1 Reply Latest reply on Mar 4, 2011 11:23 PM by Mylenium
    Time lapse movie cuts off half way
    the_squabbish
      I have a sequence of aprox. 3000 images which I have imported into AFCS5 and added Time Warp effect to. But even though I try different resolutions and codecs, it keeps cutting off at the same place, just about half way. Is there a limit to the number of images I can have in a time lapse or something?
      Any help is much appretiated, as I am very new to this.
        • 1. Re: Time lapse movie cuts off half way
          Your own fault very likely. Effects cannot manipulate the layer duration and hence at some point you simply run out and hit the end of the comp, while the actual footage may be much longer. Ergo: Put the footage in a pre-comp much longer than the footage duration and apply the timewarp to the pre-composed stuff in the main comp.
          Mylenium
