2 Replies Latest reply on Mar 4, 2011 10:58 AM by Flex harUI
    How to avoid multiple scrollbars when placing multiple lists in a vbox ?
    tuliptaurus Level 1
      Hi All ,
      Am using a flex application using flex builder 3 ...
      I need to display multiple lists one below the other with no scroll bars for the list with only the outer scrollbar visible.
      In other words , each list must display all of its children with no scroll bar. If i set the vertical scroll bar to "off" ,
      it just removes the vertical scrollbar so that the user is not able to scroll the list (rest of the children are not visible)
      I have attached a sample application to illustrate the problem I face right now....
      When the following application is run ,
      Present Behavior:
      2 scrollbars are visible , the outer vbox scrollbar and the inner list scrollbar(for each scrollbar)
      Expected Behavior:
      1 scrollbar should only be visible ie. the outer vbox scrollbar.
      Each list should display all of its children with no scrollbars.
      Application code:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" verticalScrollPolicy="off">
      <mx:VBox  width="40%" height="600" verticalScrollPolicy="on">
         <mx:List dataProvider="{dataProviderArray1}" width="100%" />
         <mx:List dataProvider="{dataProviderArray2}" width="100%" />
      </mx:VBox>
          <mx:ArrayCollection id="dataProviderArray1">
              <mx:source>
                  <mx:Object label="A............" data="1"/>
                  <mx:Object label="B............" data="2"/>
                  <mx:Object label="C............" data="3"/>
              </mx:source>
          </mx:ArrayCollection>
          <mx:ArrayCollection id="dataProviderArray2">
              <mx:source>
                  <mx:Object label="D............" data="3"/>
                  <mx:Object label="E............" data="4"/>
                  <mx:Object label="F............" data="5"/>
              </mx:source>
      </mx:Application>
        • 1. Re: How to avoid multiple scrollbars when placing multiple lists in a vbox ?
          Tanu Jain Level 2
          Hello,
          If you know the length of dataprovider and can specify the height in pixels for each list, then below mentioned code may help:
               <mx:Canvas width="40%" height="100%" horizontalScrollPolicy="off">
                  <mx:List id="l1" dataProvider="{dataProviderArray1}" width="100%" height="500"   />
                  <mx:List id="l2" y="{l1.y + l1.height  + 5}" height="300" dataProvider="{dataProviderArray2}" width="100%" />
                  <mx:List id="l3" y="{l2.y + l2.height  + 5}" height="300" dataProvider="{dataProviderArray1}" width="100%"/>
                  <mx:List  id="l4"  y="{l3.y + l3.height  + 5}" height="300" dataProvider="{dataProviderArray2}" width="100%" />
                  <mx:List  id="l5" y="{l4.y + l4.height  + 5}" height="300" dataProvider="{dataProviderArray1}" width="100%" />
                  <mx:List  id="l6" y="{l5.y + l5.height  + 5}" height="300"  dataProvider="{dataProviderArray2}" width="100%" />
               </mx:Canvas>
          Tanu
          • 2. Re: How to avoid multiple scrollbars when placing multiple lists in a vbox ?
            Flex harUI Adobe Employee
            I think you have to set rowCount on each list to the number of items in the
            dataProvider.
