6 Replies Latest reply on Mar 3, 2011 1:56 AM by tatiana1
    getPixel of a dynamically loaded image
    tatiana1 Level 1
      Hi all, I'm trying to create a color picker using getPixel. It works wonderfully as long as the image is loaded from a local drive. When I try loading it from the server (a subdirectory on the same server as the SWF), the loaded image doesn't get drawn when I use the draw command. It draws a white rectangle and when I use getPixel, I always get 0xFFFFFF. I also have system.Security.allowDomain("http.//www.mysite.com") in my script, but nothing works. Any ideas?
        • 1. Re: getPixel of a dynamically loaded image
          narmathadevi Level 1
          Hi
            You can create like this BitmapData and you can get
          var myBitmapData:BitmapData = new BitmapData(100,100, false, 0xFF0000);
          • 2. Re: getPixel of a dynamically loaded image
            tatiana1 Level 1
            The solution you suggest doesn't work...This is my code:
            import flash.display.BitmapData;
            System.security.allowDomain("http://www.mysite.com/");
            _root.createEmptyMovieClip("pal", 1);
            var mclListener:Object = new Object();
            mclListener.onLoadInit = function(mc:MovieClip) {
                 var myBitmapData:BitmapData = new BitmapData(mc._width, mc._height);
                 myBitmapData.draw(mc);
            var image_mcl:MovieClipLoader = new MovieClipLoader();
            image_mcl.addListener(mclListener);
            image_mcl.loadClip("http://www.mysite.com/palette.png", _root.pal);
            var mouseListener:Object = new Object();
            mouseListener.onMouseMove = function() {
                 tece(myBitmapData.getPixel(_root._xmouse, _root._ymouse));
            Mouse.addListener(mouseListener);
            It works if I load an image from my local drive, but not if I load it from the server...
            • 3. Re: getPixel of a dynamically loaded image
              Hi
              System.security.allowDomain("http://www.helpexamples.com/flash/images/image2.jpg");
              var mc:MovieClip = this.createEmptyMovieClip("mc", this.getNextHighestDepth());
              var listenerObj:Object = new Object();
              listenerObj.onLoadInit = function (target_mc:MovieClip):Void
                  target_mc._x = (Stage.width - target_mc._width) / 2;
                  target_mc._y = (Stage.height - target_mc._height) / 2;
                  var myBitmapData:BitmapData = new BitmapData(mc._width, mc._height, false, 0xFF0000);
                   trace(myBitmapData.getPixel(target_mc._x, target_mc._y).toString(16));
              image_mcl.addListener(listenerObj);
              image_mcl.loadClip("http://www.helpexamples.com/flash/images/image2.jpg", _root.mc);
                First you can get pixel value inside onLoadInit and then try to draw rectangle
              Otherwise you can try
              hitTest Method
              Message was edited by: narmathadevi
              • 4. Re: getPixel of a dynamically loaded image
                tatiana1 Level 1
                Hi and thanks for your reply. Didn't work and I can't figure out why. Would hitTest tell me the color of the pixel I'm touching? Do you have an example?
                • 5. Re: getPixel of a dynamically loaded image
                  import flash.geom.Point;
                  var myBitmapData:BitmapData = new BitmapData(100, 80, false, 0x00CCCCCC);
                  var mc_1:MovieClip = this.createEmptyMovieClip("mc", this.getNextHighestDepth());
                  mc_1.attachBitmap(myBitmapData, this.getNextHighestDepth());
                  var mc_2:MovieClip = createRectangle(20, 20, 0xFF0000);
                  var destPoint:Point = new Point(myBitmapData.rectangle.x, myBitmapData.rectangle.y);
                  var currPoint:Point = new Point();
                  mc_1.onEnterFrame = function() {
                      currPoint.x = mc_2._x;
                      currPoint.y = mc_2._y;
                      if(myBitmapData.hitTest(destPoint, 255, currPoint)) {
                          trace(">> Collision at x:" + currPoint.x + " and y:" + currPoint.y);
                  mc_2.startDrag(true);
                  function createRectangle(width:Number, height:Number, color:Number):MovieClip {
                      var depth:Number = this.getNextHighestDepth();
                      var mc:MovieClip = this.createEmptyMovieClip("mc_" + depth, depth);
                      mc.beginFill(color);
                      mc.lineTo(0, height);
                      mc.lineTo(width, height);
                      mc.lineTo(width, 0);
                      mc.lineTo(0, 0);
                      return mc;
                  • 6. Re: getPixel of a dynamically loaded image
                    tatiana1 Level 1
                    Thank youuuuu!!!! That tells me the coordinates where I hit the palette. How do I get the pixel color value of the x,y position I'm touching?
