2 Replies Latest reply on May 18, 2011 9:53 PM by snkd
    Session in Flex
    snkd Level 1
      You can Use the following class as a session in flex..
      [Bindable]
      private var session:Session = Session.getInstance();
      How to insert data to session
      session.setAttribute('username','sanka')
      How to retrive data from session
      var userName:String=session.getAttribute('username');
      http://dl.dropbox.com/u/7375335/Session.as
      package model
          import flash.utils.Dictionary;
          [Bindable]
           * @author Sanka Senavirathna
           *<p>
           *    Conforms to Singleton Design Pattern.
           *     </p>
           *    <p>
           *        Session.getInstance().getAttribute(key)
           *        Session.getInstance().setAttribute(key,value)
           * Code example for client
           [Bindable]
           session.getAttribute('name')
           *    </p>
          public class Session
              private static var instance:Session = new Session();
              private var dic:Dictionary=new Dictionary(); // keep user session
              public function Session()
                  if (instance != null) { throw new Error('Cannot create a new instance.  Must use Session.getInstance().') }
               * This Session is a Dictionary that keep key value pairs.Key can be object and value can be object.
               * [Bindable]
               * private var session:Session = Session.getInstance();
               * @langversion ActionScript 3.0
               * @playerversion Flash 8
               * @see getAttribute
               * @see setAttribute
              public static function getInstance():Session
                  return instance;
               * [Bindable]
               * <p>example
               * session.setAttribute('username','sanka')
               *</p>
               * @param key Describe key here.
               * @param value Describe value here.
               * @see getAttribute
              public function setAttribute(key:*,value:*):void
                  dic[key]=value;
               * [Bindable]
               * <p>example
               * var userName:String=Session.getInstance().getAttribute('username');
               *</p>
               * @param param1 Describe key here.
               * @see setAttribute
              public function getAttribute(key:*):*
                  return dic[key];
        • 1. Re: Session in Flex
          snkd Level 1
          I think This will help you to keep your shaired data in single place.this will optimize your program by
          1. reducing database hits,
          2. reducing Server hits
          Onece you retrive the data then put it into session (flex) and retrive it when you need..For example username in system.when user logged successfully
          put the user object in to session and hide the login component.then pop-up your other component.But you can access the user data from session by using
          var user:User=Session.getInstance().getAttribute('user'); something like that.
          Hope this will help you.
          enjoy
          happy cording
