1 Reply Latest reply on Jun 20, 2007 12:25 PM by Newsgroup_User
    Global Variables
    Fen4554
      Hi guys,
      So here's the thing. I have a number of nested movie clips, 8 clips, each having 3. At the bottom of each, there is a common clip that is waiting to play when it sees the correct flag. But for whatever reason, Something as simple as:
      onEnterFrame = function () {
      if (_global.go == 2) {
      gotoAndPlay(1);
      Refuses to work. On the main stage, I have this:
      _global.go = 0;
      btn.onRelease = function() {
      _global.go = 2;
      This is just a stipped down verion of what I'm trying to do while I debug. WHAT am I doing wrong here?
      Thanks~
        • 1. Re: Global Variables
          Level 7
          Without seeing your fla file it is hard to troubleshoot the error.
          My initial thought is that you need to make sure that you are declaring the
          variable before checking its value. Also, on the onEnterFrame, where is the
          gotoAndPlay(1) going? Do you mean this.gotoAndPlay(1)?
          Dan Mode
          --> Adobe Community Expert
          *Flash Helps* http://www.smithmediafusion.com/blog/?cat=11
          *THE online Radio* http://www.tornadostream.com <--check this
          *Must Read* http://www.smithmediafusion.com/blog
          "Fen4554" <webforumsuser@macromedia.com> wrote in message
          news:f5bnt4$ev7$1@forums.macromedia.com...
          > Hi guys,
          > play
          > simple as:
          > gotoAndPlay(1);
          > _global.go = 0;
          > _global.go = 2;
          > Thanks~
