20 Replies Latest reply on Apr 13, 2011 1:58 AM by dinko_ivanov
    Editable Spark DataGrid
    Zolotoj Level 3
      1. How can I get rid of a TextInput editor border that appears when I click on a cell before I start typing in?
      2. When I finish typing and move to another cell the text being just typed disappears. What do I need to do to fix that?
        • 1. Re: Editable Spark DataGrid
          Darrell Loverin Level 4
          1. Create a subclass of the DefaultGridItemEditor. Override the prepare() method and customize the editor however you wish.
          2. Put a break point on GridItemEditor.save() and see what happens.
          -Darrell
          • 2. Re: Editable Spark DataGrid
            Zolotoj Level 3
            That's what I am doing. I am having a strange behavior though. First, I have to click twice on the cell to initiate an editing session. Second, when I leave the cell the entered text disappears, clicking back on the cell will show the text. Any ideas?
            • 3. Re: Editable Spark DataGrid
              Zolotoj Level 3
              does not work
              here is a custom editor:
              package
                   import spark.components.gridClasses.DefaultGridItemEditor;
                   import spark.components.gridClasses.IGridItemEditor;
                   public class testEditor extends DefaultGridItemEditor implements IGridItemEditor
                        public function testEditor()
                             //TODO: implement function
                             super();
                        override public function prepare():void
                             setStyle("borderVisible", false);
                             trace(value);
                        override public function save():Boolean
                             trace(value);
                             return false;
              here is datagrid:
              <s:DataGrid requestedRowCount="2" fontSize="11" sortableColumns="false"
                                            id="cars" rowHeight="22" resizableColumns="false" editable="true">
                                  <s:columns>
                                       <s:ArrayList>
                                            <s:GridColumn dataField="initial" headerText="Initial">
                                                 <s:itemRenderer>
                                                      <fx:Component>
                                                           <s:GridItemRenderer>
        <s:layout>
        <s:VerticalLayout paddingLeft="1"
        verticalAlign="middle"/>
        </s:layout>
        <local:gridTextInput id="txtCarInitial" restrict="a-zA-Z" width="50"
        bindPropertyName="initial"/>
                                                           </s:GridItemRenderer>
                                                      </fx:Component>
                                                 </s:itemRenderer>
                                                 <s:itemEditor>
                                                      <fx:Component>
                                                           <s:GridItemEditor>
        <local:testEditor id="valueDisplay" width="50"/>
                                                           </s:GridItemEditor>
                                                      </fx:Component>
                                                 </s:itemEditor>
                                            </s:GridColumn>
              Problems.
              1. Have to click twice on the cell to start editing
              2. when leave text disappears
              3. save does not fire
              4. prepare does not fire
              • 4. Re: Editable Spark DataGrid
                An editing session is only initiated on a previously selected cell. If you would like to have an option to start an edit session on any click in a cell then please write a bug and post a link to it here. You can get the single click behavior by adding event listeners to the data grid that look like this:
                            private var mouseDownRowIndex:int;
                            private var mouseDownColumnIndex:int;
                            protected function dataGrid_gridMouseDownHandler(event:GridEvent):void
                                    mouseDownRowIndex = event.rowIndex;
                                    mouseDownColumnIndex = event.columnIndex;
                            protected function dataGrid_gridMouseUpHandler(event:GridEvent):void
                                if (event.rowIndex == mouseDownRowIndex &&
                                    event.columnIndex == mouseDownColumnIndex &&
                                    event.column.editable &&
                                    !event.grid.dataGrid.itemEditorInstance)
                                    trace("start item editor on single click");
                                    event.grid.dataGrid.startItemEditorSession(event.rowIndex, event.columnIndex);
                Sounds like the dataprovider is not being updated. The itemUpdated() method is called on the dataprovider in the GridItemEditor.save() method. See if you are getting there.
                -Darrell
                • 5. Re: Editable Spark DataGrid
                  Type changing this:
                                                    <s:itemEditor>
                                                          <fx:Component>
                                                               <s:GridItemEditor>
                                                               </s:GridItemEditor>
                                                          </fx:Component>
                                                     </s:itemEditor>
                  to this:
                                                    <s:itemEditor>
                                                          <fx:Component>
                                                          </fx:Component>
                                                     </s:itemEditor>
                  -Darrell
                  • 6. Re: Editable Spark DataGrid
                    Zolotoj Level 3
                    Error:
                    id attribute is not allowed on the root tag of a component
                    • 7. Re: Editable Spark DataGrid
                      remove the id attribute.
                      • 8. Re: Editable Spark DataGrid
                        Zolotoj Level 3
                        Yes, I did it. Here is my code:
                        Item Editor
                        package
                                       super();
                                  /*override public function prepare():void
                                       //trace(value);
                                       data[column.dataField]
                                       trace(value);
                                       trace(data[column.dataField]);
                                       return false;
                        Prepare is commented out because it will fail at run-time.
                        Save will show new data, but data[column.dataField] is empty -  cannot update dataProvider.
                        A little bit more help, please?
                        • 9. Re: Editable Spark DataGrid
                          Zolotoj Level 3
                          I wasn't exactly correct.
                          after data[column.dataField] = value; trace(data) will show data with new value but the cell still looses its text.
                          • 10. Re: Editable Spark DataGrid
                            Zolotoj Level 3
                            <See if you are getting there
                            How would I do that?
                            • 11. Re: Editable Spark DataGrid
                              I don't understand why you are overriding the save() method. Your save() doesn't call itemUpdated() on the dataProvider. Why are you returning  "false" from saved()? Is the data in your cell editor saved if you comment out your save() method?
                              -Darrell
                              • 12. Re: Editable Spark DataGrid
                                Set a break point in GridItemEditor.save().  Step thru the code to see what happens.
                                -Darrell
                                • 13. Re: Editable Spark DataGrid
                                  Zolotoj Level 3
                                  The save method has to return something.
                                  I am using Save according to this while the method's signature is different:
                                  <s:itemEditor>
                                      <fx:Component>
                                       <s:DefaultGridItemEditor>
                                           <fx:Script>
                                            <![CDATA[
                                                override public function save():void
                                                    data.dataField = myValueConverter(value);
                                           </fx:Script>
                                       </s:DefaultGridItemEditor>
                                      </fx:Component>
                                  </s:itemEditor>
                                  from Spark DataGrid Editing - Functional and Design Specification.
                                  • 14. Re: Editable Spark DataGrid
                                    Zolotoj Level 3
                                    Ok, here is my Save method:
                                                return true;
                                    I see that trace(dataProvider) is showing entered data, but the cell loses its text on losing focus.
                                    • 15. Re: Editable Spark DataGrid
                                      Zolotoj Level 3
                                      Ok, here is my column definition which would work if I remove custom item renderer:
        <!--<s:itemRenderer>
        <fx:Component>
        <s:layout>
        </s:layout>
        <s:TextInput id="txtCarInitial" restrict="a-zA-Z" width="50"/>
        </fx:Component>
        </s:itemRenderer>-->
        <s:itemEditor>
        <fx:Component>
        <local:testEditor width="50"/>
        </fx:Component>
        </s:itemEditor>
                                                              </s:GridColumn>
                                      Do I need a custom renderer? Will a custom editor show my data as well?
                                      • 16. Re: Editable Spark DataGrid
                                        I modified your GridItemRenderer in a couple of ways:
                                        1. First, the GridItemRenderer does not know which component to put the data in. So I added a labelDisplay property.
                                                           <s:itemRenderer>
        <fx:Component>
        <s:GridItemRenderer labelDisplay="{txtCarInitial}" >
        <s:layout>
        </s:layout>
        <s:Label id="txtCarInitial" width="50"/>
        </fx:Component>
                                                            </s:itemRenderer>
                                        2. The component in the labelDisplay must be of type TextBase so I change the TextInput component to a Label.
                                        Hope that helps,
                                        -Darrell
                                        • 17. Re: Editable Spark DataGrid
                                          Zolotoj Level 3
                                          I think I am going to have no item renderer at all.
                                          <s:GridColumn dataField="initial" headerText="Initial" width="50">
                                                   <s:itemEditor>
                                                          <fx:Component>
                                                               <local:gridTextItemEditor/>
                                                           </fx:Component>
                                                     </s:itemEditor>
                                          < /s:GridColumn>
                                          package
                                               import flash.events.KeyboardEvent;
                                               import spark.components.DataGrid;
                                               import spark.components.TextArea;
                                               import spark.components.gridClasses.GridColumn;
                                               public class gridTextItemEditor extends TextArea implements IGridItemEditor
                                                    private var _column:GridColumn;
                                                    private var _data:Object;
                                                    public function gridTextItemEditor()
                                                         super();
                                                    public function get dataGrid():DataGrid
                                                         return null;
                                                    public function get column():GridColumn
                                                         return _column;
                                                    public function set column(value:GridColumn):void
                                                         _column = value;
                                                    public function get columnIndex():int
                                                         return 0;
                                                    public function get rowIndex():int
                                                         return 0;
                                                    public function set rowIndex(value:int):void
                                                         addEventListener("keyDown", onEnter);
                                                         height = DataGrid(owner).rowHeight;
                                                         text = data[column.dataField];
                                                         x += 2;
                                                         y += 2;
                                                         selectRange(0, 0);
                                                    public function discard():void
                                                         data[column.dataField] = text;
                                                         DataGrid(owner).validateNow();
                                                         return true;
                                                    public function get data():Object
                                                         return _data;
                                                    public function set data(value:Object):void
                                                         _data = value;
                                                    private function onEnter(event:KeyboardEvent):void
                                                         trace(event.keyCode);
                                                         if (event.charCode == 13)
                                                              event.preventDefault();
                                          There are a few very, very annoying things are happening. When I select a cell for editing, the whole text is getting highlighted. Additional clicking will not cancel highlighting, so I had to implement selectRange(0, 0);. Why data in the cell has to be selected at all? For easy deletion? By the way, I am using TextArea because selectRange(0, 0) will not work for TextInput. And that creates another problem: pressing Enter with TextInput will stop editing session and move a cursor to the next tab stop, but not with TextArea. After pressing the Enter it will create a new line inside of the control.Unfortunately, my code onEnter does not work because when I press on Enter it's not getting into the event listener. All I am trying to do is to create a robust editable DataGrid with a minimum of code. It looks like the new DataGrid is not meant to be too easy.
                                          • 18. Re: Editable Spark DataGrid
                                            dinko_ivanov Level 1
                                            Hello guys,
                                            Today I installed Flex SDK 4.5 and I see that Spark DataGrid control is available there. I cannot find though IGridItemEditor or DefaultGridItemEditor classes. I also get an error when I use the s:itemEditor tag: -Could not resolve <s:itemEditor> to a component implementation.
                                            Could you help please?
                                            Kind Regards,
                                            Dinko
                                            • 19. Re: Editable Spark DataGrid
                                              There are no IGridDataEditor or DefaultGridData classes. I think you mean IGridItemEditor and DefaultGridItemEditor.
                                              <s:itemEditor> is not a component, it is a property on DataGrid and GridColumn.
                                              Below is a simple example that shows how to use declare item editors. Declaring <s:DefaultGridItemEditor> in the third column is not necessary since it is the default editor. I just put it in for demonstration purposes.
                                              This is a simple cell editor to demonstrate how to use cell editors.
                                              <s:Application
                                                  xmlns:fx="http://ns.adobe.com/mxml/2009"
                                                  xmlns:s="library://ns.adobe.com/flex/spark">
                                                  <s:DataGrid id="dataGrid"  left="10" right="10" editable="true">
                                                      <s:columns>
                                                          <s:ArrayList>
                                                              <s:GridColumn dataField="key" headerText="Key" editable="true"/>
                                                              <s:GridColumn dataField="name" headerText="Name" />
                                                              <s:GridColumn dataField="price" headerText="Price">
        <s:itemEditor>
        <fx:Component>
        <s:DefaultGridItemEditor/>
        </fx:Component>
        </s:itemEditor>
                                                              </s:GridColumn>
                                                              <s:GridColumn dataField="call" headerText="Rating" editable="true">
        <s:itemEditor>
        <fx:Component>
        <s:ComboBoxGridItemEditor>
        <s:dataProvider>
        <s:ArrayList>
        <fx:int>1</fx:int>
        <fx:int>2</fx:int>
        <fx:int>3</fx:int>
        <fx:int>4</fx:int>
        <fx:int>5</fx:int>
        </s:ArrayList>
        </s:dataProvider>
        </s:ComboBoxGridItemEditor>
        </fx:Component>
        </s:itemEditor>
                                                              </s:GridColumn>
                                                          </s:ArrayList>
                                                      </s:columns>
                                                      <s:ArrayCollection>
                                                          <s:DataItem key="1000" name="Abrasive" price="100.11" call="4"/>
                                                          <s:DataItem key="1001" name="Brush" price="110.01" call="3"/>
                                                          <s:DataItem key="1002" name="Clamp" price="120.02" call="4"/>
                                                          <s:DataItem key="1003" name="Drill" price="130.03" call="4"/>
                                                          <s:DataItem key="1004" name="Epoxy" price="140.04" call="5"/>
                                                          <s:DataItem key="1005" name="File" price="150.05" call="1"/>
                                                          <s:DataItem key="1006" name="Gouge" price="160.06" call="2"/>
                                                          <s:DataItem key="1007" name="Hook" price="170.07" call="4"/>
                                                          <s:DataItem key="1008" name="Ink" price="180.08" call="5"/>
                                                          <s:DataItem key="1009" name="Jack" price="190.09" call="4"/>
                                                      </s:ArrayCollection>
                                                  </s:DataGrid>
                                              </s:Application>
                                              -Darrell
                                              • 20. Re: Editable Spark DataGrid
                                                Hello Darrell,
                                                Thanks for the hint!
                                                I did what you proposed. Initially I got "Could not resolve <s:ComboBoxGridItemEditor> to a component implementation." error. The problem was that I was using the Flex Hero 4.5 Milestone build from Oct 2010. I installed the latest Flex Hero Build from Thu Feb 3, 2011 and the class is resolved. I had to fix some compilation compatibility problems with some missing skin states (normalWithPrompt and disabledWithPrompt).
                                                Then I stuck to a problem that I could not launch the application from within the Flash Builder (I'm using FB 4). I found some usefull info here http://forums.adobe.com/thread/787400. I had to change the <flex sdk location>/frameworks/flex-config.xml to use swfVersion 10 instead of 11: (<swf-version>10</swf-version>). I also installed the latest 2.6 AIR runtime, and changed the NS to <application xmlns="http://ns.adobe.com/air/application/2.5"> in my flex application XML descriptor (2.6 is not officially released, so use 2.5). Finally I had to add an additional <versionNumber>2.5</versionNumber> and now I'm able to start my AIR application with the latest flex SDK build using Flash Builder 4.
                                                Thanks again and regards!
                                                Dinko
