1. Re: PPBM Results question
Harm Millaard Mar 4, 2011 2:49 PM (in response to Rkenosha)The only explanation is that you did not follow the instructions to the letter. These results are unbelievable on whatever system you have. I suggest you print the instructions and with these in hand, do the test again. It is pretty easy to make a simple mistake, like a slightly different encode preset, the wrong sequence for encoding, not deleting the preview directory, etc.
2. Re: PPBM Results question
Rkenosha Mar 5, 2011 4:58 AM (in response to Harm Millaard)Harm, Can I ask unbelievable in what way? Thanks Roman. I do have the instructions in
hand and will try again. In the next post I will also list my system. Thanks Roman
3. Re: PPBM Results question
Rkenosha Mar 5, 2011 5:58 AM (in response to Rkenosha)Ok, I did the test very carefully again. The two reseults are 406-
20-36-7. The second result, Software only. 412-21-26-88.
My system.
Gigabyte x58a-UD7
24 gig ram
Intel Six core 980 extreme running stock
Nvidia GTX 480 Will give more if needed.
Thanks again Roman
4. Re: PPBM Results question
Harm Millaard Mar 5, 2011 7:22 AM (in response to Rkenosha)Unbelievable in the sense that some scores are nearly 8 times slower than the top, but on other scores your system is around 50% faster than anything we have ever seen yet and more than 100 % faster than other 980X at stock speed.
5. Re: PPBM Results question
Rkenosha Mar 5, 2011 8:35 AM (in response to Harm Millaard)I did the test again, carefully watching each step. I just get consistent results. I Included the two out put files as attachments.
Roman
Output.txt.zip 153 bytes
Outputmpe.txt.zip 158 bytes
