Should be easy, but I can't figure it out. If I simply want to have the same pre-edited clip play over and over again, how do I do that without having to recut and edit it each time from the original captured video?
One easy way is to Select the Clip on the Timeline, then do Ctrl+C (Copy), and then Ctrl+V (Paste) however many times you wish.
Another way is to Dbl-click on the Clip in the Timeline, to Open it, with the In & Out Points, and drag from there, as many times as you wish.
