2 Replies Latest reply on Mar 6, 2011 9:11 AM by JMResler
    Flex RSL library issue
    JMResler Level 1
      I have a Flex app that loads a WSDL dynamically. The web service is then available to be called from the UI.
      When I run the application from within the bin-release directory, outside of Flash Builder the application runs fine.
      When I move the bin-release directory it cannot talk to the web service. The URL is read from the flashvars parameter.
      I don't want to lead possible correct answers but I would expect this to be a path issue under other languages.
      Is there something in the way the RSL's are setup that would change from the project directory to a relocated bin-release directory?
      Thanks in advance,
      John
        • 1. Re: Flex RSL library issue
          Flex harUI Adobe Employee
          If you are using file:// then you will need to modify the FlashPlayer Trust
          file.  If you are using http:// it might be a crossdomain.xml issue.
          Are you getting an error?  Post the full text of the error.
          • 2. Re: Flex RSL library issue
            JMResler Level 1
            Well you were close. The Security Panel has an option to allow applications access from other sites. There is a crossdomain.xml file on the remote server
            but my SWF didn't have permission to make the call. The mx:WebService object was not throwing an exception so I generated the objects from the
            Data menu, retried and received the SOAP fault I wasn't receiving/catching earlier. This then put me on the right track to solving the problem. Thanks for
            your input.
            - John
