:Assets_mediumOre_dataClass" />
                          </script>
                          <script name="org/flintparticles/threeD/actions/DeathZone" mod="1283190769000" signatureChecksum="2856960911" >
                            <def id="org.flintparticles.threeD.actions:DeathZone" />
                          </script>
                          <script name="org/flintparticles/common/utils/interpolateColors" mod="1283190769000" signatureChecksum="3216385717" >
                            <def id="org.flintparticles.common.utils:interpolateColors" />
                            <dep id="Number" type="s" />
                            <dep id="uint" type="s" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/CollisionZone" mod="1283190769000" signatureChecksum="303944578" >
                            <def id="org.flintparticles.twoD.actions:CollisionZone" />
                            <dep id="AS3" type="n" />
                          </script>
                          <script name="com/chronogears/meteorminer/Assets" mod="1299011480000" signatureChecksum="3075728677" >
                            <def id="com.chronogears.meteorminer:Assets" />
                            <dep id="com.chronogears.meteorminer:Assets_smallOre" type="e" />
                            <dep id="com.chronogears.meteorminer:Assets_meteor16" type="e" />
                            <dep id="com.chronogears.meteorminer:Assets_ship" type="e" />
                            <dep id="com.chronogears.meteorminer:Assets_meteor32" type="e" />
                            <dep id="com.chronogears.meteorminer:Assets_mediumOre" type="e" />
                            <dep id="com.chronogears.meteorminer:Assets_star" type="e" />
                            <dep id="com.chronogears.meteorminer:Assets_meteor128" type="e" />
                            <dep id="com.chronogears.meteorminer:Assets_largeOre" type="e" />
                            <dep id="com.chronogears.meteorminer:Assets_meteor64" type="e" />
                            <dep id="Object" type="i" />
                          </script>
                          <script name="org/flintparticles/common/counters/SineCounter" mod="1283190769000" signatureChecksum="3589647439" >
                            <def id="org.flintparticles.common.counters:SineCounter" />
                            <dep id="org.flintparticles.common.emitters:Emitter" type="s" />
                            <dep id="org.flintparticles.common.counters:Counter" type="i" />
                          </script>
                          <script name="org/flintparticles/twoD/actions/DeathZone" mod="1283190769000" signatureChecksum="413647184" >
                            <def id="org.flintparticles.twoD.actions:DeathZone" />
                            <dep id="org.flintparticles.common.particles:Particle" type="s" />
                          </script>
                          <script name="org/flintparticles/threeD/zones/DiscZone" mod="1289464578000" signatureChecksum="1178521476" >
                            <def id="org.flintparticles.threeD.zones:DiscZone" />
                          </script>
                          <script name="org/flintparticles/common/events/EmitterEvent" mod="1277967615000" signatureChecksum="531259352" >
                            <def id="org.flintparticles.common.events:EmitterEvent" />
                          </script>
                          <script name="org/flintparticles/twoD/zones/PointZone" mod="1283190769000" signatureChecksum="1443601381" >
                            <def id="org.flintparticles.twoD.zones:PointZone" />
                          </script>
                          <script name="org/flintparticles/threeD/geom/Matrix3D" mod="1283190769000" signatureChecksum="6710975" >
                            <def id="org.flintparticles.threeD.geom:Matrix3D" />
                            <dep id="org.flintparticles.threeD.geom:Point3D" type="e" />
                            <dep id="org.flintparticles.threeD.geom:Transformable3D" type="s" />
                            <dep id="org.flintparticles.threeD.geom:Vector3D" type="s" />
                            <dep id="org.flintparticles.threeD.geom:Point3D" type="s" />
                          </script>
                          <digests>
                            <digest type="SHA-256" signed="false" value="2d4cb035b4c1aa94a3c22626e8ea94c8625b7b4b957ee4c3fe6484cb044007a6"   />
                          </digests>
                        </library>
                      </libraries>
                      <files>
                        <file path="assets/.DS_Store" mod="1291514142000" />
                        <file path="assets/Meteor_16.png" mod="1291514211000" />
                        <file path="assets/Meteor_32.png" mod="1291514211000" />
                        <file path="assets/Ship.png" mod="1291484278000" />
                        <file path="assets/Ship.psd" mod="1291249407000" />
                        <file path="assets/MeteorMinerTitle.fla" mod="1291248116000" />
                        <file path="assets/Meteor_128.png" mod="1291514211000" />
                        <file path="assets/star.png" mod="1291136354000" />
                        <file path="assets/SmallOre.swf" mod="1291412944000" />
                        <file path="assets/MeteorMinerTitle.swf" mod="1291248118000" />
                        <file path="assets/MediumOre.swf" mod="1291412994000" />
                        <file path="assets/Meteor_64.png" mod="1291514211000" />
                        <file path="assets/LargeOre.swf" mod="1291412969000" />
                        <file path="assets/Ship.ai" mod="1291484259000" />
                        <file path="assets/Meteor.ai" mod="1291514195000" />
                        <file path="assets/star.psd" mod="1291136318000" />
                      </files>
                    </swc>
                    And finally, here's the output of -link-report:
                    <report>
                      <scripts>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.utils:Maths)" mod="1283190769000" size="907" optimizedsize="363">
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="Math" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(com.chronogears.meteorminer:Assets_largeOre)" mod="1291412969000" size="1183" optimizedsize="698">
                          <pre id="mx.core:MovieClipLoaderAsset" />
                          <dep id="com.chronogears.meteorminer:Assets_largeOre_dataClass" />
                          <dep id="flash.utils:ByteArray" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(com.chronogears.meteorminer:StarField)" mod="1298993390000" size="1875" optimizedsize="1282">
                          <pre id="org.flintparticles.twoD.renderers:DisplayObjectRenderer" />
                          <dep id="org.flintparticles.twoD.actions:Move" />
                          <dep id="org.flintparticles.twoD.emitters:Emitter2D" />
                          <dep id="org.flintparticles.twoD.actions:DeathZone" />
                          <dep id="org.flintparticles.common.initializers:AlphaInit" />
                          <dep id="flash.geom:Point" />
                          <dep id="org.flintparticles.twoD.initializers:Velocity" />
                          <dep id="org.flintparticles.twoD.zones:RectangleZone" />
                          <dep id="AS3" />
                          <dep id="org.flintparticles.common.displayObjects:RadialDot" />
                          <dep id="org.flintparticles.twoD.initializers:Position" />
                          <dep id="org.flintparticles.twoD.zones:LineZone" />
                          <dep id="org.flintparticles.common.initializers:ImageClass" />
                          <dep id="org.flintparticles.common.counters:Steady" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.twoD.initializers:Velocity)" mod="1289466907000" size="1594" optimizedsize="824">
                          <pre id="org.flintparticles.common.initializers:InitializerBase" />
                          <dep id="org.flintparticles.common.particles:Particle" />
                          <dep id="AS3" />
                          <dep id="Math" />
                          <dep id="org.flintparticles.twoD.zones:Zone2D" />
                          <dep id="org.flintparticles.twoD.particles:Particle2D" />
                          <dep id="org.flintparticles.common.emitters:Emitter" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.twoD.actions:RandomDrift)" mod="1283190769000" size="1622" optimizedsize="724">
                          <pre id="org.flintparticles.common.actions:ActionBase" />
                          <dep id="AS3" />
                          <dep id="Math" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.counters:Steady)" mod="1283190769000" size="1907" optimizedsize="814">
                          <pre id="org.flintparticles.common.counters:Counter" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="Math" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(com.chronogears.meteorminer:Assets_ship)" mod="1291484278000" size="904" optimizedsize="332">
                          <pre id="mx.core:BitmapAsset" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(com.chronogears.meteorminer:Assets_mediumOre_dataClass)" mod="1291412994000" size="857" optimizedsize="289">
                          <pre id="mx.core:ByteArrayAsset" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(com.chronogears.meteorminer:Assets_meteor128)" mod="1291514211000" size="947" optimizedsize="342">
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.counters:Random)" mod="1283190769000" size="2116" optimizedsize="806">
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="Math" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.particles:ParticleFactory)" mod="1283190769000" size="1083" optimizedsize="291">
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.renderers:Renderer)" mod="1283190769000" size="872" optimizedsize="279">
                          <def id="org.flintparticles.common.renderers:Renderer" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(com.chronogears.meteorminer:Assets_meteor16)" mod="1291514211000" size="939" optimizedsize="340">
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.initializers:ColorInit)" mod="1283190769000" size="1866" optimizedsize="762">
                          <dep id="AS3" />
                          <dep id="Math" />
                          <dep id="org.flintparticles.common.utils:interpolateColors" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder Burrito/sdks/4.5.0/frameworks/libs/flex.swc(mx.core:EdgeMetrics)" mod="1283910237937" size="888" optimizedsize="413">
                          <def id="mx.core:EdgeMetrics" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="mx.core:mx_internal" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.actions:Action)" mod="1289466183000" size="823" optimizedsize="358">
                          <def id="org.flintparticles.common.actions:Action" />
                          <pre id="org.flintparticles.common.behaviours:Behaviour" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.utils:FrameUpdater)" mod="1283190769000" size="2117" optimizedsize="962">
                          <pre id="flash.events:EventDispatcher" />
                          <dep id="flash.events:Event" />
                          <dep id="org.flintparticles.common.events:UpdateEvent" />
                          <dep id="AS3" />
                          <dep id="flash.utils:getTimer" />
                          <dep id="flash.display:Shape" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(com.chronogears.meteorminer:CgSprite)" mod="1298993390000" size="1666" optimizedsize="751">
                          <pre id="flash.display:Sprite" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.initializers:Initializer)" mod="1289466258000" size="891" optimizedsize="371">
                          <def id="org.flintparticles.common.initializers:Initializer" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder Burrito/sdks/4.5.0/frameworks/libs/flash-integration.swc(mx.core:IFlexDisplayObject)" mod="1283910238359" size="6282" optimizedsize="1339">
                          <def id="mx.core:IFlexDisplayObject" />
                          <pre id="flash.events:IEventDispatcher" />
                          <pre id="flash.display:IBitmapDrawable" />
                          <pre id="Object" />
                          <dep id="flash.accessibility:AccessibilityProperties" />
                          <dep id="AS3" />
                          <dep id="flash.geom:Rectangle" />
                          <dep id="flash.display:DisplayObjectContainer" />
                          <dep id="flash.display:DisplayObject" />
                          <dep id="flash.display:LoaderInfo" />
                          <dep id="flash.display:Stage" />
                          <dep id="flash.geom:Transform" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder Burrito/sdks/4.5.0/frameworks/libs/flex.swc(mx.core:IRepeaterClient)" mod="1283910237328" size="1237" optimizedsize="321">
                          <def id="mx.core:IRepeaterClient" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.behaviours:Behaviour)" mod="1283190769000" size="1192" optimizedsize="328">
                          <def id="org.flintparticles.common.behaviours:Behaviour" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.twoD.emitters:Emitter2D)" mod="1289466888000" size="2883" optimizedsize="1376">
                          <pre id="org.flintparticles.common.emitters:Emitter" />
                          <dep id="AS3" />
                          <dep id="org.flintparticles.common.particles:ParticleFactory" />
                          <dep id="org.flintparticles.twoD.particles:ParticleCreator2D" />
                          <dep id="org.flintparticles.common.utils:Maths" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder Burrito/sdks/4.5.0/frameworks/libs/flex.swc(mx.core:IFlexAsset)" mod="1283910238109" size="343" optimizedsize="98">
                          <def id="mx.core:IFlexAsset" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder Burrito/sdks/4.5.0/frameworks/libs/flex.swc(mx.core:FlexBitmap)" mod="1283910237953" size="970" optimizedsize="537">
                          <def id="mx.core:FlexBitmap" />
                          <pre id="flash.display:Bitmap" />
                          <dep id="flash.display:BitmapData" />
                          <dep id="AS3" />
                          <dep id="Error" />
                          <dep id="mx.utils:NameUtil" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.twoD.initializers:Position)" mod="1283190769000" size="1640" optimizedsize="867">
                          <dep id="AS3" />
                          <dep id="Math" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.behaviours:BehaviourArrayUtils)" mod="1289464578000" size="2063" optimizedsize="855">
                          <def id="org.flintparticles.common.behaviours:BehaviourArrayUtils" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="org.flintparticles.common.behaviours:Behaviour" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(com.chronogears.meteorminer:Assets_smallOre)" mod="1291412944000" size="1183" optimizedsize="698">
                          <dep id="com.chronogears.meteorminer:Assets_smallOre_dataClass" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.emitters:Emitter)" mod="1289466687000" size="10522" optimizedsize="4712">
                          <def id="org.flintparticles.common.emitters:Emitter" />
                          <dep id="org.flintparticles.common.actions:Action" />
                          <dep id="org.flintparticles.common.behaviours:BehaviourArrayUtils" />
                          <dep id="org.flintparticles.common.utils:FrameUpdater" />
                          <dep id="org.flintparticles.common.counters:ZeroCounter" />
                          <dep id="org.flintparticles.common.events:EmitterEvent" />
                          <dep id="org.flintparticles.common.events:ParticleEvent" />
                          <dep id="AS3" />
                          <dep id="org.flintparticles.common.activities:Activity" />
                          <dep id="org.flintparticles.common.initializers:Initializer" />
                          <dep id="org.flintparticles.common.counters:Counter" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.twoD.zones:Zone2D)" mod="1289466928000" size="1091" optimizedsize="348">
                          <def id="org.flintparticles.twoD.zones:Zone2D" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(com.chronogears.meteorminer:Ship)" mod="1299000696000" size="2310" optimizedsize="1516">
                          <pre id="com.chronogears.meteorminer:CgSprite" />
                          <dep id="org.flintparticles.common.initializers:ColorInit" />
                          <dep id="org.flintparticles.twoD.renderers:DisplayObjectRenderer" />
                          <dep id="com.chronogears.meteorminer:Assets" />
                          <dep id="org.flintparticles.common.counters:Random" />
                          <dep id="org.flintparticles.common.initializers:Lifetime" />
                          <dep id="org.flintparticles.common.actions:Fade" />
                          <dep id="org.flintparticles.twoD.zones:PointZone" />
                          <dep id="AS3" />
                          <dep id="org.flintparticles.twoD.actions:RandomDrift" />
                          <dep id="org.flintparticles.common.actions:Age" />
                          <dep id="flash.display:Bitmap" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.renderers:SpriteRendererBase)" mod="1289464578000" size="4041" optimizedsize="2044">
                          <def id="org.flintparticles.common.renderers:SpriteRendererBase" />
                          <pre id="org.flintparticles.common.renderers:Renderer" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder Burrito/sdks/4.5.0/frameworks/libs/flex.swc(mx.core:MovieClipLoaderAsset)" mod="1283910237250" size="2886" optimizedsize="1699">
                          <def id="mx.core:MovieClipLoaderAsset" />
                          <pre id="mx.core:IFlexAsset" />
                          <pre id="mx.core:MovieClipAsset" />
                          <pre id="mx.core:IFlexDisplayObject" />
                          <dep id="AS3" />
                          <dep id="flash.display:Loader" />
                          <dep id="flash.system:LoaderContext" />
                          <dep id="flash.system:ApplicationDomain" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.actions:Fade)" mod="1283190769000" size="1517" optimizedsize="652">
                          <dep id="AS3" />
                          <dep id="Math" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.initializers:Lifetime)" mod="1283190769000" size="1834" optimizedsize="737">
                          <dep id="AS3" />
                          <dep id="Math" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.actions:ActionBase)" mod="1289466180000" size="1407" optimizedsize="530">
                          <def id="org.flintparticles.common.actions:ActionBase" />
                          <pre id="org.flintparticles.common.actions:Action" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.initializers:InitializerBase)" mod="1289466285000" size="1505" optimizedsize="548">
                          <def id="org.flintparticles.common.initializers:InitializerBase" />
                          <pre id="org.flintparticles.common.initializers:Initializer" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(com.chronogears.meteorminer:Assets_meteor32)" mod="1291514211000" size="939" optimizedsize="340">
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(com.chronogears.meteorminer:MeteorMinerMain)" mod="1299011489000" size="1375" optimizedsize="653">
                          <dep id="com.chronogears.meteorminer:StarField" />
                          <dep id="AS3" />
                          <dep id="com.chronogears.meteorminer:GameMode" />
                          <dep id="flash.display:Sprite" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(com.chronogears.meteorminer:Assets_star)" mod="1291136354000" size="904" optimizedsize="332">
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(com.chronogears.meteorminer:Assets_largeOre_dataClass)" mod="1291412969000" size="849" optimizedsize="287">
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.initializers:ImageClass)" mod="1283190769000" size="1578" optimizedsize="642">
                          <dep id="AS3" />
                          <dep id="org.flintparticles.common.utils:construct" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder Burrito/sdks/4.5.0/frameworks/libs/flex.swc(mx.core:ByteArrayAsset)" mod="1283910237468" size="636" optimizedsize="298">
                          <def id="mx.core:ByteArrayAsset" />
                          <pre id="flash.utils:ByteArray" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(com.chronogears.meteorminer:Assets_mediumOre)" mod="1291412994000" size="1191" optimizedsize="701">
                          <dep id="AS3" />
                          <dep id="com.chronogears.meteorminer:Assets_mediumOre_dataClass" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder Burrito/sdks/4.5.0/frameworks/libs/flex.swc(mx.core:BitmapAsset)" mod="1283910237531" size="7196" optimizedsize="3798">
                          <def id="mx.core:BitmapAsset" />
                          <pre id="mx.core:FlexBitmap" />
                          <pre id="mx.core:ILayoutDirectionElement" />
                          <dep id="mx.core:IAssetLayoutFeatures" />
                          <dep id="AS3" />
                          <dep id="Math" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder Burrito/sdks/4.5.0/frameworks/libs/flex.swc(mx.core:IBorder)" mod="1283910237875" size="449" optimizedsize="153">
                          <def id="mx.core:IBorder" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="mx.core:EdgeMetrics" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder Burrito/sdks/4.5.0/frameworks/libs/flash-integration.swc(mx.core:mx_internal)" mod="1283910237562" size="196" optimizedsize="109">
                          <def id="mx.core:mx_internal" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.twoD.zones:PointZone)" mod="1283190769000" size="3138" optimizedsize="1483">
                          <pre id="org.flintparticles.twoD.zones:Zone2D" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="Math" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.twoD.particles:ParticleCreator2D)" mod="1289464578000" size="1334" optimizedsize="586">
                          <pre id="org.flintparticles.common.particles:ParticleFactory" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.particles:Particle)" mod="1283190769000" size="2561" optimizedsize="1263">
                          <def id="org.flintparticles.common.particles:Particle" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="flash.geom:ColorTransform" />
                          <dep id="flash.utils:Dictionary" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.events:EmitterEvent)" mod="1277967615000" size="918" optimizedsize="404">
                          <pre id="flash.events:Event" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.twoD.zones:RectangleZone)" mod="1283190769000" size="3958" optimizedsize="2103">
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="Math" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder Burrito/sdks/4.5.0/frameworks/libs/flash-integration.swc(mx.core:IAssetLayoutFeatures)" mod="1283910237593" size="4642" optimizedsize="867">
                          <def id="mx.core:IAssetLayoutFeatures" />
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="flash.geom:Matrix" />
                          <dep id="flash.geom:Matrix3D" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder Burrito/sdks/4.5.0/frameworks/libs/flex.swc(mx.utils:NameUtil)" mod="1283910243562" size="1780" optimizedsize="1097">
                          <def id="mx.utils:NameUtil" />
                          <pre id="Object" />
                          <dep id="mx.core:IRepeaterClient" />
                          <dep id="SecurityError" />
                          <dep id="flash.utils:getQualifiedClassName" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.events:UpdateEvent)" mod="1289345647000" size="956" optimizedsize="409">
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.twoD.particles:Particle2D)" mod="1286384355000" size="2100" optimizedsize="1088">
                          <pre id="org.flintparticles.common.particles:Particle" />
                          <dep id="AS3" />
                          <dep id="Math" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.twoD.renderers:DisplayObjectRenderer)" mod="1289464578000" size="2069" optimizedsize="1161">
                          <pre id="org.flintparticles.common.renderers:SpriteRendererBase" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.twoD.actions:Move)" mod="1283190769000" size="1068" optimizedsize="561">
                          <dep id="AS3" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder Burrito/sdks/4.5.0/frameworks/libs/flex.swc(mx.core:MovieClipAsset)" mod="1283910237609" size="1698" optimizedsize="929">
                          <def id="mx.core:MovieClipAsset" />
                          <pre id="mx.core:FlexMovieClip" />
                          <pre id="mx.core:IBorder" />
                          <dep id="AS3" />
                          <dep id="Math" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.twoD.zones:LineZone)" mod="1283190769000" size="4040" optimizedsize="1866">
                          <pre id="Object" />
                          <dep id="AS3" />
                          <dep id="Math" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.activities:Activity)" mod="1289466328000" size="939" optimizedsize="340">
                          <def id="org.flintparticles.common.activities:Activity" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(com.chronogears.meteorminer:Assets_smallOre_dataClass)" mod="1291412944000" size="849" optimizedsize="287">
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.actions:Age)" mod="1283190769000" size="1289" optimizedsize="615">
                          <def id="org.flintparticles.common.actions:Age" />
                          <dep id="org.flintparticles.common.energyEasing:Linear" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.counters:Counter)" mod="1283190769000" size="1269" optimizedsize="361">
                          <def id="org.flintparticles.common.counters:Counter" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.utils:interpolateColors)" mod="1283190769000" size="758" optimizedsize="289">
                          <dep id="Number" />
                          <dep id="AS3" />
                          <dep id="Math" />
                          <dep id="uint" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(com.chronogears.meteorminer:GameMode)" mod="1298993390000" size="1131" optimizedsize="524">
                          <dep id="AS3" />
                          <dep id="flash.ui:Mouse" />
                          <dep id="com.chronogears.meteorminer:Ship" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.energyEasing:Linear)" mod="1283190769000" size="1087" optimizedsize="367">
                          <def id="org.flintparticles.common.energyEasing:Linear" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.counters:ZeroCounter)" mod="1283190769000" size="1304" optimizedsize="473">
                          <def id="org.flintparticles.common.counters:ZeroCounter" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(com.chronogears.meteorminer:Assets_meteor64)" mod="1291514211000" size="939" optimizedsize="340">
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.events:ParticleEvent)" mod="1283190769000" size="1412" optimizedsize="741">
                          <def id="org.flintparticles.common.events:ParticleEvent" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.displayObjects:RadialDot)" mod="1283190769000" size="1760" optimizedsize="796">
                          <pre id="flash.display:Shape" />
                          <dep id="flash.display:GradientType" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.initializers:AlphaInit)" mod="1283190769000" size="1904" optimizedsize="796">
                          <dep id="AS3" />
                          <dep id="Math" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerAir/src/MeteorMinerAir.as" mod="1299012535000" size="859" optimizedsize="412">
                          <def id="MeteorMinerAir" />
                          <pre id="com.chronogears.meteorminer:MeteorMinerMain" />
                          <dep id="AS3" />
                          <dep id="trace" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder Burrito/sdks/4.5.0/frameworks/libs/flex.swc(mx.core:FlexMovieClip)" mod="1283910237500" size="972" optimizedsize="571">
                          <def id="mx.core:FlexMovieClip" />
                          <pre id="flash.display:MovieClip" />
                          <dep id="AS3" />
                          <dep id="Error" />
                        </script>
                        <script name="/Applications/Adobe Flash Builder Burrito/sdks/4.5.0/frameworks/libs/flash-integration.swc(mx.core:ILayoutDirectionElement)" mod="1283910237671" size="838" optimizedsize="239">
                          <def id="mx.core:ILayoutDirectionElement" />
                          <pre id="Object" />
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.common.utils:construct)" mod="1283190769000" size="1152" optimizedsize="723">
                          <dep id="AS3" />
                          <dep id="Class" />
                          <dep id="Array" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(org.flintparticles.twoD.actions:DeathZone)" mod="1283190769000" size="1776" optimizedsize="844">
                          <dep id="AS3" />
                        </script>
                        <script name="/Users/jfbilodeau/Documents/Projects/Chronogears/flash/workspace/MeteorMinerLib/bin/MeteorMinerLib.swc(com.chronogears.meteorminer:Assets)" mod="1299011480000" size="1325" optimizedsize="561">
                          <pre id="Object" />
                          <dep id="com.chronogears.meteorminer:Assets_smallOre" />
                          <dep id="com.chronogears.meteorminer:Assets_meteor16" />
                          <dep id="com.chronogears.meteorminer:Assets_ship" />
                          <dep id="AS3" />
                          <dep id="com.chronogears.meteorminer:Assets_meteor32" />
                          <dep id="com.chronogears.meteorminer:Assets_mediumOre" />
                          <dep id="com.chronogears.meteorminer:Assets_star" />
                          <dep id="com.chronogears.meteorminer:Assets_largeOre" />
                          <dep id="com.chronogears.meteorminer:Assets_meteor128" />
                          <dep id="com.chronogears.meteorminer:Assets_meteor64" />
                        </script>
                      </scripts>
                      <external-defs>
                        <ext id="flash.system:ApplicationDomain" />
                        <ext id="flash.geom:Matrix" />
                        <ext id="AS3" />
                        <ext id="flash.geom:Matrix3D" />
                        <ext id="Error" />
                        <ext id="flash.geom:ColorTransform" />
                        <ext id="flash.display:DisplayObject" />
                        <ext id="flash.accessibility:AccessibilityProperties" />
                        <ext id="SecurityError" />
                        <ext id="Number" />
                        <ext id="flash.geom:Point" />
                        <ext id="flash.utils:getQualifiedClassName" />
                        <ext id="flash.utils:getTimer" />
                        <ext id="uint" />
                        <ext id="flash.utils:ByteArray" />
                        <ext id="Math" />
                        <ext id="Array" />
                        <ext id="flash.display:Bitmap" />
                        <ext id="Class" />
                        <ext id="flash.events:Event" />
                        <ext id="flash.display:BitmapData" />
                        <ext id="flash.display:GradientType" />
                        <ext id="flash.display:LoaderInfo" />
                        <ext id="flash.display:Shape" />
                        <ext id="flash.events:IEventDispatcher" />
                        <ext id="flash.geom:Rectangle" />
                        <ext id="flash.utils:Dictionary" />
                        <ext id="trace" />
                        <ext id="flash.events:EventDispatcher" />
                        <ext id="flash.display:IBitmapDrawable" />
                        <ext id="flash.ui:Mouse" />
                        <ext id="Object" />
                        <ext id="flash.display:MovieClip" />
                        <ext id="flash.display:DisplayObjectContainer" />
                        <ext id="flash.display:Sprite" />
                        <ext id="flash.display:Loader" />
                        <ext id="flash.display:Stage" />
                        <ext id="flash.system:LoaderContext" />
                        <ext id="flash.geom:Transform" />
                      </external-defs>
                    </report>
                    I know it's a lot to sieve through. I hope that helps.
                    Thanks again,
                    J-F
                    • 7. Re: Resources stored in SWC are stripped from the SWF
                      Flex harUI Adobe Employee
                      I didn't check them all, but the link-report shows that assets like ship and meteor16 are in the SWF.  How are you trying to access the embedded assets?
                      • 8. Re: Resources stored in SWC are stripped from the SWF
                        jfbilodeau Level 1
                        The ship (ship.png) is indeed in the swc, but doesn't get included in the air swf. I think the asset that shows in the link report is either the field from the Asset class, or if it's the actual bitmap, it's empty (0K). To answer your question, I use the asset within the Ship class, and instanciate that class from the air swf.
                        I can confirm that the bitmap is empty with a couple of trace statement showing that the size is indeed zero.
                        I validated the code by copying it in the Air project (no changes were made to the code), removing the reference to the swc, and running it. The asset loads correctly, and the size of the air swf is much bigger. Furthermore, the size of the bitmap is correct.
                        I'm starting to think that using the [Embed()] in AS3 may not be the best way to include assets in a swc. What do you think?
                        Thanks again for your time,
                        J-F
                        • 9. Re: Resources stored in SWC are stripped from the SWF
                          Ignore sizes in the link-report.  A PNG is wrapped by a class that is pretty
                          small, and a different SWF tag associates the class to the PNG file in the
                          SWF.
                          If you want, post the SWF.
                          • 10. Re: Resources stored in SWC are stripped from the SWF
                            jfbilodeau Level 1
                            Erm...stupid question, but how do I attach a file to a post?
                            • 11. Re: Resources stored in SWC are stripped from the SWF
                              So far, I've found that attaching via email doesn't work, but going to the
                              forum thread via the browser and replying there gives me the option to
                              attach that did work.
                              • 12. Re: Resources stored in SWC are stripped from the SWF
                                jfbilodeau Level 1
                                Hey harUI,
                                I'm sorry to say I couldn't find the 'attach' command on the forum. I've uploaded the swc and swf to:
                                www.chronogears.com/static/Archive.zip
                                In the archive you'll find:
                                MeteorMinerAir.swf - Contains the compiled application that is causing me headache. The code works, but the ship asset does not display.
                                MeteorMinerLib.swc - The library that contains Assets.as, Ship.as and ship.png. This is merged with MeteorMiner.swf.
                                MeteorMinerAirWorking.swf - I compiled this one by copying the code and assets into the MeteorMinerAir.swf, and removing the reference to the swc. No changes were made to the code. This one loads the ship.png asset correctly.
                                I really appreciate the time you are putting into this. Thanks again!
                                J-F
                                • 13. Re: Resources stored in SWC are stripped from the SWF
                                  If you start a reply, there should be an attach option when typing the
                                  reply.
                                  Anyway, I looked at the SWFs.  I confirmed that the assets are not in the
                                  SWF that is not working.  File a bug at bugs.adobe.com/jira if you can, with
                                  your test case code.
                                  I did note that it appears that the main app is a .AS file, not a .MXML
                                  file.  It would be interesting if you could try having the main app be an
                                  MXML file.  There have been other bugs reported against main apps based on
                                  .AS files.
                                  • 14. Re: Resources stored in SWC are stripped from the SWF
                                    jfbilodeau Level 1
                                    Thanks for all your help harUI.
                                    As you suggested, I've filed a bug: https://bugs.adobe.com/jira/browse/SDK-29833
                                    I'll mark this thread as solved. Have a great weekend!
                                    J-F
