3 Replies Latest reply on Apr 5, 2011 2:38 PM by AIF Bob
    Pixel Size bug with multiple inputs
    Christian Lett Level 3
      As part of a bigger project I've written a simple kernel to take one image (with alpha) and composite it over a second image.
      I'm testing it using images with different pixel aspect ratios. For example input image 1 has square pixels (1050x576), input image 2 has non-square (720x576 @ 1.46 PAR).
      In order to sample the second image properly I need to divide the current coordinate by the pixelSize of the background (which should be float2(1.46, 1.0))
      kernel Over
      <   namespace : "quarterlightpictures.com";
          vendor : "Quarterlight Pictures";
          version : 1;
          input image4 fg;
          input image4 bg;
          output pixel4 dst;
          void evaluatePixel() {
              float2 coord = outCoord();
              pixel4 pFG = sampleNearest(fg, coord);
              pixel4 pBG = sampleLinear(bg, coord / pixelSize(bg));
              dst = pFG + pBG * pBG.a * (1.0 - pFG.a);
      This doesn't work, because for some reason the pixel size for the bg image is considered to be (1.0, 1.0).
      Am I missing something obvious, or is this a bug?
      I'm testing this in After Effects CS5, by the way.
      Christian
