4 Replies Latest reply on Mar 14, 2011 5:19 AM by mmosleh
    multiple rows display in PDF
    atwork1234
      I am new to Adobe Livecycle forms . I have a form developed which has to connect to  a java web service , I have gotten to the point where I have created a web service and a test form that calls it using wsdl data connection. I have a query that returns multiple rows and I have to  display those in the PDF , I tried returning it as an Java array and binding it to the table . I bound the cells to the attributes of the object but was not able to get all the data and the table does not dynamically grow.Also I saw that it can be done by returning the data in form of XML. I needed some direction in getting this done .Also I have gone through most of the link on this forum hence posting this one .
        • 1. Re: multiple rows display in PDF
          pguerett Level 6
          Acrobat only supports simple types so you will not be able to return an array. You can return a string of XML to a text field. Then load that xml into the dom and manipulate it for your own purposes. If the xml represents data to fill the form then bindings shoudl be enough and loading the xml into the dom will populate your form.
          Hope that helps
          Paul
          • 2. Re: multiple rows display in PDF
            atwork1234 Level 1
            Thanks , But I did create a java array object and bind it with a table , Put the
            table in a flowed subform and then check boxed the repeat for each data item . I
            have an inpyt and an button in the form too not on the subform . This supposedly
            should create a dynamic table . My web service returns two data items in the
            response
            I get the first set in the row 1 but it does not dymanically create row two .
            If I have two rows already created ,both these recods show up in their resp .
            columns
            I followed the  help that was under Working with data in tables and some other
            threads on this forum , I am not able to understand what I am doing wrong any
            help will be appreciated.
            Manisha
            I get the first record
            Regards
            Manisha Telang
            mtelang34@yahoo.com
            Tel-(609)275 6276
            • 3. Re: multiple rows display in PDF
              atwork1234 Level 1
              I wanted to post the return response that I get from the web service
              Regards
              Manisha Telang
              mtelang34@yahoo.com
              Tel-(609)275 6276
              • 4. Re: multiple rows display in PDF
                mmosleh Level 1
                Hi there, am really facing the same problem !!
                I created a process to read multi rows from Database and return the result in XML file.
                In my PDF after creating a data connection to this WSDL I found the XML filled with the Table data BUT I couldn't view this XML in a Table inside my PDF....
                Any Help !!
