1 Reply Latest reply on Mar 4, 2011 3:41 AM by Tanu Jain
    Dealing with arrays and labels
    Astrotsp
      Hey i'm quite new to flex and am running flash builder 4.
      I need help with this code and have no idea how close or wrong I am.
      The aim is to add 10 random numbers to an array and then display
      the array in a text area box.
      <s:Application
      xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="
      library://ns.adobe.com/flex/spark"
      xmlns:mx="
      library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
      <fx:Declarations>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      <s:TextInput x="342" y="169" id="ta_outPut"/>
      <fx:script>
      <![CDATA[
      var randNums: Array=[];
      var i: int=0;
      while (i < 10)
      randNums[i]=math.random(1,100);
      i++;
      ta_outPut.text = randNums;
      </fx:script>
      </s:Application>
        • 1. Re: Dealing with arrays and labels
          Tanu Jain Level 2
          In script tag, make a function and put all the code for random numbers generation and populating array inside it.Call this function on creationComplete      event of application.
                         xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600"
                         creationComplete="fun()">
                       <fx:Script>
                  <![CDATA[
                  var randNums:Array=[];
                  var i:int=0;
                  private function fun()
                      while (i < 10)
                          randNums[i]= Math.random();
                          i++;
                      ta_outPut.text = randNums.toString();
              </fx:Script>
          randNums is an array which can not be directly assigned to textArea's text. Hence use randNums.toString()
          Tanu
