2 Replies Latest reply on Mar 13, 2011 9:19 AM by mianbarray
    could not find a jvm
    mianbarray
      hi all,
      I have the 64bit jdk installed so for Flex I had to install the 32bit java version which is located in C:\Java\jdk1.5.0_22_32bit
      I have updated the flex jvm.config but I still get the error that jvm could not be found.
      here is my jvm.config values
      java.home="C:\Java\jdk1.5.0_22_32bit"
      env=
      java.class.path="C:\Java\jdk1.5.0_22_32bit\bin"
      java.library.path=
      I have my JAVA_HOME, CLASSPATH and PATH env variables set to 64bit Java which I can't change due to work requirements. Any ideas?
      thank you
      P.S. I have tried this without the double quotes around the path as well
