1. Re: View all layers in title creator?
Bill Hunt Mar 5, 2011 11:05 AM (in response to funkbomb)Can you tell us exactly what you are doing to create your Titles?
Are you creating them as Layered PSD files in PS?
If so, then Import those in as Sequences, and you will have separate Layers to use on separate Video Tracks. If you Import as Footage, then the Layers are Flattened, and one will only see the top-most Layer. The others no longer exist.
2. Re: View all layers in title creator?
funkbomb Mar 5, 2011 11:45 AM (in response to Bill Hunt)No, I'm using the title creator in Premiere Pro. When editing a title that exists on a timeline already, only the text layers below that one show up in the preview window.
I place three titles on the timeline on top of a video layer. So that's four layers. I double-click the second title from the top to edit it and move the text around. The title editor comes up, with a preview window of the video and other text in the other layers. However the text from the layer above does not show up here. It makes placement very annoying because I can't see what's going on depending on what layer of text I'm editing.
I can't use PS because I need to see the video layer below when placing the text, the different layers have to be animated, and going between PS and Ppro is too time-consuming considering how many titles I have to do.
3. Re: View all layers in title creator?
Bill Hunt Mar 5, 2011 12:35 PM (in response to funkbomb)OK, thank you for the clarification.
In Titler, there is a checkbox for Show Video. That will show the Video on the Tracks below, and can be very handy for alignment, etc.
When you have stacked Titles, you will not have a clear view of your currnetly being edited Title. Uncheck Show Video, and you should have ONLY the Title in Titler, the editing program.
When you are working in Titler, you can ONLY see the currently being edited Title, and the Title (or Video) below it, with Show Video checked. You cannot see any Titles or Video on higher Tracks - sorry.
Good luck, and hope that helps,
4. Re: View all layers in title creator?
Bill Hunt Mar 5, 2011 12:37 PM (in response to funkbomb)If you wish to see other Titles for alignment purposes, then perhaps this ARTICLE on Alignment Grids will be useful. It includes a few, but they are so easy to create and customize in PS, that I always produce them, just as I need.
5. Re: View all layers in title creator?
Bill Hunt Mar 5, 2011 12:38 PM (in response to funkbomb)If neither of those suggestions gets you what you want, can you post a screen-cap of your Timeline with the Titles showing, and also the Titler open, and annotate that to show what you would like to see where?
6. Re: View all layers in title creator?
Powered by Design Mar 5, 2011 12:58 PM (in response to funkbomb)This is just a work around but you could awlays create a JUNK 5th layer and do your editing of your title on that layer that way all layers show up.
Just drag your copy up to the 5th layer, edit, then move it back.
Also if you have 2 monitors you can watch your Program monitor and see the edit that is happening in the title window.
If you make the title smaller you can see your Program monitor too.
I think a check box that would show tracks above would be a good idea.
GLenn
7. Re: View all layers in title creator?
Bill Hunt Mar 5, 2011 1:24 PM (in response to Powered by Design)GLenn,
Could be a perfect "workaround" for the OP.
8. Re: View all layers in title creator?
funkbomb Mar 5, 2011 1:43 PM (in response to Bill Hunt)Aha! Just discovered this...
The program monitor actually outputs all the text and video in their entirety and updates live as you move the text around in the Titler. Scoot the Titler window a little to the left allows you to see the monitor and use it to align all the text.
Thanks!
