1 Reply Latest reply on Mar 4, 2011 2:18 AM by Mylenium
    What could cause no propagation using Roto Brush Tool?
    thepopoman
      Also is it allowed to use masking while using the Roto Brush tool?
      Could the arrow colors be exacly the same as the gray of the background?
      I have gotten it to work on some other projects.After Effects no propagation.jpg
        • 1. Re: What could cause no propagation using Roto Brush Tool?
          Unlikely that you could tweak your UI brightness in such a way that it kills both grey tones at the same time, so this is a real issue of sorts. do you see any propagation status updated on teh info plaette? Please check that. If there is propagation, yet it does not show up in the viewer, it may be an issue with your footage. And no, you shouldn't use masks and RB at the same time. It may throw off RB completely. You would have to pre-compose or pre-render the RB layer and work based on that.
          Mylenium
