0 Replies Latest reply on Mar 1, 2011 2:35 PM by Binh T
    ORM and DB2 date conversion problem
    Binh T Level 1
      I'm testing an orm application in a test environment with coldfusion 9 for windows and db2 for the IBM system i.
      I'm running into several problems with data conversion from orm to db2.
      The current problem is sending dates to db2.
      I keep getting the following error message:
      [SQL0180] Syntax of date, time, or timestamp value not valid.
      I looked in the hibernate log and I see the following sql bind statement:
      03/01 15:38:18 [web-12] HIBERNATE DEBUG - binding '28 February 2011' to parameter: 7
      In the coldfusion page, I am setting the date using the CreateODBCDate function within the object setter's parameter before the ormflush().
      Is the date format set by coldfusion or hibernate?
      I don't know if the above date format is the problem because it seems to work one minute and then the next it doesn't.
      I would appreciate any help with this problem.
