3 Replies Latest reply on Mar 8, 2011 1:56 AM by Muppet Mark-QAl63s
    Photoshop droplets don't work after file.copy();
    mkeatley17 Level 1
      I wrote a script to backup all of my files in a directory, like this
      fileObj = File('~/Desktop/Vendor Swatches.app');
      fileObj.copy('~/Desktop/BACKUP/' + fileObj.name);
        I noticed that when it copies my Photoshop Droplets, they no longer work.  If you look at the attached image, you can see the file before and after copying.  The end file is also listed as "Application (Classic)".  Does anybody know why this is happening?  Or any way to prevent it?
      thanks!
        • 1. Re: Photoshop droplets don't work after file.copy();
          Muppet Mark-QAl63s Level 4
          I don't use File.copy() myself it creates a 'NEW' file which makes it pretty useless to me. My Retrospect back-ups would be never ending. It looks like form your images you are making a copy across from mounted server? From a personal point of view I would have the system do the copy/moving of files… Here are a few functions that may be of use to you… Copying files/folders you could do this with the shells 'cp' or 'ditto'
          Using cp…
          #target photoshop
          var source = Folder.selectDialog('Select a Folder to Copy from?');
          var dest = Folder.selectDialog('Select a Folder to Copy to?');
          if (source != null && dest != null) {
               var res = cpFiles(source, dest);
               alert(res);
          function cpFiles(sf,df) {
               var comm = 'cp ';
               var optns = '-R ';
               var sPath = "'" + sf.fsName + "/' ";
               var dPath = "'" + df.fsName + "'";
               var sh = comm + optns + sPath + dPath;
               var res = undefined;
               var sh = app.system(sh);
               !sh ? res = true : res = false;
               return res;
          And much the same using ditto…
          #target photoshop
               var res = dittoFiles(source, dest);
               alert(res);
          function dittoFiles(sf,df) {
               var comm = 'ditto ';
               var optns = '';
               return res;
          And as you mentioned back-up… here are a few things you could use before/after your process to store/back-up whichever…
          ZIP a folder…
          #target photoshop
          var source = Folder.selectDialog('Select a Folder to create ZIP From?');
          if (source != null) {
               var res = makeZIP(source);
               alert(res);
          function makeZIP(sf) {
               var comm = '/usr/bin/ditto ';
               // These should be default after 10.4 Tiger?
               var optns = '-c -k -rsrc --keepParent ';
               var sPath = "'" + sf.fsName + "' ";
               var dPath = "'" + sf.fsName + '.zip' + "'";
               return res;
          Disk Image a folder…
          #target photoshop
          var source = Folder.selectDialog('Select a Folder to create Disk Image From?');
               var res = makeDiskImage(source);
               alert(res);
          function makeDiskImage(sf) {
               var comm = 'hdiutil create ';
               var optns = '-srcfolder ';
               var dPath = "'" + sf.fsName + '.dmg' + "'";
               return res;
          And lastly TAR Archive a folder…
          #target photoshop
          var source = Folder.selectDialog('Select a Folder to create TAR Archive From?');
               var res = makeTAR(source);
               alert(res);
          function makeTAR(sf) {
               var comm = '/usr/bin/tar ';
               var optns = 'cjvf ';
               var dPath = "'" + sf.fsName + '.tbz' + "' ";
               var sPath = "'" + sf.fsName + "'";
               var sh = comm + optns + dPath + sPath;
               return res;
          They are for 'mac' and all expect a folder object or two…
          • 2. Re: Photoshop droplets don't work after file.copy();
            mkeatley17 Level 1
            oh wow! that works really well! thank you.
            I'm not understanding what you mean when you say file.copy() makes a "NEW" file, and what the problem is with that?? I've been using file.copy() for other things, so maybe it would make sense to change everything to a shell script....
            • 3. Re: Photoshop droplets don't work after file.copy();
              What I mean is that the resulting files modification date is set to the time stamp of the File.copy() call. This is NOT the behavior of the OS. Say if I was to move a directory to process and my script does NOT modify every file within that. (This is typical workflow for me). When I put these files back on the server 'Retrospect' will think everything has been modified and want me to back-up the lot again. But I know this is NOT the case. In my case I need to have the system move/copy the files or I would need to use bridgetalk and have Bridge app do copyTo() and moveTo() as this works correctly…
