1 Reply Latest reply on Mar 1, 2011 9:20 AM by Colin Brougham
    Universal deletion of an effect (multiple clips)
    AdamJRead
      I have applied an effect to a whole load (150+) clips.  I now want to delete this effect.
      I know it's possible to select multiple clips and apply an effect....  Is it possible to achieve the reverse?
      I really don't want to have to select each clip and delete fx manually.
      Thanks in advance
      ADAM
      InterMedia
        • 1. Re: Universal deletion of an effect (multiple clips)
          Colin Brougham Level 6
          Select the clips and go to Clip > Remove Effects. You'll be presented with a dialog of checkboxes to remove Motion, Opacity, Video Filters, Audio Filters and Audio Volume, in any combination. Note that you can't specify just a single effect or filter to remove, so if you have multiple video effects, I suggest copying the ones you want to keep first, then removing all video filters, and then pasting to the same selection.
