0 Replies Latest reply on Mar 2, 2011 11:26 AM by ADEMacUser
    ADE Setup assistant activation.dat
    ADEMacUser
      Hi!
      I work in a school environment and I'm trying to distribute the volume license of ADE on Macs with setup assistant already run.
      I see that I need to capture 2 files - manifest.xml and activation.dat. However, seems like activation.dat is tied to a hardware? I cannot reuse the file although I'm only activating "Don't Authorize Computer". bummer!
      Is there a work around to stomp setup assistant and let the students run it later? I can run a unix/command line version of the assistant if you have one. Do you have one such alternative?
      Thanks in advance for your response!
