20 Replies Latest reply on Mar 7, 2011 10:06 AM by Peter Grainge
    View CHM.HTML Pages in App
    orlyz
      Platform: Robohelp 8 from TCS1.0 (RH8 is an upgrade from RH7)
      Problem: HTML pages not opening when
      called from the CHM in the application.
      The application is calling the chm using MSITS.
      In the past, when the CHM was created using Robohelp 6 - the CHM opened
      fine (still today if you open the old CHM in the same app - all works fine).
      Now, however, that we're using the Adobe Technical Suite, with Robohelp8
      (upgraded from RH7) based on the same FM sources - then the HTML pages don't open in the
      application.
      Again, the CHM file is fine on its own - i.e. when opened from the C drive.
      The application has not changed (it opens the old CHM file fine) - so I can't really blame the application we're
      using.
      It must be some parameter or switch that is preventing the CHM file from opening
      properly in the application. Can anyone suggest a solution?
      I will stress again, that the files are all placed on the user's PC -
      Application and CHM file. There are no network issues here - and we cannot expect our customers to tweak their HKEY regs.
      Thanks for any help/ideas
