1 Reply Latest reply on Apr 30, 2011 12:44 PM by Hazar Hiasat
    Can you draw chart in flex displaying Arabic Text?!
    Hazar Hiasat
      Dears,
      I am having a problem in drawing a flex chart with arabic data, the data get flipped !!!
      And here is the code...
      <?xml version="1.0"?>
      <!-- http://blog.flexexamples.com/2007/11/07/creating-a-simple-piechart-in-flex-using-actionscr ipt/ -->
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
              layout="vertical"
              verticalAlign="middle"
              backgroundColor="white"
              creationComplete="init();">
          <mx:Script>
              <![CDATA[
                  import mx.charts.PieChart;
                  import mx.charts.series.PieSeries;
                  import mx.collections.ArrayCollection;
                  private var medalsAC:ArrayCollection;
                  private var chart:PieChart;
                  private var series:PieSeries;
                   * Create and return a simple ArrayCollection to
                   * use as a data provider.
                  private function getDataProvider():ArrayCollection {
                      var arr:Array = [];
                      arr.push({label:" العينة الاولى ", data:30});
                      arr.push({label:"العينة الثانية", data:10});
                      return new ArrayCollection(arr);
                  private function init():void {
                      medalsAC = getDataProvider();
                      /* Define pie series. */
                      series = new PieSeries();
                      series.nameField = "label";
                      series.field = "data";
                      /* Remove default dropshadow filter. */
                      series.filters = [];
                      /* Define pie chart. */
                      chart = new PieChart();
                      chart.percentWidth = 100;
                      chart.percentHeight = 100;
                      chart.showDataTips = true;
                      chart.dataProvider = medalsAC;
                      chart.series = [series];
                      /* Add chart to the display list. */
                      addChild(chart);
          </mx:Script>
      </mx:Application>
